necronikka
- Local time
- 9:08 PM
- Messages
- 1
Here is my Build:
Logitech Z333 80 Watts Multimedia Speakers (980-001203)
Samsung 850 EVO 500GB 2.5-Inch SATA III Internal SSD (MZ-75E500B/AM)
Seagate 2TB BarraCuda SATA 6Gb/s 64MB Cache 3.5-Inch Internal Hard Drive (ST2000DM006)
Corsair Vengeance LPX 32GB (4 x 8GB) DDR4 DRAM 2666MHz (PC4-21300) C16 memory kit for DDR4 Systems
Phanteks Enthoo Pro M PH-ES515PTG_BK, Tempered Glass Window, Brushed Black Steel/Plastic Mid Tower ATX Chassis
SilverStone Technology All-In-One Liquid CPU Cooler with Dual Adjustable 120mm PWM Fan TD02-LITE
Gigabyte GeForce GTX 1080 G1 Gaming 8Gee
Intel 7th Gen Intel Core Desktop Processor i7-7700K (BX80677I77700K)
MSI Pro Series Intel Z270 DDR4 HDMI USB 3 SLI ATX Motherboard (Z270 SLI PLUS)
EVGA Supernova GS 650W 220-GS-0650-V1 Fully Modular Power Supply
I also use 2 monitors, 1 HDMI 42 TV and a 32 inch 1440p monitor.
So I have very few problems and have exhausted all the troubleshooting I could.
Monitored temps, reseated things, all except replacing things, as this is a problem there seems to be no real solution to, although, everything software related I have tried.
What happens is this. The computer will restart randomly with this error, which by the way has no bug check. It will just restart itself and go to the home screen. It typically happens when I am gaming (Players unknown battlegrounds). I do not get a blue screen or anything, just the event viewer saying what happens.
I build this in febturary, but I'd like to find a fix for this.
Any help is apperciated, I am really hoping it is not the power supply as my case does not make replacing that easy. And if it is, I was wondering if Underclocking is an option.
I'd appreciate any help in isolating this issue.....
At this point I used DDU in safe mode to uninstall alll gpu drivers and reinstall, it did not really help much as 6 days later it rebooted on it's own idling again, just an update from my previous months of troubleshooting this issue.
I also do not get a BSOD or minidump because of this, but I can post the event lots. Also I have ran sfc scannow 3 times for errors and got nothing
Also, chrome opens all the tabs that were open when i restart my computer sometimes, not sure why, like if i have multiple windows of chrome open, restart PC, and get back to logon. The tabs open that were left off, not sure if that has anything to do with anything though.
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="EventLog" />
<EventID Qualifiers="32768">6008</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2017-11-07T09:21:56.935627100Z" />
<EventRecordID>1729</EventRecordID>
<Channel>System</Channel>
<Computer>DESKTOP-6I6LBGP</Computer>
<Security />
</System>
- <EventData>
<Data>4:20:42 AM</Data>
<Data>11/7/2017</Data>
<Data />
<Data />
<Data>291966</Data>
<Data />
<Data />
<Binary>E1070B0002000700040014002A007102E1070B0002000700090014002A0071023C0000003C0000000000000000000000000000000000000001000000FAFFFFFF</Binary>
</EventData>
</Event>
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>6</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2017-11-07T09:21:53.594382000Z" />
<EventRecordID>1742</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">true</Data>
<Data Name="CheckpointStatus">0</Data>
</EventData>
</Event>
Windows 10 64 bitI7-7700k
- Computer type
- PC/Desktop
- Custom Build
- Windows 10 64 bit
- I7-7700k
