System freezing (7 Pro 64-Bit)
The issue re-ocurred when I got my Spyware Detector software up and running. I have informed the company. They were not able to provide an immediate resolution so I uninstalled the software and everything is working normally this morning. I installed Spybot which I had on the PC of my home network (also with Windows 7). It works fine on both machines.
HP Pavillion dv2700 Notebook PC
Windows Vista
My PC was crash-free last night running two sticks of RAM (4 GB total). If it makes it through the weekend then I'll be pretty confident it was something about having all 4 stick of RAM in my PC. Then I'll have to decide if it's worth my time to figure out exactly why it doesn't like all 4 sticks at once...
-HM
Shuttle SD39P2 SFF XPC
Windows 7 Professional 64-Bit
Intel Core 2 Duo E6600 320 MB
Intel 975X + ICH7R
4 GB Crucial Ballistix
NVIDIA GeForce 8800 GTS
Realtek ALC888
Sumsung 22" LCD
Maxtor 320 GB SATA II (7200 RPM, 16MB cache, AHCI mode)
400W
Shuttle XPC
I.C.E. Technology CPU heat-pipe
IBM Model M
Razer DeathAdder
DSL
JJ, great, thanks for the feedback. You might want to search the System Security thread (or post your problem with your Spyware) for other recommended programs
HM, keep us posted. When you are done (and confirmed) I suggest you mark the thread as solved (right upper corner, report icon, state solved) since both problems will then be solved
Wally, Innc.
Windows 7 x64 finally!
AMD Athlon II X2 240
Biostar TA790GX XE
OCZ Platinum 4GB DDR2 1066 (will not work past 800MHz)
MSI R4670-MD1G Radeon HD 4670 1GB 128-bit GDDR3
ATI High Definition Audio Device Realtek ALC888
HP w19e
Western Digital Caviar Green WD5000AADS 500GB SATA
Western Digital Caviar Blue WD5000AAKS 500GB SATA
Athena Power Micro ATX 400W
HEC 6T 6T10BB Black MicroATX Mini Tower
stock
wired, many keys
HP wireless, 2 buttons, 1 wheel
DSL 2Mb (recently getting 1.65M!)
Is HM not able to find any dump files because his computer is freezing instead of BSOD crashing?
I suspect this is the case, because I got dump files when the driver for my Garmin Forerunner 205 acted up. That caused a BSOD.
-HM
Intel 975X + ICH7R
Realtek ALC888
Sumsung 22" LCD
400W
Shuttle XPC
IBM Model M
Razer DeathAdder
DSL
It looks like someone else already reported this as solved. Regardless, for everyone's info, I haven't had a crash since I removed some of my RAM. Still not sure yet why the machine doesn't like all 4 sticks in (since the two I removed was the RAM I used when I had XP, so it's unlikely it's bad), but that's an issue to deal with at some point in the future.
-HM
Intel 975X + ICH7R
Realtek ALC888
Sumsung 22" LCD
400W
Shuttle XPC
IBM Model M
Razer DeathAdder
DSL
Tks HM for the update. It weill help others.
Was XP 32 or 64 bits? 64bits seems to be more picky regarding memory.
Wally, Innc.
Biostar TA790GX XE
HP w19e
stock
wired, many keys
XP 32-bit. I never had all 4 sticks in when I was running XP, so I simply don't know what it would've done.
-HM
Intel 975X + ICH7R
Realtek ALC888
Sumsung 22" LCD
400W
Shuttle XPC
IBM Model M
Razer DeathAdder
DSL
