Need help with audio display
iSasquatchh
4:36 PM
I use an HP dv7 model laptop and when I turn the volume up or down, a little audio meter pops up to show me the current sound level. My problem is, when gaming it will minimize the game and often times crash it.
Does anyone know of a way to disable it from popping up?
Thanks! :D
HP Pavilion dv7
HP's software - look for a control panel to disable the option, or uninstall the utility.
Sony Vaio Z46GDU
Windows 7 Ultimate x86-64
[email protected] 1066MHz FSB
Sony branded
6GB DDR3 1066MHz
9300M GS 256MB Dedicated (Speed) + Intel4500MHD (Stamina)
13.1' WXGA
1600x900
320GB 7200RPM w/ 16MB cache
1MB/s
I still can't seem to find out how to do this...
Do you have any more details for me?
HP Pavilion dv7
Look in the control panel for anything HP, then type its name into the start menu and press enter. Configure.
Sony Vaio Z46GDU
Sony branded
6GB DDR3 1066MHz
13.1' WXGA
1600x900
1MB/s
A down and dirty method.
Right click on the task bar, select "Start Task Manager".
Go to the Processes tab.
Look for any HP related processes, you will probably find more than one... pick the most likely, unless an obvious choice is apparent you may have to go one at a time. Choose one and select the "End Process" button. Check after each process you stop and see if the volume pop-up is gone.
The problem is... it could be under a different name as part of the audio device software.
As Frostmourne posted... there may be an HP or audio configuration utility lurking around.
If you do find process that's causing the pop-up, there's a couple of methods to prevent it form loading at statup.
Ap
p.s. If you deselect the "Show Processes From All Users" checkbox there might be more HP background processes visible.
Assembled in my workshop
Windows 7 Home Premium
Intel Core 2 Duo @ 3.00gHz
Gigabyte GA-P35-S3G
ATI Radeon HD 2600 XT
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
Ap
Hey thanks a lot! The first process I ended just happened to be the right one.
It's called "audiodg.exe" for future reference.
HP Pavilion dv7
Audiodg is part of the Windows 7 audio and effects processing engine for Windows 7, I don't think audio/sound will work without it.
Perhaps that's why you no longer see the pop-up! :sarc:
So, that's probably not going to be a permanent fix as it should reappear when you start to play audio.
Ap
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
