- Local time
- 10:53 AM
- Messages
- 436
Realtek HD Audio Properties
For Realtek HD users, this might help;
In Realtek's HD Audio Manager
I find it very useful to not combine inputs and outputs. You can do this by clicking on advanced device properties
Under Playback, select "Make front and rear output devices playback two different audio streams simultaneously" and
Under Recording, select "Separate all input jacks as independent input devices
Clicking "Ok" on this page will separate all output devices and separate all input devices you have on your system. Once on the main GUI, you can then select the default device you want to use as your input/output.
If you've plugged something on your front panel, you might want to click on the "Folder" icon which brings up this control
Then select the appropriate ones for your setup.
These two property windows will let you effectively control your input/output devices properly.
In my experience, combining or tying up input/output devices works well only if you have single input/output devices attached but not so great with multiple input/output devices.
This might work with other audio controllers as well
Windows 7 Build 7048 x64Athlon 64 X2 Dual Core 4600+4 x 1GB Kingston 400MHz 6-6-6-18 (800MHz)ATI Radeon 3650
- Custom Build
- Windows 7 Build 7048 x64
- Athlon 64 X2 Dual Core 4600+
- Motherboard
- EMX-AMD750G-PRO
- 4 x 1GB Kingston 400MHz 6-6-6-18 (800MHz)
- Graphics Card(s)
- ATI Radeon 3650
- Sound Card
- Realtek HD Audio
- Monitor(s) Displays
- 22" AOC 2216Vw
- Screen Resolution
- 1680x1050
- Cooling
- Arctic Cooling Freezer 64 Pro PWM
- Keyboard
- Generic Enhanced Natural Keyboard
- Mouse
- Logitech VX Nano
- Other Info
- Edifier M1550
