Display Calibration problem, please help
GoosePants
8:08 PM
I've searched on these forums and google and I'm beginning to think I can't fix this problem. Basically what happens is this. Everytime my computer goes into Sleep or Hibernate mode, it resets the color calibration. If I restart/shut off the computer, the settings are OK. But only if I use sleep or hibernate. It just won't have the settings I have calibrated. This means I am going back into the calibration settings and changing them again. I have already been in the color management box and have tried with those settings. I'm begging for help, this is a very anoying problem >.<. Any help is appreciated, thank you.
Windows 7 Home 64 Bit
i5-2500k
Asus P8P67 Pro
8GB Mushkin Blackline DDR3
EVGA GTX 570
1TB WD Black Caviar
Corsair 750w HX
CM 690 Advanced II
Logitech G110
Razer Deathadder
Dell XPS 420
6 gb
ATI Radeon 256MB HD3650
Intergrated 7.1 Channel Audio
Dell SP2009W 20"
640 GB Serial ATA Hard drive
Fan
Dell USB Keyboard
Dell Premium Optical USB
DSL 2.85
Hmm, I tried what you gave, didn't work, your help is appreciated though. Unless I didn't do something properly. I double clicked the .exe file and it popped up a window, than t just had the srgb profile selected.
Also one more thing, would it be possible to save a calibration and throw it in the quick bar at the bottom right? Than instead of going through all that crap, I just have to click a button and wala?
i5-2500k
Asus P8P67 Pro
EVGA GTX 570
1TB WD Black Caviar
Corsair 750w HX
CM 690 Advanced II
Logitech G110
Razer Deathadder
Dell XPS 420
6 gb
Dell SP2009W 20"
Fan
Dell USB Keyboard
DSL 2.85
Kind of, it is quicker than loading through control panel and clicking yes to everything in the calibration setup, but what I was looking for was more like, I click an Icon, and my screen calibrates to the proper color settings automatically. Your very helpful btw, thank you.
I'm also going to add that if I go to the color management profile window, and choose "Reload Current Calibration" it goes back to what I wanted. I'm just baffled why I need to do this whenever it exits sleep or hibernate?
i5-2500k
Asus P8P67 Pro
EVGA GTX 570
1TB WD Black Caviar
Corsair 750w HX
CM 690 Advanced II
Logitech G110
Razer Deathadder
Unfortunately my help must stop. The tutorial that I gave you is the best that I can do. Hopefully another member will have something that is more suited to your needs.
Dell XPS 420
6 gb
Dell SP2009W 20"
Fan
Dell USB Keyboard
DSL 2.85
Thank you anyways.
i5-2500k
Asus P8P67 Pro
EVGA GTX 570
1TB WD Black Caviar
Corsair 750w HX
CM 690 Advanced II
Logitech G110
Razer Deathadder
