Hello all,
I hope you could help me with my problem.
Recently, I got problem with my PC, just all of a sudden, it stopped booting and later on the HDD got wiped and I have no saved data. So I reinstalled using USB, before I was running Windows XP, but I prefer to install Windows 7. The thing is, I don't have sound anymore.
Here's everything you need, this is my DxDiag.txt file
I don't have Sounds, Video and Game Controller tab in Device Manager.
In my previous OS, I was using SoundMax Audio.
I hope you could provide me exact solutions for this.
Thank you in advance <3
System Information
Operating System: Windows 7 Professional 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
Language: English (Regional Setting: English)
System Manufacturer: AWARD_
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Sempron(tm) Processor 2800+, ~1.6GHz
Memory: 2048MB RAM
Available OS Memory: 2046MB RAM
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Notes
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 25.9 GB
Total Space: 40.0 GB
File System: NTFS
Model: Maxtor 6Y080L0 ATA Device
Drive: D:
Free Space: 33.1 GB
Total Space: 38.2 GB
File System: NTFS
System Devices
Name: SiS 900-Based PCI Fast Ethernet Adapter
Device ID: PCI\VEN_1039&DEV_0900&SUBSYS_0C92105B&REV_91\3&2B8E0B4B&0&20
Driver: C:\Windows\system32\DRIVERS\sisnic.sys, 2.00.1039.1210 (English), 7/13/2006 18:32:54, 40840 bytes
Name: ATI Radeon 9600 / X1050 Series Secondary
Device ID: PCI\VEN_1002&DEV_4172&SUBSYS_169118BC&REV_00\4&330C319E&0&0108
Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.0882 (English), 2/11/2010 15:42:22, 4450816 bytes
Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0018 (English), 2/11/2010 12:34:44, 53248 bytes
Driver: C:\Windows\system32\atiumdag.dll, 8.14.0010.0647 (English), 2/11/2010 13:17:14, 3839488 bytes
Driver: C:\Windows\system32\atiumdva.dll, 7.14.0010.0218 (English), 2/11/2010 13:00:38, 4946432 bytes
Driver: C:\Windows\system32\atitmmxx.dll, 6.14.0011.0021 (English), 2/11/2010 13:30:38, 159744 bytes
Driver: C:\Windows\system32\atiicdxx.dat, 4/24/2009 06:29:16, 189051 bytes
Driver: C:\Windows\system32\amdpcom32.dll, 7.14.0010.0023 (English), 2/11/2010 12:49:00, 51712 bytes
Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1032 (English), 2/11/2010 12:48:28, 135168 bytes
Driver: C:\Windows\system32\atiumdva.cap, 2/11/2010 13:00:10, 152496 bytes
Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1001 (English), 2/11/2010 13:29:58, 12288 bytes
Driver: C:\Windows\system32\Ati2evxx.exe, 6.14.0010.4222 (English), 2/11/2010 13:28:32, 733184 bytes
Driver: C:\Windows\system32\Ati2evxx.dll, 6.14.0010.4178 (English), 2/11/2010 13:29:38, 278528 bytes
Driver: C:\Windows\system32\atipdlxx.dll, 6.14.0010.2550 (English), 2/11/2010 13:30:20, 348160 bytes
Driver: C:\Windows\system32\Oemdspif.dll, 6.15.0006.0004 (English), 2/11/2010 13:30:06, 274432 bytes
Driver: C:\Windows\system32\ati2edxx.dll, 6.14.0010.2514 (English), 2/11/2010 13:29:50, 43520 bytes
Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.3694.0978 (English), 2/11/2010 13:32:36, 442368 bytes
Driver: C:\Windows\system32\atioglxx.dll, 6.14.0010.8545 (English), 2/11/2010 12:58:04, 11513856 bytes
Driver: C:\Windows\system32\aticaldd.dll, 6.14.0010.0227 (English), 2/11/2010 12:42:40, 3235840 bytes
Driver: C:\Windows\system32\aticalrt.dll, 6.14.0010.0227 (English), 2/11/2010 12:43:56, 53248 bytes
Driver: C:\Windows\system32\aticalcl.dll, 6.14.0010.0227 (English), 2/11/2010 12:43:44, 53248 bytes
Driver: C:\Windows\system32\atibrtmon.exe, 2.00.0000.0000 (English), 10/22/2008 01:51:42, 118784 bytes
Driver: C:\Windows\atiogl.xml, 4/17/2009 00:19:48, 15577 bytes
Name: SiS760 Host CPU Bridge
Device ID: PCI\VEN_1039&DEV_0760&SUBSYS_0C92105B&REV_03\3&2B8E0B4B&0&00
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4152&SUBSYS_169018BC&REV_00\4&330C319E&0&0008
Name: SiS 180 RAID Controller
Device ID: PCI\VEN_1039&DEV_0180&SUBSYS_0C92105B&REV_01\3&2B8E0B4B&0&28
Driver: C:\Windows\system32\DRIVERS\sisraid2.sys, 5.01.1039.2600 (English), 7/14/2009 09:19:04, 40016 bytes
Name: SiS 7001 PCI to USB Open Host Controller
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0C92105B&REV_0F\3&2B8E0B4B&0&1A
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7601.17586 (English), 3/25/2011 10:57:58, 20480 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 10:58:07, 284672 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 10:58:37, 258560 bytes
Name: SIS Processor to AGP Controller
Device ID: PCI\VEN_1039&DEV_0002&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&08
Driver: C:\Windows\system32\DRIVERS\GAGP30KX.SYS, 6.01.7600.16385 (English), 7/14/2009 09:20:28, 57936 bytes
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0C92105B&REV_0F\3&2B8E0B4B&0&19
Name: AMD Miscellaneous Configuration
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C3
Driver: n/a
Device ID: PCI\VEN_1039&DEV_7001&SUBSYS_0C92105B&REV_0F\3&2B8E0B4B&0&18
Name: AMD DRAM and HyperTransport(tm) Trace Mode Configuration
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C2
Driver: n/a
Name: SiS PCI IDE Controller
Device ID: PCI\VEN_1039&DEV_5513&SUBSYS_0C92105B&REV_01\3&2B8E0B4B&0&15
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/14/2009 09:20:45, 12368 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 09:19:03, 42560 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 09:26:15, 21584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/21/2010 05:29:03, 132992 bytes
Name: AMD Address Map Configuration
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C1
Driver: n/a
Name: SiS964 PCI to LPC Bridge
Device ID: PCI\VEN_1039&DEV_0964&SUBSYS_00000000&REV_36\3&2B8E0B4B&0&10
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 09:20:43, 13888 bytes
Name: AMD HyperTransport(tm) Configuration
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2B8E0B4B&0&C0
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
ATI Ticker,0x00200000,0,1,Ticker.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.16426
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
Xvid MPEG-4 Video Decoder,0x00800002,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft Windows 7 Professional 32-bit 7601 ...AMD Sempron(tm) Processor 2800+2.00 GB(1) ATI Radeon 9600 / X1050 Series (2) ATI Ra...
- Computer type
- PC/Desktop
- AWARD_ , awardacpi
- Microsoft Windows 7 Professional 32-bit 7601 Multiprocessor Free Service Pack 1
- AMD Sempron(tm) Processor 2800+
- Motherboard
- WinFast 760GXK8MC
- 2.00 GB
- Graphics Card(s)
- (1) ATI Radeon 9600 / X1050 Series (2) ATI Radeon 9600 / X
- Hard Drives
- Maxtor 80gb
- Antivirus
- ESET NOD 32
- Browser
- Google chrome
