Computer *Jet Engine Sound* *Using Too Much Memory*
Batomega5
3:03 PM
Santo Domingo
My computer has started to sound like a jet engine when it starts consuming memory almost all of it with only google chrome open right now its consuming 1.12gb :mad: when i turn it on it sounds like a jet engine and when i play ang games even halo and it starts consuming memory it starts making that terrible sound.
https://www.dropbox.com/sh/92bzcs9n29c398j/1JVSkYoEpD
Some images of the task manager
Windows 7 Ultimate 32 BitAMD Athlon(tm) 64 x2 Dual Core Processor 4000...2.00 GBNVIDIA GeForce 6150SE nForce430
Dell Inspiron 531S
AMD Athlon(tm) 64 x2 Dual Core Processor 4000+ 2.10GHz
Inspiron 531S (Manufacturer: Dell Inc.)
2.00 GB
DELL USB HS-CF Card USB Device
DELL USB HS-MS Card USB Device
DELL USB HS-SD Card USB Device
DELL USB HS-xD/SM Card USB Device
ST325031 0AS SCSI Disk Device
Avira Antivurs Personal (Its outdated recommend me one)
Well the memory and cpu usage seems fine, Um. Have you tried cleaning out any dust? or making sure the computer isn't heating up? I know the fan on my laptop doesn't kick up the power until I accidentally block the fan.
Windows 7 Ultimate 64 bitIntel(R) Core(TM)2 Duo CPUT575 @ 2.00GHz (2 C...3GB DDR2Mobile Intel(R) 965 Express Chipset Family
Sony Vaio VGN-NR498E White Case
Intel(R) Core(TM)2 Duo CPUT575 @ 2.00GHz (2 CPUs), ~2
Chipset: Intel GL960 Motherboard: Sony MBX-182
3GB DDR2
Speaker/HP (Realtek High Definition Audio)
1280x800 32bit 59Hz
TOSHIBA MK2546GSX ATA Device 250GB 5400RPM
Laptop is old, and doesn't have a battery, and a broken mousepad, not related to drivers.
Might be heating up . how do i check to see if it is? and no i have not tryed cleaning any dust .
Dell Inspiron 531S
2.00 GB
3GB DDR2
1280x800 32bit 59Hz
Dell Inspiron 531S
2.00 GB
I would say, tomorrow try cleaning out some dust. And recheck it.
I recommend a can of compressed air, and anti static cloth? I think thats what they are. And give your PC a good clean.
3GB DDR2
1280x800 32bit 59Hz
Ok thanks for all the help :).
Dell Inspiron 531S
2.00 GB
