I have a problem on my right click
eth2234
9:38 PM
so hi all I have a windows 7 and A toshiba satellite c50-A560 I bought it about 5 months ago..
everything was great And I had no problems AT ALL but before yesterday my laptop right click button stopped working :O I was watching a film when it happened so idk :( I tried to re install but the same problem happened
any one help please? also I downloaded melware but it detected nothing :(
TOSHIBA
Intel(R) Core(TM) i3-3110M CPU @ 2.40GHz
Intel PT10F
4.00 GB
(1) NVIDIA GeForce 710M (2) Intel(R) HD Graphi
(1) IDT High Definition Audio CODEC (2) Intel(R) Display A
1366x768
You need to bring a lot more information to the forum in order for us to help you.
Please read this article to understand how to ask for technical help:
How to Ask a Question When You Want Technical Help
If you do not understand, ask. Please refrain from using 1 word/sentence responses, and avoid text stating things like "I am not good with computers".
It is okay to not know something, and we can work together to solve almost any issue. This is a two way street, both sides must work together to get results.
Please fill out your system specs (if possible) by following this tutorial here: (Click the blue words)
http://www.sevenforums.com/tutorials/180324-system-info-see-your-system-specs.html
Once we have more information, we will be happy to assist you. :)
Windows 10 Pro
Motherboard Built in
Wired Dell keyboard
Wireless Logitech mouse
250mb down, 30mb up
Panda Cloud Antivirus
Chrome-ish x64
What is melware?
Malwarebytes?
Just because your right click does not work does not mean you need to scan for malware.
It is most likely you hit the key to disable the mouse buttons.
Check control panel-mouse. Look in there for an option to enable the trackpad and/or buttons.
What do you mean you tried to reinstall? Reinstall what?
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
okay I uploaded my specs,
also I got a lot of blue screen of deaths,also my right click is working sometimes... so Idk what to do :( and I checked mouse options and there was nothing wrong with it , and I wanted to say Malwarebytes not malware Sorry XD, and sometimes the left click turns into right click function and left click function at the same time,
And I tried to reinstall the driver using the device manager but It didn't work :O
TOSHIBA
Intel PT10F
4.00 GB
1366x768
If it works sometimes and not others, it is most likely a hardware issue. Try pushing really hard on the button or using compressed air in it. Maybe some dirt or something caked it up and that is why it is not working
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
guys i have the same problem again but this time the right click and the left click are working
but when I click on left click it pops out the right click menu and when I click on the right click it shows the right click menu too! :L
TOSHIBA
Intel PT10F
4.00 GB
1366x768
bump!
TOSHIBA
Intel PT10F
4.00 GB
1366x768
help?
TOSHIBA
Intel PT10F
4.00 GB
1366x768
