Strangest Problem with Wireless Speed
trevorjames
3:01 AM
Hey there, this might be a lengthy first post but I hope you'll be able to give me some guidance. I apologize in advance!
I recently had a Realtek RTL8190 PCI card for my wireless internet. Not reaching my regular speed as well as having consistent interrupts (30mbps) I decided to reseat, reinstall drivers as well as Windows 7 to no avail. In fact, it ended up a lot worse than it was at the start so I ended up trashing the thing. In replacement I went out and bought a Cisco AM10 Wireless Adapter since my Router is of the same brand. I was met with no more interruptions but the same download speed as I was getting before which was constantly fluctuating in between 10-20mbps (according to speedtest and videotron) Frustrated I ended up reinstalling the OS again thinking it might be conflicting software, registry entries or other drivers. Same problem.
I've tested the connection on 3 different laptops. Two running Windows 7 and the other Mac OS X. They're all easily capable of hitting 30mbps instantly in the same room as my new USB adapter.
I've run out of things to try and am looking for anything to try and solve the issue.
Sorry for the length!
Windows 7 Home Premium x64Phenom II 1055T4GB CORSAIR2x 5850 OC'D
Myself
Phenom II 1055T
Asus Crosshair IV Formula
4GB CORSAIR
2x 5850 OC'D
Onboard Creative X-Fi
Dell 24"
WD 620GB
Silverstone 750W
CM HAF X
Air
Windows 7 x64Intel i7 2600kG.skill Ripjaw 16gigs @ 1866Nvidia gtx580 (evga)
Insane hobo technologies. ;-)
Windows 7 x64
Intel i7 2600k
Asrock z68 extreme 4 gen 3
Integrated HD audio + hdmi
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
1 western digital 1tb (eSATA)
1 Seagate 1tb (eSATA)
Zalmann
Microsoft wireless 3000 (v2)
I've disabled IPV6 as well as the standard Windows Firewall that is included with a fresh installation of Windows 7. No difference unfortunately.
Myself
Phenom II 1055T
4GB CORSAIR
2x 5850 OC'D
Dell 24"
WD 620GB
Silverstone 750W
CM HAF X
Air
Well there only seems to be one version of the driver software provided for that device
Cisco Connector
Barring a signal strength issue I'm curious if the software and drivers associated with the previous wireless device have been properly removed, as you are suffering an identical problem even though you have now replaced the physical hardware.
Windows 7 x64
Intel i7 2600k
1080p (1920x1080)
128 Samsung 830
256 Samsung 840
Zalmann
Indeed and that is the driver that is currently installed. The software and drivers from the older one must have been properly removed since I formatted the hard drive and put a fresh installation on it as well.
Myself
Phenom II 1055T
4GB CORSAIR
2x 5850 OC'D
Dell 24"
WD 620GB
Silverstone 750W
CM HAF X
Air
