NEED HELP NOT CHARGING W7 Home premium
Jesse0389
3:19 AM
When I try charging my laptop it says ...% Not charging Please help I'VE REPLACED BATTERY AS WELL
32 BIT Windows 7 Home preniumUnknown4GBUnknown
L500D
Unknown
Unknown
4GB
Unknown
450GB
AVF
Google Chrome+ Ie 11
Have you tried clearing the residual power by removing the battery and holding the power button down for thirty seconds or so then replacing the battery?
Windows 7 Home Premium X64AMD Phenom II X4 9504 Corsair XMS2 DDR2 SticksRadeon HD5770
N/A
Biostar A78DEA2T
Radeon HD5770
WD5000AAKX
CoolMax ZU Series 1000W
NZXT Full Chassis
Corsair Liquid Cooling with additional 3 Fans
Google Chrome W AdBlock Plus
Hi I have a new HP laptop that show connected, not charging. I found this to work.
Disconnect AC
Shutdown
Remove battery
Connect AC
Startup
Open Device Manager
Click the plus (+) sign next to Batteries category, right-click All of the "Microsoft ACPI Compliant Control Method Battery" listings, and select Uninstall In the "Confirm Device Uninstall" dialog box, click OK. (it’s ok if you only have 1 of these listings).
Click the plus (+) sign next to System Devices.
Right-click the “ACPI Fixed Features Button" and select Uninstall. In the "Confirm Device Uninstall" dialog box, click OK.
Shutdown
Disconnect AC
Insert battery
Connect AC
Startup
Hope this can help others.
Microsoft Windows 7 Home Premium 64-bit 7601 ...AMD Phenom(tm) II X4 965 Processor8.0 GBNVIDIA GeForce GTX 560 Ti
ASUSTeK Computer INC. M4A785-M
8.0 GB
(1) NVIDIA High Definition Audio (2) NVIDIA High Definitio
Samsung SyncMaster T220G
1680 x 1050 x 32 bits (4294967296 colors) @ 59 Hz
WDC WD7500AADS-00M2B0
650 Watt
Cooler Master HAF XM
Air
CompUSA SK-6200
Logitech M-510
Comcast
Firefox 27.0 IE 11
Belkin Hub To Go F5U706
Disconnect AC
Shutdown
Remove battery
Connect AC
Startup
Open Device Manager
Shutdown
Disconnect AC
Insert battery
Connect AC
Startup
This method may help, but I would recommend my method first. Getting into the devices and reconfiguring them should not be the very first step you take.
N/A
Biostar A78DEA2T
Radeon HD5770
WD5000AAKX
NZXT Full Chassis
