Solved iRush Pro Monitor Problem
Like this one.
ME/XP/Vista/Win7
ME/XP/Vista/Win7
The only other thing I need is the blue monitor cable (the one I used was for the family desktop) any idea where I can get them?
Windows 7 Ultimate x64Intel Core i5 2500K Processor2x4GB DDR3 1333Mhz MemoryNovatech Radeon 6770 1GB Graphics Card
iRush Pro
Intel H67 Chipset Motherboard (Micro ATX)
1TB
Novatech 500W
Novatech ATX Gaming Case
Novatech Wired Keyboard
Novatech Wired Mouse
VirginMedia 10MB/s
iRush Pro
1TB
Novatech 500W
VirginMedia 10MB/s
I don't know if there is a PC World, Comet, Argos or Currys in the US, but I need this ASAP to see if it works, so I would have to go to the actual shop and buy it do you think they would sell the blue cable and DVI to VGA cable (if not, where in the UK can I get one?
iRush Pro
1TB
Novatech 500W
VirginMedia 10MB/s
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
iRush Pro
1TB
Novatech 500W
VirginMedia 10MB/s
Yeah.
With that 9.18 pound cable, you don't need the separate adapter. It is male on both ends.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
iRush Pro
1TB
Novatech 500W
VirginMedia 10MB/s
One of the RED.
ME/XP/Vista/Win7
ME/XP/Vista/Win7
Thank you very much guys, I'll let you know how it goes.
One last question:
I have a AMD Graphics Card Driver CD, a Windows 7 CD, and a FOXCONN Drivers & Utilities CD ITL-0B2 Motherboard disk with Norton (I won't install Norton).
I'm guessing I install Windows 7, then the GFX Driver then the Drivers/Utilities disk, please correct my mistake.
Cheers Joe
iRush Pro
1TB
Novatech 500W
VirginMedia 10MB/s
Install Windows, get antivirus running, update Windows, and then take a look in device manager and look for errors.
Windows should recognize the graphics card and install a driver for it.
You may not need the AMD driver disk unless it has some special features not in the Windows driver.
You may not need the Foxconn disc either--it just depends on what functionality is missing after Windows is updated. For instance, you might not have sound or a working Internet connection. In that case, look in Device Manager to see what drivers are installed already. You may then have to resort to the Foxconn disc.
I'd at least look at the Foxconn disc, but I wouldn't blindly install everything I saw.
I'd avoid installing as much as I could get away with. Pick and choose. There is very little chance you will need it all. The "utilities" may be totally useless or worse.
1600 x 900
Antec Solo II
Pale Moon
The driver disk for the video card, either through it out or use it as a coaster. Just go here,
ATI Radeon
to get the driver for it. Same can be pretty much be said for the Foxconn and utilities disks. Just go to the Foxconn download page for the model of motherboard and get the latest No idea what utilities Foxconn has but if they are anything like the one's from Asus (nice programs in theory, but just way to much bloat for what they do), then no you don't need it.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
I would do that but the problem is there is no network card preinstalled, someone from nova tech linked me to a USB Wirelesss Adapter.
Unless it doesn't even need net to run.
iRush Pro
1TB
Novatech 500W
VirginMedia 10MB/s
Yes there is. Unless they used some off the wall motherboard, there hasn't been a consumer grade motherboard made recently that doesn't have an onboard NIC of some kind. Not only does that motherboard have an onboard NIC, it also supports gigabit lan,
The irush Pro
Unless you need wireless (for which yes, you will need either a wireless card or USB adapter), then it already has all you need. just plug an ethernet cable into the port on the computer and the other end to your router or modem.
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
http://www.foxconnsupport.com/downl...000000001&Series=en-us0000014&keywords=&sort=
Above appears to be the download page for your motherboard at Foxconn. You can go there and get the latest drivers if you have issues.
You have an onboard LAN chip. The driver for it is at the above link and should also be on your Foxconn disk.
It looks like all of the downloadable stuff is dated Dec 20 of 2010, so it may not be any newer than what is on your Foxconn disc.
You should definitely download the motherboard manual.
1600 x 900
Antec Solo II
Pale Moon
iRush Pro
1TB
Novatech 500W
VirginMedia 10MB/s
Yes it will work, but why would you want that one when it is almost 2.5x more than the one linked to previously?
Me
Win 7 Ultimate x64
Asus M5A97 EVO
Acer S232HL Abid
120 GB OCZ Vertex 3
Antec Three Hundred
Logitech G510
Logitech G500s
Monitor finally works, installation gets an error and is stuck on Expanding Windows Files - 0%
(face palm)
iRush Pro
1TB
Novatech 500W
VirginMedia 10MB/s
iRush Pro
1TB
Novatech 500W
VirginMedia 10MB/s
