DoeZ
- Local time
- 9:41 AM
- Messages
- 308
First let me apologize now because I am in no way shape or form a computer geek nor do I pretend to be. So I ask that you have some patience with me in the hopes I can get my laptop up and running again.
I have a Toshiba Satellite L455-S5975 I'm currently running Windows 7 Home Premium 32-bit and as I mentioned above my Network Adapter is Realtek RTL8187B Wireless 802.11b g 54Mbps USB 2.0 Network Adapter. Hope that was enough info if not just ask I'll get more.
I've been having some serious problems with my connection and my speed for quite some time. Nothing has changed in the sense as our router modem or anything like that. It gets down to 2-3 bars at times and takes forever to load a page and ends up timing out. I go into the Network/Sharing Center and I run a diagnosis on my Adapter and even tho I really don't know what I'm looking at it always says There's a Problem with your Network. I can't remember how I went into it and it would always say that it was working properly but that's not the case here...I truly believe that there are missing parts to my Adapter if that's even possible. But as of right now the only way I'm even connected to the internet is thru my extender...and when I go back into the Network/Sharing Center and go to look at the full map...I get a message telling me that Windows cannot start mapping on the adapter and to make sure that your connected. I know this probably doesn't make sense but I don't know how to explain it any other way. How do I fix this adapter or uninstall it and install a newer updated one. I'd appreciate any help with this as I need to get this up and running again.
DoeZ
DoeZ
Windows7 Home Premium 32-bit SP-1Intel(R) Celeron(R) CPU 900 @ 2.20GHz2.00 GB USABLE 1.87 GB(1) Mobile Intel(R) 4 Series Express Chipset ...
- Computer type
- PC/Desktop
- Toshiba HP
- Windows7 Home Premium 32-bit SP-1
- Intel(R) Celeron(R) CPU 900 @ 2.20GHz
- Motherboard
- TOSHIBA NBWAA
- 2.00 GB USABLE 1.87 GB
- Graphics Card(s)
- (1) Mobile Intel(R) 4 Series Express Chipset Family (2) Mo
- Sound Card
- Realtek High Definition Audio
- Hard Drives
- TOSHIBA MK2555GSX
- Antivirus
- Panda Free Antivirus
- Browser
- I'm a new FireFox Browser user~
- Other Info
- Do Not Mess With Your Computer~
Unless You Know What You're Doing~
Unlike Me~I Had No Clue At All~I Thought I Did~
