Other solutions for Realtek HD audio problem?
okieuser
3:40 AM
I've tried Googling this and posting in a Realtek-specific forum. This computer at work has begun to distort all the audio I hear via ear buds. Crackling, snapping, buzzing; I've never heard this type of distortion anywhere else. Since it developed over time, I thought it might have been the last one or two driver updates. The Realtek forum replies had the same idea. They agreed I needed to roll back to at least 2.22. I did, and it worked for while. But then it started distorting again. I didn't think that was possible, unless the driver somehow updated itself. (I do all driver changes myself.) I've checked, and it's still the 2.22 driver.
So now I'm looking for an alternate solution? Audio and system specs follow ...
Sound control panel: Any and all "enhancement" features disabled, audio output volume set at 20%, format 16-bit 44100 Hz (CD quality). Physical connections to ear buds etc check out fine.
System: Dell A11 computer w/0N826N moboard, 6GB RAM, Windows 7 64-bit.
Win 7 Pro 64bit
Intel Pentium E5400
0N826N
6GB
NVIDIA GeForce 7300 GT
Samsung 250GB SSD
What is a "Dell A11"? The BIOS version? According to the motherboard part number it could be an Inspiron 525 or an Insprion 525S??
Sound popping and crackling is a common problem with Vista/Win7/Win 8 systems. Unfortunately there is not a "one fix" for the problem. Audio and Video drivers are one issue. Wi-Fi can be another. Another application, etc.
In most cases, Dell's need Dell supplied sound drivers for proper operation. Non-Dell, even direct RealTek, may not work correctly.
The Inspiron 525 is an older Dell that could have come with XP or Vista. As noted, the Dell sound driver would be my first suggestion.
My Own Build
Intel i7 6700K
ASUS ROG Maximus VIII Hero
16GB Corsair Dominator
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
2 TB drive for backup
EVGA Supernova 750G2
BeQuiet Silent Base 600
Deepcool Captain 120EX
Microsoft Wireless 2000
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Thank you Fireberd for the Dell driver tip. I'll try that ASAP.
Sorry about "A11" problem. The utility I used to identify my system coughed that up, which in fact turns out to be the BIOS. The tower itself just says Dell. None of the labels or stickers applied by our IT staff provide a model name.
Win 7 Pro 64bit
Intel Pentium E5400
0N826N
6GB
Samsung 250GB SSD
Searched the web and found a way to identify it with a special URL.
Inspiron 545
Service Tag: D197PL1
Win 7 Pro 64bit
Intel Pentium E5400
0N826N
6GB
Samsung 250GB SSD
OK, it is an Inspiron 545.
Here is the Dell downloads. Install the Dell RealTek driver and see if it helps. There is also an A12 BIOS update but it doesn't look like it does much according to the listing.
Drivers & Downloads | Dell US
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Much, much better with the Dell/Realtek driver! There are still oddities I've noticed. Occasionally, during a song I'll hear a brief BZZZT sound. Not loud but definitely not in the original songs. Also, even with this new driver, I can no longer use non-standard settings in WinAmp like mono or the equalizer without most of the distortion coming back. I'm very surprised that Vista, Win7 and Win8 have all had audio problems. I would think simply handling an audio signal would not be the most complex task the OS handles. Thanks for your help.
Win 7 Pro 64bit
Intel Pentium E5400
0N826N
6GB
Samsung 250GB SSD
I did support on the Dell forums for 10 years. Dell tends to have custom motherboard implementations and the reason the Dell sound drivers are needed. Some other vendors may not have the customization that Dell does.
An example of Dell customization. I had a Dimension E510 desktop. The motherboard was made by Foxconn for Dell and not equivalent to any other Foxconn. The Intel chipset on the motherboard, according to Intel, could accept up to a D960 CPU. However the Dell custom implementation limited it to mximum of a D945 CPU. If a D960 was installed it would not boot.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
I had no idea that companies like Dell have influence that goes that deep into how "their" computers behave. I had always assumed they were simply assembling PCs likely to appeal to various business and consumer markets.
Win 7 Pro 64bit
Intel Pentium E5400
0N826N
6GB
Samsung 250GB SSD
Some of the current production PC's are more standard than the older ones.
My Own Build
Intel i7 6700K
Intel CPU Graphics
RealTek
27" Dell S2719dgf
2560X1440
Microsoft wireless
100 MB/sec (Cable)
Edge/Firefox
Was another pair of earbuds or headphones tried on this system?
Self Built Custom
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was required!
MSI 890FXA-GD70
8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo nonOC max rec'd]
Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Frozr model
Realtek High Definition Audio (onboard mobo, ALC-889 chip)
2 WS LED Monitors: One LG One Viewsonic
1920 by 1080
SSD for OS: Samsung 840 Pro
SSD for VM and utilities: Adata SX900
7200 RPM SATA HDs for the rest: Hitachi and Seagate
Corsair TX850 - 850W max, in service since August 2010.
Thermaltake Armor A90
Thermaltake Spin Q CPU Cooler, in service since August 2010
Logitech G11
Logitech M310 Wireless
100 Megabit broadband supposedly upgraded from 50 (Cable)
Bitdefender Internet Security 2014 suite
Pale Moon 64-bit main, also IceDragon, Opera, and Maxthon.
CompTIA A+ certified (220-800 series) in July 2013.
Brief note for audiophiles with similar problems:
I reduced some of the lingering distortion by finding my music player's process name in the Task Manager and raising the thread priority to High.
Win 7 Pro 64bit
Intel Pentium E5400
0N826N
6GB
Samsung 250GB SSD
Faladu, no other earbuds or headphones were tied to the system. All other audio jacks are empty.
Win 7 Pro 64bit
Intel Pentium E5400
0N826N
6GB
Samsung 250GB SSD
