Need help with my Realtek RTL8187B Wireless Network Adapter
Windows7 Home Premium 32-bit SP-1Intel(R) Celeron(R) CPU 900 @ 2.20GHz2.00 GB USABLE 1.87 GB(1) Mobile Intel(R) 4 Series Express Chipset ...
Toshiba HP
TOSHIBA NBWAA
(1) Mobile Intel(R) 4 Series Express Chipset Family (2) Mo
TOSHIBA MK2555GSX
Panda Free Antivirus
I'm a new FireFox Browser user~
Do Not Mess With Your Computer~
Unless You Know What You're Doing~
Unlike Me~I Had No Clue At All~I Thought I Did~
Now i think we are getting to the cause of the problem .. What is the Model Number of your Computer ?
windows 7 home 64bitINTEL-CORE I716GB
W530-3630QM1
INTEL-CORE I7
16GB
750GB
I'm gonna assume your talking about my laptop that I'm on now that is having these issues? My laptop is a Toshiba Satellite L455-S5975...you can look in my specs for anything else I believe...other than that new Network Adapter I downloaded last week.
Toshiba HP
TOSHIBA NBWAA
TOSHIBA MK2555GSX
Okay brb
W530-3630QM1
INTEL-CORE I7
16GB
750GB
Toshiba HP
TOSHIBA NBWAA
TOSHIBA MK2555GSX
Do your Function Keys work ? ...
W530-3630QM1
INTEL-CORE I7
16GB
750GB
You mean my F1 F2 and so on? I never use them so I'm not sure but I would think so...but again not sure because I don't use them :/
Toshiba HP
TOSHIBA NBWAA
TOSHIBA MK2555GSX
Press F8 does that Enable the Wireless ? ...
W530-3630QM1
INTEL-CORE I7
16GB
750GB
Toshiba HP
TOSHIBA NBWAA
TOSHIBA MK2555GSX
Go into Network and Sharing Center is there any change there ?
W530-3630QM1
INTEL-CORE I7
16GB
750GB
Negative...looked in a few of the spots and it's still the same :(
Toshiba HP
TOSHIBA NBWAA
TOSHIBA MK2555GSX
When you pressed the F8 Key is there a LED light come on it will be the first light on the left ...
W530-3630QM1
INTEL-CORE I7
16GB
750GB
No light at all
Toshiba HP
TOSHIBA NBWAA
TOSHIBA MK2555GSX
Press the Fn Key and some of the Function Keys at the top of the Keyboard they will be the F1 etc .. To see if any of the Function Keys are working ...
W530-3630QM1
INTEL-CORE I7
16GB
750GB
Ok when I pushed the FN key with any of the F1 or whatever keys there was a light that lit up by the number 8...and when I pushed the FN key with the F3 or 4 not sure which one...it put my laptop to sleep...screen went black and had to move my mouse to wake it up and then click my photo to open it up again. So then I clicked the FN with the F8 key and nothing changed in the Network and Sharing screen...
Toshiba HP
TOSHIBA NBWAA
TOSHIBA MK2555GSX
The LED light did not come on then ? ...
W530-3630QM1
INTEL-CORE I7
16GB
750GB
Toshiba HP
TOSHIBA NBWAA
TOSHIBA MK2555GSX
The problem has to be a Setting in your Router .. As we have ruled out every thing else .. If it is ok with you i will look at your Router Settings tomorrow and hopefully resolve the issue ... As it is getting late here near 1am and have an other start tomorrow ...
W530-3630QM1
INTEL-CORE I7
16GB
750GB
No problem at all. I was just wondering if it could be my Network adapter? Maybe it's missing stuff? Like when I look at others I see so much more than what mine says...if that makes sense lol...
Toshiba HP
TOSHIBA NBWAA
TOSHIBA MK2555GSX
