I think I'm in the right place. I bought a pre-packaged system from best buy 3 days ago:
Dell studio xps 8100
Win7-64bit
Intel i7 CPU 860 @ 2.80GHz(4 of em i think)
8GB DDR3 memory
ATI Radeon HD5770 graphics (1GB)
Dell 1505 wireless LAN PCI-E card and 802.11n mini card (802.11b/g/n)
...don't know how much more ya'll need as far as info on my system?
After getting it up and running, I tried to play a MMO game...and had very noticeable latency issues(pings going from 30 to 12,000)(even on lowest graphic setting)....where i had none before on an older system (wireless/hp media center/vista/3gb ram/256 Graphics card).
I disabled the built in wireless and pluged in my old linksys usb wireless conector. Afterwards I did not notice any latency issues.
Is the Dell 1505 not a good wireless system? With the N band available does it inversly effect the G signal? Why does it go strong for 3-5 mins then crap out for 30-40 secs?
Is there something that I can do to "boost" the Built in wireless, or at least keep it more consistant without the ups/downs?
also...in my search for a solution, I did a bit of research and noticed that the Graphics Card to the system I bought specifies a 450watt power supply; however, the package spec'd in a 350watt. I thought this was the issue before I checked the usb wireless signal/consistancy.
Should I just return the system, or is the wattage not an issue and the built-in can be fixed.
Thanks in advance, opinions and shots are welcomed.
Win7-64bit
8GB DDR3 memory
- Dell studio xps 8100
- windows 7 64bit
- i7
- 8gb
- Graphics Card(s)
- ATI Radeon HD 5700 series
