Solved SanDisk Cruzer Flash Drive-AUTOPLAY problem
Put the top one back to disabled. Leave others at default. Otherwise Autoplay may not work for your CD player.
I noticed my light didn't go off either just now. As long as it tells you it is safe.
My Memorex light goes off so I thought they all did.
Sorry it isn't working right on the Autorun.
I'm out of options.
Maybe someone else will come up with something.
Check back later on this thread.
Maybe???
Mike
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Samsung 830 120GB SSD
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
Looks like it might be a PlugnPlay issue, since it thinks it's a CD player might be a IDE/AHCI issue.
What is the BIOS setting for SATA?
IDE, AHCI or RAID?
It seems to be acting like an external HDD, if in IDE mode will only see the memory stick when it's plugged in before booting. It won't like it if you disconnect it while the computer is still running. You might get errors if you unplug it without shutting down the computer.
If your SATA setting is IDE and you want to change it to AHCI this tutorial will show you how to do this without re-installing your OS.
Another way to get around this is the handy HotSwap app.
You can try the Hot Swap app, it might work for you in IDE mode, haven't tried it myself as I found it after I changed to AHCI mode.
Hot Swap
It does the same thing as you can remove device from Device Manager but it provides much friendly user interface as you remove the removable device from the "Safely Remove Hardware" icon in the notification area.
I've used this for a couple of years, it will stay in the same place as the MS 'Safely Remove Hardware' does, actually looks and acts just like it but, will let you select any device in your system including your main HDD.
It will not load/install on your computer as a running program, you can open it when needed or set it as a startup task, then it will run after login.
A BIOS update on my laptop enabled the built in plugnPlay to work correctly, so didn't need HotSwap on it any more but, still use it on two desktops.
Let us know if this helps.
Windows 7 Ult x64 - SP1/ Windows 8 Pro x64Intel Core i5-3570K 4.6GHz8GB (2X4GB) DDR3 1600 Corsair Vengeance CL8 1.5vSapphire HD 7770 Vapor-X OC 1GB DDR5
76~2.0
Gigabyte GA-Z77X UD3H, f18
Onboard VIA VT2021
22" LCD Dell
Samsung 840Pro 128GB SSD,
Corsair HX650W
Cooler Master Storm Scout
Logitech Wave
CM Sentinel
Dismal
Opera Next
Desktop: eSATA ports,
External WD USB 500GB
hi dave,
i use AHCI
the utility is nice thanks, but does not help me.
Mike,
1-did you update or something on your sandisk drivers /U3 ?
2-under HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
*i have default value for NoDriveTypeAutoRun is 0x91 (145) is it the same for you?
*DO you have another key there "NoDriveAutoRun "(i do not have just read a tweak about it)
I tried to reinstall sandisk drivers but no good.
cant get autoplay menu for the sandisk...
98SE/XP/windows7 32bit/ win10
Problem solved :)
after some reading in sandisk forums i found out some gadgets can cause this problem.the fault gadget belongs
to cyberlink power2go express. after remove it from MSCONFIG- sandisk autoplay menus are open!
thank all the friends trying to help me through (Dear Mike)
thats an interesting soloution, thanks for posting results i have power2go on this laptop,so any issues i shall know why .although i have a sandisk cruzer slice flash and it shows autoplay fine.
Hewlett packard/p6512uk
FOXCONN 2AA9
2x2gb
ati radeon HD 5450
samsung lcd tv 32"
1360x 768
air!
wireless hp
wireless Hp,optical
1.10mb/s
that's how the fault gadget looks like on the desktop
Your welcome.
Though I didn't get it working.
:DYou now know where all the Windows Autorun buttons, check boxes and default settings are!!!;)
Take care.
Mike
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
