IE 9 problem please help
bro i bought norton using 32$ u know
most importantly after installation of norton 1st week everything is fine
Okay bro.
Try this bro:
Manually go to internet options | advanced |
Accelerated graphics | check “Use software rendering instead of GPU rendering”
really appreciating your kind assistance;;;but sorry to say that still only in IE facebook is blank and YM chat screen is also blank :( :cry:
Home Premium 64bit.
Self assembled
Windows 10 Home 64Bit
Intel Core i5 10400 @ 2.90GHz
Intel Corporation DG41WV (PROCESSOR)
8.00GB Single-Channel Unknown @ 1329MHz (16-20-20-38)
DELL E170S
1280x1024 pixels
931GB TOSHIBA DT01ACA100 (SATA)
238GB TEAM TM8PS7256G (SATA SSD)
Nothing Fancy
Fans
A4 Tech Co LTD
A4 Tech Co Ltd/Logitech
25 Mbps
It will give you a ID and Password.
Just post them on this thread or post it on my profile.
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
Sure bro.
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
892 558 937
pass 8789
here it is bro
Home Premium 64bit.
Bro, I hope you have downloaded 32 bit of Java.
We will try to fix your problem tomorrow evening.
Take care.. bro!
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
okki :D
but java 32 doesn;t fix it :(
Home Premium 64bit.
Self assembled
DELL E170S
1280x1024 pixels
Nothing Fancy
Fans
A4 Tech Co LTD
25 Mbps
reinstall of windows solution is such kind of solution when all the door are close ..by the way thx for your time buddy :)
Home Premium 64bit.
does any body have any other solution please !!
Home Premium 64bit.
