aiizawa
The realtek audio managers shows that the front two inputs, front mic and headphones, are always plugged in when there is nothing in them at all. When I plug in my speakers to the back green input for sound it inputs both the green one, front speakers out, and the blue input, line in.
Now I get no sound when I set it to HD audio but I get a little sound when its set to ac97. Also there is a constant static ringing sound going on. When the computer is first turned on the speakers do a very large pop, then start winding up getting loader and loader and pops again. Then it just sits with static. This happened when I turned my computer back on.
I tested the speakers and they work just find on other devices so its not the speakers.
How the heck does this happen and how does one fix this?
Thank you guys.
Thank you guys.
Windows 7 Home Premium 64 bitAMD PHenom II X4 965Broken
- Computer type
- PC/Desktop
- Custom
- Windows 7 Home Premium 64 bit
- AMD PHenom II X4 965
- Motherboard
- Asus M4A89GTD-Pro
- Graphics Card(s)
- Broken
- Screen Resolution
- 1920 X 1080
- Internet Speed
- 30 Mbit down 10 Mbits up
- Antivirus
- Bitdefender
- Browser
- Chrome
