need help - Monitor "out of range"
ionut
10:13 AM
i've just installed windows 7, a beta version
i think it has selected a rezolution that's too high for my monitor, so i can't see anything on screen, it just says "out of range"
i can't start it in safe mode until installation is complete, that means running it for the first time.
Any sugestions?
don't know
don't know
ASRock ALIVENF7G-HDREADY
That shouldn't be the case, Windows chooses the Native resolution (the Best resolution), so you don't get this problem.
Have you tried to reinstall 7?
W7 RTM Ultimate x64Intel Q8400 @ 2.66GHZ4GB DDR2-800Gainward GTS 450 GLH 1GB Edition
W7 RTM Ultimate x64
Gigabyte GA-EG45M-UD2H
4GB DDR2-800
Integrated 8 Channel
AOC 23.6 Inch Widescreen LCD
Seagate 500GB Internal
Western Digital 1TB Internal
Hitachi 1TB External
Apevia Java Power 500W
Cooler Master HAF 922 Black
Stock Intel CPU Fan
1.5MB
i've tried reinstalling, even a different version, still a beta, and the same thing happens.
don't know
don't know
Hello Ionut, and welcome to Seven Forums.
That is strange. You might see if booting into the Advanced Boot Options screen (tapping F8 during boot), then selecting either Safe Mode or Enable Low Resolution Video (640 X 480) may allow you to boot into Windows 7 to check your screen resolution and refresh rate settings to make sure that they are correct for you monitor. While there you may also need to uninstall and/or install your video driver.
This Helped fix Frequency out of range problem
Ive been wrestling with this frequency problem all day- even tried the tips in your How to Change the Screen Refresh Rate in Windows 7
tutorial but the F8 routine got me to the happy land- thanks.
Windows 7Intel Core I3 Processor 5306 GB DDR3
Gateway DX 4831-01e
6 GB DDR3
gateway HX 2000
1 Tb
Hope so
