Realtek HD Audio 5.1 surround sound plus frontmic?
Reddragon298
12:05 AM
Hello, I've been looking for a solution to this problem for hours and I can't seem to find anything. I'm trying to keep the 5.1 Surround sound and have my front jacks working so i can use my mic for things without unplugging anything in the back and switching to quad. please help me.
Asus
You haven't listed the exact PC model number or motherboard so I can't directly comment.
However, it sounds like you have one that must use the front panel connections, along with the rear audio connections for 5.1 surround sound. Is this how your system is configured?
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Right now I have it set up so all three audio ports are hooked up in the back taking up the rear mic. My mother board is a Asus PK5PL-VM and I'm using Asus on-board rear sound with realtek for some reason it tells me i have the front mic unplugged weather it is plugged in or not. I'm not sure if this will help but i hope it does
Asus
Check the front panel connection to the motherboard. The connector is probably labeled AC97 audio, but could be the newer HD Audio. If the connector is loose or not connected it could be the problem. The front panel mic jack could also be the problem. Does the front panel headphone jack work?
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
No the front jack does not work on the computer. I can't get it to work or play only through the front nor does it play through the front when plugging in headphones it will continue to only play through the surround sound speakers
Asus
Your motherboard is from 2009. Has it ever worked? Did you change the case? I agree, the front panel connector is either not connected or connected incorrectly.
Windows 7 Pro-x64i7-2600 3.4GHz - 3.8GHz Turbo8Gb - 2x4GB, Muskin 991770 PC3-1333Integrated Intel HD 2000
Built 2/11/2011
Windows 7 Pro-x64
Intel DH67BL-B3
Integrated Intel 10.1 HD, RealTek ALC892
Asus LCD VH222H, Haier HL24XSL2a
1920x1080, 1920x1080
Crucial SSD C300-128Gb,
Western Digital WD5002AALX - 500Gb,
Western Digital WD7501AALS - 750Gb
Seasonic 650W 80+ Gold Modular
Rosewill Defender
Stock CPU, Four 120mm case fans, PCH fan added
Logitech EX100 Y-RBH94 Wireless
Logitech EX100 M-RCE95 Wireless
3.0/1.5 Mbs
Microsoft Internet Explorer 11
Antec Veris Premier-Multimedia IR Station,
Cyber Accoustics-3602 Speakers,
AFT XM-5U Card Reader,
Hauppauge TV-HVR-2250,
Sony LX300 USB Turntable
Another item to check is the input separation. Open the Realtek Audio Manager from the control panel and see if you have the input separation button set.
Built 2/11/2011
Windows 7 Pro-x64
Intel DH67BL-B3
Rosewill Defender
3.0/1.5 Mbs
