A few Creative Sound Blaster Z problems. (Sleep Mode, Front Ports)
Lukelbs
10:40 AM
I have a few issues with my Sound Blaster Z card...
The first is that when my computer wakes up from sleep mode the sound stops functioning. In Foobar2000 I get this error message.
Unrecoverable playback error: A device attached to the system is not functioning. (0x8007001F)
I can't get any sound from the device but it still shows up in my device manager. When I restart my computer everything is normal and working again.
Second I'm not sure how to get it setup so that when I unplug my headphones from the front port the sound comes out of my monitor. I always have to change my default device in the control panel.
Any help would be great!
64 Bit Windows 7 HomeAMD FX Quad Core 41306GB DDR3HIS Radeon HD 7750
ASUS M5A97
6GB DDR3
HIS Radeon HD 7750
Sound Blaster Z
Even though the device still shows up in the device manager; there still could be something causing some sort of glitch here. i would completely uninstall the sound blaster in the device manager; reboot; and reinstall the drivers using the disc that came with the sound card(if you have the disc) and then update the drivers and other sound blaster software if there are any updates available for it.
Windows 7 ultimate 64-bitIntel I7 2600K 3.4ghzCorsair 16gb ddr3 1600mhzNvidia Geforce gt 430
custom built
Asus Evo P8P67
Sound Blaster Titanium x-fi pci express
Dell E198WFP
1 western digital 2TB drive.
Antec 1200 watt
Inwin Dragon Rider
6 case supplied cooling fans
logitech mk700
logitech m705
25-50mbps download; 10mbps upload(i think)
avg free 2014
mozilla firefox
Also have a pretty bad speaker setup which is a klipsch promedia 5.1 surround speaker setup with huge subwoofer and lg blu ray player/writer. Also a hp officejet pro 8600 plus wireless all in one and a logitech s7500 webcam.
Thanks for the response.
So I uninstalled the drivers and the software and re-installed in the order you said. Now instead of my device not functioning after sleep mode it will work but it asked me to select a new default device in my sound blaster software and in Foobar2k and I had to pick "Sound Blaster Z 2" which exists now instead of the original "Sound Blaster Z". My monitor is still silent too when I unplug from the front port.
ASUS M5A97
6GB DDR3
HIS Radeon HD 7750
Sound Blaster Z
bump
ASUS M5A97
6GB DDR3
HIS Radeon HD 7750
Sound Blaster Z
bump
ASUS M5A97
6GB DDR3
HIS Radeon HD 7750
Sound Blaster Z
Greetings Lukelbs. Sleep mode issues with the Sound Blaster Z are well documented, they (creative) did release updated drivers that they claim should have fixed the issue, it didn't. The only work around is to actually restart the computer.
My advise it to download the latest driver and give it a shot: Creative Worldwide Support > Sound Blaster Z
As for the front panel issue; I was among the early adopters of Sound Blaster Z last May. It was the worse mistake I ever made. The card worked perfectly for about 15 minutes, then the driver caused a blue screen. That issue was corrected with a driver release but then the front panel no longer switched back and forth between my analog headset and analog speakers. They release two more drivers none fixed the issue. I spent over $80 in shipping for all four Sound Blaster Zs they sent me in addition to well over 250 hours trouble-shooting the issue before I finally upgraded to an older X-FI Titanium Fatality Pro. I have not reinstalled Windows since the last time I tried a SBZ, my front panel does the same as you have reported. In short: The front panel will not function correctly until you replace the SB Z with another card and reinstall windows.
Windows 7 Home Premium 64bitFX 835016GBGTX 770 4GB
FX 8350
GA-990FXA-UD3
16GB
GTX 770 4GB
X FI Titanium Fatality Pro SB0886
Samsung
Western Digital
750 Watt
Challenger
Corsair H80i
Microsoft Natural 4000
Steelseries
