GTX 460 Kernel 41 power issue need help ASAP
rebelicious14
5:02 PM
Hello guys im new in here i just got an problem with my system
i was just lunching steam like i do normally and then i open up counter strike GO
then my suddenly my computer restarts with no warning and keeps restarting after the windows logo
and there pops up blue screen for about 2 seconds and restarts again
i open up safe mod and i check the event viewer and i get this critical error
here down below
Critical 12-07-2013 16:13:05 Kernel-Power 41 (63)
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 12-07-2013 16:13:05
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: magicmuffin-PC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2013-07-12T14:13:05.438433000Z" />
<EventRecordID>1227</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>magicmuffin-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">278</Data>
<Data Name="BugcheckParameter1">0xfffffa8005a58010</Data>
<Data Name="BugcheckParameter2">0xfffff88004795e30</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x2</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
and after that those tons of retarts
i started getting green lines on my monitor witch is obviously my video card because i have tried 2 other monitors
the only thing i can do to run windows normally
go in to safe mod unistall display drivers and then boot it up notmally
as soon as i re install the dispay driver and try to retart normally i get the blue screen and restart again
so i can only run my computer in safe mode
i re installed the OS and formated i keep getting the restarts and the bluescreens
is anyone here with a similar problem or knows what to do
here are my full specs
MSI 870A-G54 AMD Motherboard
AMD Phenom II x4 955 Black Edition Quad Core 3.2Ghz AM3 8MB 125w
RAM kingston ValueR DDr3 1333Mhz 4GB
Gainward GeForce GTX 460 1GB GS
PSU Silver power SPSS500 W ATX 12v v2.2 80 plus
thanks
Windows 7 home Premium 64bit
Windows 7 Professional 64bit
AMD Athlon (tm) X2 5200+ Dual Core 2712 Mhz
Asus
4GB
Nividia GeForce 8600 GTS- DIED 25/7/2013 R.I.P
None
22" Yuraku LCD (Dont ask)
1280x960
2TB WD Caviar green
Windy up type
Scout cm Storm
Hair dryer on full cool power ;-)
QWERTY
Microsoft Special
BT Infinity 9.38Mb/s Wheeeeeeeeeeeeeeee!!
Internet Explore 10 and Chrome
Don't shout...I've got a Hangover!
I would also take a serious look at a better power supply.
Every review I have look at call this a budget power supply of question.
