Missing power state controls in advanced power plan settings
KAAMO
12:43 PM
Hi guys, I'm new here and this is my first post. I have an Optiplex 745 running Windows 7 Professional. Normally in the advanced setting section of the power plan option I have the option to change the power state, however all of a sudden these options have just totally disappeared. Any help is appreciated.
Thanks in advance.
Dell Optiplex
Intel E6400 2.13 GHz
8GB DDR2
1GB NVIDIA GEForce 8400
HP 201
250GB SATA
AVAST Pro and Avast Grimefighter
Skylake Special #666
Intel Core i7 6700K
Asus Sabertooth Z170 Mark 1
EVGA GTX 980 Ti SC x2
Realtek High Definition
AOC G2460PG
Logitech G910 Orion Spectrum
I am using High Performance. I am not getting the option in any powerplans.
Dell Optiplex
8GB DDR2
HP 201
250GB SATA
I have tried the fix stated in option 2 but still no luck unfortunately
Dell Optiplex
8GB DDR2
HP 201
250GB SATA
Hello Kaamo,
Thanks for posting your question.
Is this a most recent issue you are experiencing? If it is, why not try to system restore to before it was happening?
1. When turning on your computer, continuously tap F8
2. Select Repair Your Computer.
3. Select System Restore.
Make sure to restore to before the issue was occurring.
Thank you,
VinnyBuxton
Brilliant, Ill give that try now and see if that solves it. Thankyou.
Dell Optiplex
8GB DDR2
HP 201
250GB SATA
A system restore hasn't fixed it unfortunately.
Dell Optiplex
8GB DDR2
HP 201
250GB SATA
