Solved IE9 32 Bit and 64 Bit Problem
windude99
Windows 7 Guy
10:38 PM
USA
When I open up a link in Windows Live Mail or a link in another application, it opens up the link in 32 Bit Internet Explorer 9 instead of 64 Bit Internet Explorer 9 which is what I use. How do I make applications use Internet Explorer 9 to open up links instead of 32 bit. This all started after I installed Google Chrome and it became the default browser and then I uninstalled it and it set Internet Explorer 9 as the default again (which is what I wanted). Thge probelm is that I have Internet Explorer 64 bit pinned on the taskbar and applications use 32 Bit, so there are two Internet Explorer icons on the taskbar. Here is what happens:
HP Pavilion P7-1010
AMD Athlon X4 645
Foxxcon N-Alvorix RS880
6GB DDR3 1066
Sapphire Radeon HD 5670 512MB GDDR5
Realtek Integrated Audio
HP 2011x
1600x900
1. Crucial M4 128GB SSD
2. 1TB Seagate Barracuda 7200.12 RPM
3. 1TB Western Digital Caviar Green 5400RPM
Seasonic S12 II Bronze 380 Watt
HP OEM
Coolermaster Heatsink, AVC Case Fan
HP OEM- Made by Chicony
HP OEM- Made by Logitech
20MBit Down/4 Up
Internet Explorer 10
All Win 7 64-bit computers come with 2 IE bit versions, 32 and 64.
It is best if you leave IE 9 32-bit as your default browser, because there are still some instances that 64-bit IE will not work. 32-bit IE is universal.
Until Microsoft have it all sorted out, use 32-bit IE version.
Acer Aspire 7741Z
Windows 7 Home Premium 64-bit, SP1
Intel Pentium P6200, Cores 2, 2.13 GHz
Intel HD
unknown
17.3 inches
1600 x 900
640 GB, 5400 PRM
If I try to open IE 9 32 bit, it opens the 64 Bit version.
HP Pavilion P7-1010
AMD Athlon X4 645
6GB DDR3 1066
HP 2011x
1600x900
HP OEM
20MBit Down/4 Up
Sorry, you lost me.
You said that when you clicked on a link, it opened in IE9 32-bit version. Yes ?
You said IE9 32-bit appeared to be your default. Yes ?
Now how did you attempt to open IE9 32-bit ?
Did you go.... Start > All Programs > Internet Explorer ?
How did you know it was the 64-bit IE opened instead ?
If you click Help at the top of the Internet Explorer window > About Internet Explorer > what does the window say ?
Does it say 64-bit or does it say version : 9.0.8112.1642
Why not UN-pin IE9 64-bit from the taskbar ?
Acer Aspire 7741Z
Intel HD
unknown
17.3 inches
1600 x 900
640 GB, 5400 PRM
I Might have replied in a hurry and I have not make myself clear.....
I mean UN-opin all you IE icons from task bar > go to Start > All Programs > right click at Internet Explorer ( NOT the 64-bit ) > Pin to task bar.
Now please go to task bar and click at the newly pinned IE 9.
Acer Aspire 7741Z
Intel HD
unknown
17.3 inches
1600 x 900
640 GB, 5400 PRM
@windude: You're trying to get the 64bit IE9 to launch instead of the 32bit version when you click on a link, right?
This might help (ignore that it says Server / XP)
--> edit: You say it started when ..... but I have to ask, did the 64bit IE9 ever launch when you clicked on a link before?
HP Pavilion dv6-6c10us
Hewlett-Packard 1805
6.00 GB
AMD Radeon(TM) HD 6520G
Logitech k520 wireless KB
15/5 | 54 MB Wireless 'n'
IE 11 on Win8, IE 10 on win 7
I fixed the problem! I went to Turn Windows Features on and off and turned off Internet Expolorer 9 and Rebooted. Then, I reenabled Interrnet Explorer 9 and rebooted again. Now, everything works correctly. Thanks for your help!
HP Pavilion P7-1010
AMD Athlon X4 645
6GB DDR3 1066
HP 2011x
1600x900
HP OEM
20MBit Down/4 Up
