BSOD after recent parts replacement (Error 124)
Dami107
11:47 AM
Hello good fellas! I hope you will be able to help me out with my problem, because it drives me crazy!
The PC is mainly used by my parents (YouTube, Facebook, movies, etc.). The configuration was pretty slow (nothing was changed for 6 years or so), but was just fine for them. MSI motherboard with Intel® Pentium® Processor E2160 and 2GB of DDR2 RAM. Unfortunately, the motherboard has died (I guess so). So I thought it's time to build a quite-modern PC for them. I have left good parts (Samsung hard drive and Corsair power supply).
The "refreshed" PC configuartion is as follow ("+" indicates brand new part):
Motherboard: Gigabyte GA-B85M-D3H (+)
CPU: Intel Core i5-4460 (+)
CPU cooling: provided with CPU (+)
Memory: GoodRam 2 x 4GB DDR3-1600 Dual Channel CL9 (+)
Power Supply: Corsair VX450W
Hard Drive: Samsung HD501LJ
and last:
Thermal paste: Arctic MX-2 1g (+)
After assembly, I have installed necessary drivers from the DVD (witch came with motherboard) and everything seemed to be OK. Unfortunately, after leaving PC for some time on idle, I got blue screen with error code 124. I had completly no idea, what could cause this problem. First thought was low CPU Vcore, which may be getting to low for stable work. CPUID HWMonitor (screenshot below) confirmed very low CPU Vcore values.
However, I have done a little more research (including sevenforums.com :) ) and downloaded BlueScreenView.exe, prime95.exe and RealTemp. I have read recommendation to perform a "Small FFTs" stress test for about 2 hours to see if there are any problems with CPU. I did start this test, but had to stop it about minute later, because RealTemp showed about 85 - 90 deg C on every core and there was no sign of stabilisation - temp. was rising and rising.
Intel Processor Diagnostic Tool 64bit passed the test, including one test "passed with warnings".
So, is it defective CPU? Or bad cooling? Or maybe something else I am not aware of? I thought that if I won't overclock CPU, I will be fine with Intel CPU Cooling.
Thanks for reading that much! Waiting for you reply!
And bonus question: I'm not native speaker, so if you could take your time and correct biggest errors in this post... It will make me happy :)
custom build
Intel Core i5-4460
GOODRAM 2 x 4GB DDR3-1600 Dual Channel CL9
Intel HD Graphics 4600
Samsung HD501LJ
Pakiet Bezpieczenstwa UPC (eng UPC SecuritySuite) by FSecure
Google Chrome / Firefox / Opera / Internet Explorer
Welcome to SevenFourums,
So i have had a look at the Intel report:
CPU Frequency Test Passed with Warning!!!
The processor frequency could be affected by[U][B] [COLOR="red"]power management[/COLOR][/B][/U] features. In order
to ensure the processor frequency is not affected by a power management setting,
enter BIOS, load [U][B][COLOR="red"]defaults[/COLOR][/B][/U], and disable any 'Over-Clocking' or power
management features that may affect processor frequency. Also, set any
software applications which control power management features to default.
Prime 95 will stress your CPU more then The Intel test would 85 - 90 deg is far too high!
The Highest Temperature you CPU is able to reach without causing damage is: 72.72°C
Lets try some troubleshooting:
  • Can you Boot into the BIOS and set everything as default.
  • Can you look at RealTempGT and take a reading of the Temperature and post it on here Please :)
Windows 7 Ultimate 64-bit
Intel G3420 3.2GHZ Dual Core
Gigabyte H87-HD3
Kingson 8GB 1600mhz
MSI R7970 TF 3GD5/OC BE
21" LG & "19 Vertical Samsung
120GB SSD - Boot
1TB WD
350GB External
2TB External (Wireless)
Corsair CX 500 modular
Zalman Z11 Plus (modified)
Corsair H55, 2x 120mm SP Corsair, 1x 140 Coolermaster
Corsair K50
CSL Gaming
164Mbps
Avast, Malwarebytes
Google Chrome, IE, Firefox
@HarriePateman, thank you so much for your answer!
All BIOS setting are set to their default values. This PC is not meant to be overclocked.
I am attaching 2 screen shots taken from RealTempGT - one when idle, second one when stressed with prime95 for no more than 30 seconds.
Edit:
Also, I think that it's worth to mention that (using CPUID HWMonitor) CPU Vcore is very... um... unstable. It differs from min. value ~0.3V up to max. value ~2.0V (!). And it doesn't matter whether Vcore is set to auto in BIOS or if I change it manually to 1.0V.
custom build
Intel Core i5-4460
Samsung HD501LJ
Thank you i will ask the hardware guru's to come over and take a look to make sure the CPU is performing Properly.
Gigabyte H87-HD3
Kingson 8GB 1600mhz
120GB SSD - Boot
1TB WD
350GB External
Corsair K50
CSL Gaming
164Mbps
Avast, Malwarebytes
@HarriePateman, thank you so much. I hope it's something that can be fixed at home.
I have contacted Intel Support Team and they believe that the problem lies in the motherboard.
After giving them results from Intel Processor Diagnostic Tools:
Yes, according to this, the processor is overclocked, although it shouldn't be since is not unlocked.
There seems to be an issue with the motherboard.
I can tell for sure that the processor is not overclocking itself. I recommend you to check with gigabyte, because apparently it is modifying the processors stock settings beyond specs.
And answer for the question if they think that the problem could be caused by the motherboard.
That is correct. But the fact that a processor that cannot be overclocked, is overclocked, leads to that. No processor can be overclocked by itself. Only motherboard BIOS / software settings can accomplish that.
custom build
Intel Core i5-4460
Samsung HD501LJ
Maybe its time to give gigabyte a call? :)
Gigabyte H87-HD3
Kingson 8GB 1600mhz
120GB SSD - Boot
1TB WD
350GB External
Corsair K50
CSL Gaming
164Mbps
Avast, Malwarebytes
@HarriePateman, yeah but they do not provide phone number here in Poland. Anyway, I have created a warranty ticket and as soon as I get their reply I will inform you here.
custom build
Intel Core i5-4460
Samsung HD501LJ
Brilliant, Gigabyte are very good with there customer care :)
Gigabyte H87-HD3
Kingson 8GB 1600mhz
120GB SSD - Boot
1TB WD
350GB External
Corsair K50
CSL Gaming
164Mbps
Avast, Malwarebytes
@HarriePateman, I hope you are not kidding ;)
custom build
Intel Core i5-4460
Samsung HD501LJ
Gigabyte H87-HD3
Kingson 8GB 1600mhz
120GB SSD - Boot
1TB WD
350GB External
Corsair K50
CSL Gaming
164Mbps
Avast, Malwarebytes
Hope he will find a minute soon.
Please excuse me for the quality of the image, but I had no idea how to take a screenshot here.
I have performed a Memtest86+ test and in the attachment you can find results... They are not making me happy.
custom build
Intel Core i5-4460
Samsung HD501LJ
Okay thats a very bad sign, one error is to many.
You need some new RAM, please remove one stick and run the test again that way we can see what RAM Stick is causing the errors, however it is possible that they are both faulty.
Gigabyte H87-HD3
Kingson 8GB 1600mhz
120GB SSD - Boot
1TB WD
350GB External
Corsair K50
CSL Gaming
164Mbps
Avast, Malwarebytes
I hope not. The lowest and highest failing adresses are within the range of 2MB. I think only one stick (the second one) is causing the problems.
Oh boy, faulty RAM, faulty motherboard, maybe faulty processor. That's my luck. ;(
custom build
Intel Core i5-4460
Samsung HD501LJ
Trouble always comes in 3, however i think your processor is fine as Intel said its your motherboard but as you have recently bought all of this you will still be cover by the warranty.
Gigabyte H87-HD3
Kingson 8GB 1600mhz
120GB SSD - Boot
1TB WD
350GB External
Corsair K50
CSL Gaming
164Mbps
Avast, Malwarebytes
