Solved Realtek High Definition Audio driver problem and speaker static
BrainFreeze123
4:58 AM
Hi
I recently installed the program, Driver Sweeper, which picked up a problem with my audio driver, Realtek High Definition Audio after my speakers had been making some static sounds while playing audio. After running Driver Sweeper and cleaning the driver I restarted the computer.
When I returned to windows my driver had been uninstalled. Windows ran a troubleshooter when I clicked on the volume controls. Then it automatically installed the same driver back again. My speakers continue to make the same sounds after this and if I run Driver Sweeper again the same thing happens again. I'm not sure whether I should install a different audio driver or something.
Thanks for the help
Brainfreeze123
Microsoft Windows 7 Home Premium 32-bit 7601 Multiprocessor Free Service Pack 1
Intel(R) Core(TM) i3 CPU 530 @ 2.93GHz
ASUSTeK Computer INC. P7H55-M
4.00 GB
Intel(R) HD Graphics
(1) Realtek High Definition Audio (2) High Definition Audi
LG
1360 x 768 x 32 bits (4294967296 colors) @ 60 Hz
WDC WD5000AAKS-007AA0 ATA Device
Zixa
Eset
Hi Brian Go to the Asus site and download the latest driver for your sound card using such programs like Driver Sweeper cause more problems than they cure in my opinion .
W530-3630QM1
windows 7 home 64bit
INTEL-CORE I7
16GB
750GB
Haha. That program was actually recommended by another windows 7 helper. Oh well. Will check it out, thanks.
4.00 GB
LG
Zixa
Eset
The Manufacture always tweaks their Drivers that's why its best to download from them
W530-3630QM1
INTEL-CORE I7
16GB
750GB
The correct driver was in fact Realtek as specified on the assus website. I uninstalled Driver Sweeper as I think you're right about it being harmful.
4.00 GB
LG
Zixa
Eset
Are you still having problems
W530-3630QM1
INTEL-CORE I7
16GB
750GB
I'm going to wait and see. So far the speakers seem fine.
4.00 GB
LG
Zixa
Eset
That is good news hope it stays that way :)
W530-3630QM1
INTEL-CORE I7
16GB
750GB
