Solved Not Reading HDs after power surge/loss
WartHog
Call me Beau
Pro User
1:06 PM
Louisville, KY
Greetings,
Sometime during the day while I was @ work here was either a power surge or loss of power to my home yesterday. I think it was a loss of power. Now my computer is not able to start Windows. When I do the initial boot up it looks as though it is not finding my hard drives. I tired running the startup repair and I also tried restring to a previsous restore point. No luck so far. Any suggestions?
Thanks. :)
Windows 7 Ultimate x64 SP1AMD Phenom II X4, 945, Quad Core, 3.0 GHz8GB G.Skill PI Black PC2 6400 * 4-4-4-12 @1.9vNVIDIA 512MB 9600GT
"WartHog Wonder"
Gigabyte MA785GM-US2H
NVIDIA 512MB 9600GT
Realtek ALC889A Chipset (onboard)
2 x 22" Hans-G LCD
650GB 7200RPM WD Caviar Black
OCZ 700w GameXstream
Cooler Master CM 690 Midtower
Xigmatek Gaia SD1283 CPU Cooler, Assorted 120mm case fans
Dell SK-8115
Microsoft Comfort Optical Mouse 3000
Liteon iHAS 424-98B 24x DVD/CD Writer
Try clearing the CMOS.
Windows 7 Home Premium x64Intel 2500k @4.5ghz 66deg max P95/IBT8 Gigs Patriot Viper 2 Extreme @1600EVGA GTX 580 3 GIG 35degrees idle
Home Made
Gigabyte Z68A-D3-B3
Nvidia HD audio via HDMI to 7.1 Receiver
32" Olevia hdtv
1080p
64gig SSD(OS/Apps)
250gig (Files and Dox)
1tb (imaging and backup)
Corsair vx550w
Thermaltake V3 black
CM 212+(push n pull) 4 case fans
Logitech wireless Combo, G13
G300
40mps
Two others up and running; C2D E5200/MSI G41M-P26/Corsair XMS3 8gb/GTS 250 1gb and C2D E8200/xFx 750sli/8gb Corsair Dominator/2x EVGA 550ti
Working on; i2600 Build...
HP DV6
@Work I use a Lenovo 5536B8U + Lenovo U300s
Thanks James. I tried it, but it did not work. Any other suggestions? I'm open to anything.
"WartHog Wonder"
NVIDIA 512MB 9600GT
2 x 22" Hans-G LCD
Dell SK-8115
Are you able to test the HDDs on another PC?
Home Made
Gigabyte Z68A-D3-B3
32" Olevia hdtv
1080p
64gig SSD(OS/Apps)
Corsair vx550w
G300
40mps
HP DV6
I'm not. However, I was talking to Ted (my Brother - Barefoot Kid), and he was walking me through some different things. We figured out my 2nd HD is no reading. I've go Windows up now. Gonna do a complete backup and then unplug that 2nd HD and see what's up.
James, I REALLY appreciate you sticking with me! I've been working some long hours (just finished day 6 of a 7-day stretch!!!) and having to ck the thread using my wife's lappy.
Admins: I'd like to keep this thread open for a couple more days just in case I need to revisit. Hope that's ok.
"WartHog Wonder"
NVIDIA 512MB 9600GT
2 x 22" Hans-G LCD
Dell SK-8115
Hi WartHog,
If you boot from a Windows 7 installation DVD, and then at the Language screen hold SHIFT+F10 to enter a cmd window, can you try this command lines:
diskpart <enter>
list disk <enter>
Is that disk listed?
Regards,
Golden
Golden Mk. I.4
EVGA NVidia GTX 560 1024MB
Realtek Integrated
1920*1080 and 1920*1080
1*Samsung 840 EVO 120GB SSD;
1*OCZ Vertex 2 60GB SSD;
1*Samsung F1 SpinPoint 1TB;
Logitech G110
Logitech MX518
Hi WartHog,
diskpart <enter>
list disk <enter>
Regards,
Golden
It's listed, but does not show any size to it.
"WartHog Wonder"
NVIDIA 512MB 9600GT
2 x 22" Hans-G LCD
Dell SK-8115
Mmm. Ok, can you try a :
list volume <enter>
Does the output show any information under the titles Fs, Type, Size, Status?
Regards,
Golden
Golden Mk. I.4
Realtek Integrated
Logitech G110
Logitech MX518
In computer mgmt it says not initialized.
"WartHog Wonder"
NVIDIA 512MB 9600GT
2 x 22" Hans-G LCD
Dell SK-8115
Ouch. OK, I speak under correction, but my understanding is that if you do initialise it you lose the existing information on the disk.
Was this a Windows disk, data disk, or combination thereof? Do you want to try and recover data from it?
Regards,
Golden
Golden Mk. I.4
Realtek Integrated
Logitech G110
Logitech MX518
I don't think I had anything on there that hurt me to lose. I think it is the disk I was using to run Acronis backup. Go figure huh? :confused:
"WartHog Wonder"
NVIDIA 512MB 9600GT
2 x 22" Hans-G LCD
Dell SK-8115
OK. So apart from that, your system is good right?
If that is the case, just initialise the disk as normal and lets see what can be read from it.
Regards,
Golden
Golden Mk. I.4
Realtek Integrated
Logitech G110
Logitech MX518
Won't initialize. It says I/O error.
"WartHog Wonder"
NVIDIA 512MB 9600GT
2 x 22" Hans-G LCD
Dell SK-8115
Mmm.
Can you select the disk using diskpart? From an elevated cmd window try the following:
diskpart <enter>
list disk <enter>
lets assume it shows as disk number 1
select disk 1 <enter>
attribute disk <enter>
Does it list any disk attributes?
Regards,
Golden
Golden Mk. I.4
Realtek Integrated
Logitech G110
Logitech MX518
Sorry, but not sure how to get to an elevated cmd window.
"WartHog Wonder"
NVIDIA 512MB 9600GT
2 x 22" Hans-G LCD
Dell SK-8115
Click the Start Orb, then in the search box, type cmd.
Right-click on cmd in the list, then choose Run as administrator.
Regards,
Golden
Golden Mk. I.4
Realtek Integrated
Logitech G110
Logitech MX518
"WartHog Wonder"
NVIDIA 512MB 9600GT
2 x 22" Hans-G LCD
Dell SK-8115
Ok, I took out the bad HD, removed the SATA cable and blew my rig out. This thing is running good once again! I'm going to mark this solved. Thanks again for all the help!
"WartHog Wonder"
NVIDIA 512MB 9600GT
2 x 22" Hans-G LCD
Dell SK-8115
If that disk is still under warranty, it may be worthwhile downloading the manufacturer's diagnostics app and running it on the drive to see what error code is returned. Could be worth a new drive!
Thanks for the thoughts. :) However, that disk is @ least 3-4 years old.
"WartHog Wonder"
NVIDIA 512MB 9600GT
2 x 22" Hans-G LCD
Dell SK-8115
