Solved Problem with exFAT USB Flash Drive
Jalouly
2:24 AM
Hi Everyone
I have recently encountered a problem when I first bought a USB Flash Drive 128 GB.
It's exFAT Format, Whenever I Add files to it, then re-plug it in, the files become corrupted, And i will not be able to open any.
I have tried to open the files but no luck :/,
I'm Using Windows 7 Home Edition and Dell Inspiron 1520 Intel Core 2 Duo, RAM
2.5 GB
Thank you.
Windows 7 Home Edition x86
Intel Core 2 Duo
Dell Inspiron 1520 Notebook
What size are these files. And Are you "Safely removing USB device" of just unplugging.
Home Build.
Windows 7 Home Pre
Q8200 Intell 2.333
Asus P5Q3 Delux
DDR3 1333 4gig
Ati HD4870
Onboard Soundmax. 7.1
1, 20" Samsung
Good enough
Le Shark
FAN FAN FAN FAN, Thermaltake Minitype 90 with speed fan 4.
Standard, Gaming Wolfking
Cm-storm-inferno-wired-gaming-mouse
Sky Crappy upto 20meg I get a whapping 5.8mbs.
I'm safely removing it, and whatever the size of the file is. it keeps giving me errors :(
Intel Core 2 Duo
Have you looked on the site manufactures for a firmware update. Or Format it into Fat32 or NTFS
Home Build.
Windows 7 Home Pre
Q8200 Intell 2.333
Asus P5Q3 Delux
DDR3 1333 4gig
Ati HD4870
1, 20" Samsung
Good enough
Le Shark
There is no luck into formatting it into NTFS, the formatting process always fail. Please help me, I really don't want to throw the Drive Away
Intel Core 2 Duo
exFat is not supported in Windows 7. Either you reformat or you donate the stick to someone who has and old OS. Try another formatting program.
ok well I converted the Flash Drive from exFAT to FAT32. but I don't see any difference. I tired the program you gave me and still no luck :/
I got the flash drive from china, maybe it's a poor type or something ? :p
Intel Core 2 Duo
About the type it's HP 128 GB Flash Drive
Intel Core 2 Duo
exFAT is very much supported in Windows 7 so it should have been working.
It looks quite likely that the drive is bad after all. Well assuming that OTHER drives work fine in the same computer? If more than one drive doesn't work, then maybe something wrong with the USB port or cabling or something...
Scratch built
Windows 7 x64 Ultimate
i7 960
Asus P6X58D
12 Gig Corsair Dominator
Nvidia 480
Maudio Delta 44 + breakout box
Dell UltraSharp U2410 24in and Samsung 21 dual monitors
1920x1200 and 1280x1024
Primary: Intel X-25M G2 160G SSD
Secondary: Segate baracuda 1.0 TB
HDs in AHCI mode.
Corasair TX850
Cooler Master HAF
Corsair H50
Logitech G15 + N52 game pad
Logitech MX518
15kbs down 4.5kbps up
WEI 7.6
CPU & RAM 7.6
Graphics 7.9
Hard disk 7.7
ok well, other Drives works properly. However there is an update here I added a file to the Flash Drive 1.37 MB and it worked. I could read and write the file.
Intel Core 2 Duo
Try to do a full format by removing the checkmark on quick format. This will check the flash thoroughly. You can try different formats one after other. I prefer NTFS.
As you can see the exFat option in format dialog box, it is very much supported in Windows 7.
After the format copy some files and do CHKDSK on it and verify there are no errors. Then try the flash in different USB ports on your laptop and also on other computers. Do a trial and error method to isolate the problem.
Toshiba Satellite P775-S7232
MS Windows 7 Ultimate 64-bit SP1
i5-2410M 2.3GHz (2.9GHz Turbo-Boost) Sandy Bridge 32nm
Toshiba PHRAA ver. PSBY1U-00F003
4GB+4GB Samsung DDR3 PC3-10700 (1333 MHz)
Video Intel(R) HD Graphics Family, 1696MB available memory
Realtek High Definition Audio version=6.0.1.6323
17.3 " Trubrite TFT LCD, LED Backlit
1600x900 32 bit, Native support for 720P content
TOSHIBA MK6476GSXN
580.614 [GB] partitioned C: 80GB and D: 500GB with hidden recovery partitons.
Spare bay for 2nd HDD but no SATA connector :-(
Toshiba AC/DC Adapter
Notebook
Built-in Fan
Premium Raised Tile keyboard
Logitech M215 wireless mouse
Not fast enough
Built-in Harman Kardon speakers with Dolby Advanced Audio, Waves MaxxAudio® 3. HDMI, 1xUSB3+3xUSB2 ports, WebCam, Battery life 4hrs 11mins, 4GB Readyboost SDHC card, WD My Book Essential Ext HDDs 2 TB, 2x1TB, My Passport SE 1TB and WDTV 1st Gen for Multimedia playing on a Sony Wega 32" LCD.
Recent addition to my toys are Asus Transformer Pad TF300T with 32GB onboard sd card + 32GB microsd card.
Jalouly,
I'm going to tell it to you like it is.
Reformat that thing as NTFS.
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
well Reformatting it to NTFS without checking the quick format takes like 50 years to finish. I wish if i can format to NTFS :/. another strange thing happening to me is the subfolders always appear to be empty in my flash drive.
Intel Core 2 Duo
It will not take you fifty years. Start the format job and take a coffee break or a stroll. Don't stare at the monitor. Let it do its job. 128Gb flash will take some time to complete the format. This is the way to do it. ;)
TOSHIBA MK6476GSXN
Notebook
Built-in Fan
Not fast enough
I swear the progress bar is moving so slow, i feel like breaking the PC now xD. I will keep the PC on for 12 hours and see ;)
Intel Core 2 Duo
Patience is a virtue, but who wants to be virtuous?:D
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
What brand of flash drive do you have. Their has been reports of many counterfeit flash drives that just don't work.
EXAMPLE.
http://www.amazon.com/Kingston-Data...?ie=UTF8&filterBy=addOneStar&showViewpoints=0
Kingston Technology Company - Company - Memory Verification
Hi Jalouly,
I will go with Layback Bear. You probably got a fake HP 128GB Pendrive. These are available for $2 a piece.:)
128GB/64GB/32GB/16GB HP Mini USB flash drive pen drive memory stick (China Manufacturer) - Portable Storage - Computer Accessories Products
( I searched for genuine HP 128GB pendrive but couldn't get any. HP does not make any pendrives. Genuine HP pendrives with HP Logo are generally sourced from PNY and carry the PNY part no. Just about a week ago I discarded my HP pendrive's original packing. PNY)
Please do not waste your time. Return the pendrive to the vendor and get your money back.
Windows 7 Home Premium 32 bit
