- Local time
- 7:19 PM
- Messages
- 248
hello win 7 forum world i have a big problem with my laptop its a TOSHIBA SATELLITE PRO L450-13R .its got windows 7 64bit running.well the problem is to do with the wifi i have unistalled it and loaded ti up a bunch of times downloaded it also from this site
Driver Downloads - Computers | Toshiba - Toshiba
i know there is a fault because the laptop sees the routter and gets a signal as i got the bars on the signal sign on the bottom right of my screen but most of the time when i open my brouser it wont even show up google but shows that i have a connection.i can get internet no problem if i connect the cable directly into the laptop.this is a great laptop other than this problem.i know this is a problem because i have tried another toshiba laptop beside mine and it seems to get internet no problem when mine dont but both pcs show that they are connected to the same router and show that same signal that they have
any of you guys come across this problem.i was thinking of buying this maybe solve the problem but dont want my usb port used up and tis big thing sticking out either.
TP-Link TL-WN823N Mini 300Mbps WiFi Wireless USB Adapter 802.11b/g/n Windows 8 | eBay
WINDOWS 7 64BIT ultimate8GB
- Computer type
- Laptop
- dell latitude e6430
- WINDOWS 7 64BIT ultimate
- 8GB
- Hard Drives
- sandisk extreme pro 480gb ssd
- Antivirus
- free avast
