Problem Running Modio and other exe's
ipixel
2:44 PM
I am running Windows 7 Proffesional and i am trying to run a programme called modio when i double click the exe it load up for a second in my task manager (system processes) and then dissapears no error or anything just dissapears can anybody help please ?
Hallo ipixel, you might try right clicking on your installer select properties & see if there is an option to unblock.
Then right click on your installer & select Run as Administrator & see if this works
Hewlett Packard Compaq Presario CQ60-305au
Windows Seven Home Premium 32bit SP1
AMD Athlon QI46 2.1Ghz
Wistron 303c
2048 Mb DDR2 SD RAM
NVidea GE GoForce 8200M G/256mb dedicated graphics memory
MCP78S NVidea high definition
15.6" High definition Brightview Widescreen
1336x768
Toshiba MK2555GSX ATA
hi mitchell its not an installer its a stand-alone exe and there isnt an option to unlock it i have also tried running as administrator and in every compatability mode its happening even with things like 3.5 Framework from the microsoft website the exes i try to run are just appearing for a split second in my systme processes and then just dissapearing as though something is blocking them.
The only other thing i can think to do is to enable the built in Admin Account & running it from there this account will give you full permissions
I have attached a link to a tutorial that will show you how to do this.
http://www.sevenforums.com/tutorials/507-built-administrator-account-enable-disable.html?filter[2]=User Accounts
Otherwise i am at a loss Sorry :confused:
Edit; Just another thought you could try running it in Safe Mode if this works it may be one of your Security Apps not allowing it to run.
To boot into Safe Mode just repeatadly tap F8 key on start up
Wistron 303c
2048 Mb DDR2 SD RAM
1336x768
