Solved Begging YOUUUU For Help Monitor RR problem!
Bliznez
11:23 PM
I have got a Problem that is just driving me nuts, Cause i cant enjoy my KotOR 2 game Properly- I got a great computer system, with nice monitor (ASUS Make, runningat 1280x1024 Res)
And I was Playing and Enjoying the Game (s) with the same resolution for months, at refresh rate 75 all the time.
Now, i DID switch to another Older system at some point, ie. i have Disconnected all peripherals, Keyboard, mouse AND monitor from my New system, And connected them to the old one- just casue one game doesnt like new 64 bit system- and after i Was done, I reconnected to my new computer again0 And weird stuff started happening- Firstly, my resolution went to 1024x768 . I fixed that in personalisation. When i Launched my KotOR 2 game, I noticed tha the Only Refresh Rate (RR) option was 60 (!!!!), Not 75, so I thought- Okay, this is just current setting in Windows
So i Went back to personalisation- and in Monitor tab in advanced settings there is ONLY 60! No 75!
So, Basically, My pproblem is- I had EXACTLY the same monitor, after Briefely switching it to another computer, literally less than a day, I connected it with original one and RR is now locked to 60 for unknown Reason, PLEASE please tell me how to fix it, before i go nuts to extent of actually writing a report to microsoft.
Windows 7 64 Bit6 Core16 Gb RAMATI
NI
Windows 7 64 Bit
6 Core
NI
16 Gb RAM
ATI
NI
ASUS
1- 2TB (internal)
NI
NI
NI
Model number of Asus monitor?
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Samsung 830 120GB SSD
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
Wow! :shock: that was So fast reply!
Well, im Not sure, i Got it from friends, is there some way to check it in the windows driver information?
on the Back it says MM17D, but im Not sure if that is the Actual model.
NI
Windows 7 64 Bit
6 Core
NI
16 Gb RAM
ATI
NI
ASUS
1- 2TB (internal)
NI
NI
NI
Clik here> ASUS - Display- ASUS MM17D
Checked the pdf manual and it a 75Hz monitor. Wanted to be sure.
I see you have an ATI video card. If you are using the AMD Catalyst driver/software you will need to select the Hz settting and resolution in Catalyst not through Windows.
You can check though this thread here> http://www.sevenforums.com/graphic-cards/1810-latest-amd-catalyst-video-driver-windows-7-a-175.html
I'm not up on the AMD video hardware/software. I've been using Nvidia.
I passed on a request to get some of the AMD specialists to come and take a look. They know a lot more than me. :D
Good luck.
Mike
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
OmG........
*fAcepalm*
I somehow KNEW the solution would Be something simple, i sort of SENSED it through the force......
If I can ever repay you , just tell me, Please.
Thank you VERY very much.
I can't believe I just got such an easy solution to the problem, lol......
pS. can U set karma in These forums? u deffinetely earned quite a few just now.
NI
Windows 7 64 Bit
6 Core
NI
16 Gb RAM
ATI
NI
ASUS
1- 2TB (internal)
NI
NI
NI
You found the settings in Catalyst?
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
OmG........
*fAcepalm*
Karma was sent his way. :D
Windows 7 Home Premium 64 BitIntel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz6.00 GB Hundai HMT125U6BFR8C-H9ATI Radeon HD 4850
HP Pavilion e9110t
Pegatron IPIEL-LA3
ATI Radeon HD 4850
Realtek High Definition Audio/ATI High Definition Audio
Acer AL2216W
Hitachi HDP725050GLA360 ATA Device 500 GB
Unknown/installed by HP
HP generic case
Intel Stock Cooling
HP Keyboard
HP Mouse
Download: 19.15 Mbps Upload: 1.67 Mbps
Network Adapter Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
Network Adapter 802.11n Wireless PCI Express Card LAN Adapter
I'm not sure if you did this or not but...
Make sure you turn off the PC and turn off the monitor before disconnecting the monitor.
If either was powered on when you disconnected the monitor that might have caused the settings to change.
Just a possibility.
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
oh, Yeah, i Have managed to Get it, and all Good old bugs with the game came back too Lol xD
but the Main thing is, That the 75 Option is now availiable in the game menu, i Chose it, and gaming process is back to normal now, Thanks Again)
Oh, and if some could tell me how to raise karma in Pm, or here, i will give u karma as well ofc
NI
Windows 7 64 Bit
6 Core
NI
16 Gb RAM
ATI
NI
ASUS
1- 2TB (internal)
NI
NI
NI
Glad you have it back to normal. ;)
Enjoy!
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
Bliznez,
If you wish to express your gratitude to HopX - click on the scales icon (middle icon in group of 3) in the upper right hand corner of one HIS posts, not my post
x64 (6.3.9600) Win8.1 Pro & soon dual boot x6...AMD A6-3420M APU with Radeon(tm) HD Graphics6.00 GBAMD Radeon(TM) HD 6520G
HP Pavilion dv6-6c10us
Hewlett-Packard 1805
6.00 GB
Logitech k520 wireless KB
15/5 | 54 MB Wireless 'n'
IE 11 on Win8, IE 10 on win 7
