Do I have enough power for my machine?
Panda4cash
9:30 PM
Hi everyone! I'm kind of concerned about my PSU and if its supplying enough power to my machine. I currently have a 460Watt PSU. Everything is running stable but I just wanna make sure my system is getting enough power.
Specs:
AMD Phenom ii x4 965 BE 3.4Ghz
12GB RAM
1TB HDD 5400 RPM
RADEON HD 6670 (400watt)
Windows 7 ultimate 64bit
Do I need an upgrade on a power supply or am I good with my 460W? I'm also planning on upgrading my graphics card to a gtx 660 which requires 450W. I don't know if I should stick with mine or get another. How much extra power do you need for your system?
Gigabyte
Windows 7 Ultimate 64bit
AMD FX 6300 3.5GHz
Gigabyte GA-78LMT-USB3 (rev. 5.0)
12GB
GIGABYTE RADEON HD 6670
Western Digital 1TB 5400RPM
Thermaltake 600W
Thermaltake commander MS-I
120mm back fan and stock CPU cooler
Microsoft comfort desktop 5000
Logitech G700 Wireless Gaming mouse
15/5 Verizon FIOS
I would suggest moving to a better quality power supply like a Corsair or Seasonic. I have also read good things about Antec. Make sure they are 80 + Gold. Something in the 650W range. It gives you a smother current and volt plus room for your computer to grow. If possible a modular makes a very neat install and improves air flow. Once you have used a modular you won't go back to the old style.
100% correct. Here is one on sale with a $30 Promo code through 1/31. Corsair quality, semi-modular, 80+ Gold, 650 Watt.....should last you a long time meaning you can use this in your next build if you want. Best deal I've seen in quite a while. Looks to be about $89.99 with the promo code, and a $10 Corsair mail in rebate. That is a hell of a power supply for $79.99! Corsair HX 650
Intel Core i5-3570K @ 4.5GHz
Asus Sabertooth Z77
EVGA GTX 750 Ti FTW
Onboard Audio
Dell S2309W
Samsung 830 128GB SSD - OS
(4) Seagate 5TB HDD
(1) Seagate 2TB HDD
Intel Liquid Cooler
Mionix Naos 7000
50 Mbps Down / 10 Mbps Up
Chrome/Firefox
Klipsch ProMedia 2.1's
Asus RT-N66R Wireless Router
Skylake Special #666
Intel Core i7 6700K
Asus Sabertooth Z170 Mark 1
EVGA GTX 980 Ti SC x2
Realtek High Definition
AOC G2460PG
Logitech G910 Orion Spectrum
I do have a 600W laying around in my house. Is this a decent amount or so I need more? If I upgrade to the gtx 660, will te 600W supply more than enough power?
Gigabyte
AMD FX 6300 3.5GHz
12GB
Thermaltake 600W
15/5 Verizon FIOS
It depends on the brand of the PSU. Some claim to have 800Watts, and they explode trying to feed an HD 6670
Windows 7 professional X64
AMD A10-5800K OC@ 4.4Ghz.
Gigabyte F2A85X-UP4
8GB Kingston HyperX Blu 1333mhz
XFX HD7870 2GB Core Edition
Acer AL2216W
Seagate Barracuda 500gb 7200rpm
Seagate Barracuda 1.5TB 7200rpm
Cooler Master Silent Pro M 850W
Thermaltake Commander MS-I
Cooler Master N520
Logitech M504
10Mbps
Very well said. It all depends on the brand and the quality of build. For example, the one that came with my case is a generic 500W unit that doesn't even have any indication of who the manufacturer is. It is also a very light unit, weighing in at pretty much the same weight as my keyboard. I certainly wouldn't feel happy running a system off that unit (not even one where everything was integrated on the motherboard and no add-on cards were used).
A quick guide to quality of PSUs is their comparative weight. Decent quality units, such as those from PC Power and Cooling, XFX, etc. (that are based on Seasonic), are much heavier than the non-branded generic units of supposedly the same rating. This is because better quality components are used, which will have a better life and are much more capable of sustaining the PSUs rated output. In fact, many cheap units are simply not able to maintain a sustained output of much more than half their rating.
For example, if I had a system that wasn't too power demanding, I would be far happier to run it off a decent quality 350W model than a cheap non-branded 500W model.
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Use the power supply calculator to find the wattage rating that you'll need:
eXtreme Power Supply Calculator
I find it ironic that the DIY crowed is talking about PSUs that have a rating of close to a thousand Watts and when you buy an OEM desktop, it'll have a 300W PSU. Even, the OEM with i7-3770 CPU and AMD Radeon™ HD 7570 1GB GDDR5 comes with a 460W PSU...
Custom built at Home
Windows 7 64-bit, Windows 8.1 64-bit, OSX El Capitan, Windows 10 (VMware)
Intel i5-3350P 3.1 GHz
Gigabyte GA-Z77X-UP5 TH
16 GBs GSkill Sniper
Radeon HD 7850
VIA HD Audio
Dell U2410 24"
1920x1200
1 x Intel 520 240 GBs
1 x Seagate 1TBs SATA 2.0,
1 x Seagate 1TBs eSATA 2.0
Thermaltake 850W
Antec P183
Noctua NH-D14 Heatsink 2 x 120mm fans, 4 x 120mm case fans
Dell Multimedia keyboard
Logitech Trackball
28.5 Mb/s
Your Cooler Master PSU is adequate for the Radeon. (If it's the Elite model, it has two 18A +12V rails, and a max. total current at +12V of 27A.) However, it's not intended to drive high-end graphics cards: it has a single 6 pin PCI-E power connector, which means that it'd work with a 660, but not (without Molex-to-PCI-E adapters) with a 660ti.
I dunno about trying for 80+ Gold efficiency ratings. The Corsair PSUs that I'm familiar with are 80+ Bronze, but few would sneer at those.
homegrown
Windows 7 Pro X64 SP1
Intel Core I7-3930k
Asus P9X79 Pro
16 GB Gskill DDR3-2133
eVGA GTX680
Creative X-Fi Titanium
As PA246Q
1920 X 1200
Corsair Force GT, 120 GB
WDC 1.5TB Caviar Black
PCP&C Silencer 750 Crossfire
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
Microsoft Intellimouse Explorer (old optical) USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Monsoon 5.1 speakers
I linked him to the HX650 by Corsair........semi-modular, 80+ Gold and plenty of PCI-E connector for video cards. All that for less than $100.
Asus Sabertooth Z77
EVGA GTX 750 Ti FTW
Onboard Audio
Dell S2309W
(4) Seagate 5TB HDD
(1) Seagate 2TB HDD
Intel Liquid Cooler
Mionix Naos 7000
Chrome/Firefox
I did try this link and i put in my graphics card and the rest of the important stuff. Somehow it calculated a minimum of 300 something Watts. That is irrelevant because my card expects 400W min.
Gigabyte
AMD FX 6300 3.5GHz
12GB
Thermaltake 600W
15/5 Verizon FIOS
The HX650 is a very good choice, I have two. In my opinion a PSU with a single 12V rail and active PFC (Power Factor Correction) is always best.
Windows 7 Ultimate X64 SP1
ASUS P8Z68-V PRO/GEN3
Onboard Realtek 5-1
Samsung P2570HD
Corsair HX650W
Inwin Dragon Rider
Norton Internet Security 2013
That is likly the usage that you would have if Idle under load it would be much higher a Graphics card can use inbetween 75 to 150 w from idle and up to 200 to 500 w underload
Enthod Pro Full Tower
Logitech wireless keyboard
Logitech wireless mouse
Cox Cable 100+ mb
IE-10, Chrome, Opera
GPU GTX Gigabyte 970G1
My apologies. I'm out of date. www.newegg.com lists many 80+ Gold or Platinum units at prices that aren't absurd. There are a reasonable number of choices even if you put a lot of filters in their Power Search (80+ Gold or Platinum, single 12V rail, modular, active PFC). It's a good place to look for information even if you cannot (outside of US or Canada, or no credit card), or will not, do business with Newegg.
homegrown
Intel Core I7-3930k
Asus P9X79 Pro
eVGA GTX680
As PA246Q
1920 X 1200
Silverstone FT02
Noctua NH-D14
cheap Logitech USB
6Mb cable
Pioneer BDR-205
Samsung SH-203B
Well I guess everybody is going for a quality power supply. Let us know what you choose.
