transcend usb 3.0 and host controller problem
I uninstalled the original drive I had downloaded from Trandscent and downloaded and installed the driver you suggested because I didn't get a CD with the expansion card. Didn't help.
What happened when you ran the installer file? Did it complete normally? Did it fail with an error message, complaining about hardware not found?
So today I went back into computer and pushed harder on the expansion card to make sure it was seated in board. I also, which I think might of been the problem, was remove the 4 pin white connector and plug it into another white 4 pin connector. I wasn't sure which 4 pin white connectors were hot and didn't know for sure how to test and find a power supply for sure.
Anyway everything is working.
Well, that's certainly the good news we were shooting for. I suspect reseating the card and trying another power supply cable were good things to try, and they obviously produced the desired results.
However it's still not possible for the device to be working without drivers. Your screenshot of Device Manager showing the two Renesas USB 3.0 devices is perfect. So my guess is that you are now actually running the driver I pointed you to and that you ran (but said "didn't help"). While it might not seemed to have helped initially, after you re-seated the card and used a different power supply cable the just-installed drivers now actually did have proper hardware to apply themselves to.
If you right-click on the Renesas 3.0 XHCI Host Controller item in Device Manager, select Properties, and then select the Driver tab, I suspect you will now see that the driver IS installed and that it is the very Renesas 3.0.23.0 version from 8/21/2012 that I pointed you to and that you just installed.
If it's not that driver, it's still got to be some other driver... because hardware can't work without some driver installed. So what is the driver vendor, version and date, shown on the Driver tab of that device??
Also, if you go into Control Panel, Programs, and then slide down until you see the Renesas USB 3.0 driver software (which I'm sure will be there), look over on the right and you'll see the "installed date" and "version". Again, I suspect it will be today's date and version 3.0.23.0 corresponding to your installing the file I pointed you to today. So, what do you see in Control Panel?
Anyway, sounds like you've emerged victorious!! And that's what's important. Excellent.
Home-built, two systems (1) and (2)
i5-3350p 3.1Ghz/6MB-cache (1); E8400 3.0Ghz/6MB-cache (2)
ASUS P8Z77-V Pro (1); ASUS P5Q3 (2)
8GB PC3-12800 DDR3 (1); 4GB PC3-10600 DDR3 (2)
ATI HD7750 (1), (see TV cards); ATI R7 250 (2)
Realtek ALC892 HD Audio (1); Realtek ALC1200 HD Audio (2)
Eizo HD2441W LCD, Eizo S2433W (1); Eizo 24" S2433W (2)
1920x1200, 1920x1200 (1); 1920x1200 (2)
(1) 1TB SATA-II (7200RPM), 2x2TB SATA-III (7200RPM), 250GB SATA-III (10000RPM) for OS; 2x2TB external USB 3.0
(2) 320GB SATA-II (7200RPM), 750GB SATA-II (7200RPM), 150GB SATA-II (10000RPM) for OS; 2TB external USB 3.0
Nesteq ECS-6001 600W (1); Nesteq ECS-5001 500W (2)
Acousti-Case 360 (1) and (2)
Noctua NH-U12P SE2 for CPU, 2x120mm case fans (1) and (2)
IBM PS/2 (1) and (2)
Logitech MX Revolution wireless (1); Microsoft wired (2)
100mbps down / 10mbps up
Microsoft Security Essentials; Malwarebyte Anti-Malware Pro
Ceton InfiniTV 4-tuner cablecard-enabled TV card as well as Hauppauge HVR-2250 OTA/ATSC 2-tuner TV card in (1), running under Win7 WMC
Maybe I shouldn't have but I uninstalled the driver I had installed prior to you telling me were to go to get new driver. The driver you told me to download and install seemed to install fine. I think you and I got it. Thanks
Windows 7 Home Premium 32 bit
You're home free. Perfect.
Interestingly, while I was doing my own research I downloaded that driver installer file and ran it for myself on my own laptop... which does NOT have the Transcend card installed.
Remarkably, the installation process "completed normally", which is certainly strange considering the required hardware was NOT present on the machine. In another similar forum thread the chipset was not from Renesas/NEC, but was from VIA. And the installer had been written so that if the required hardware was not present an error message would be presented advising of that fact... which is good design, in my opinion.
Anyway, rather casually, this Renesas driver installer (which both you and I ran) just quietly completes "successfully", no matter whether it actually found the expected hardware or not.
So, back to your story, I'm sure that's exactly what happened. You uninstalled your first originally installed Transcend driver and then ran this Renesas driver installer (3.0.23.0), which now being installed was there dormant and waiting for the hardware it would support.
And then when you removed and re-seated the card, and connected a different power supply cable, well now the hardware finally actually WAS electrically connected and truly ready for use. So when you next booted Windows, the "new hardware detected" process launched, with the VEN_1912&DEV_0015 Hardware ID. Windows then searched its "Driver Repository" for a suitable INF to match the Hardware ID, and found the Renesas INF which you'd just installed with that Renesas driver installer.
You probably then saw "installing drivers for device...", and then "drivers installed successfully, device is now ready for use".
And bingo... you now have a pair of working USB 3.0 ports on your machine! Congratulations.
Note that even though USB 3.0 has a theoretical high speed that is maybe 5X that of regular USB 2.0, you won't likely actually achieve that in real life. For sure, the speeds you will actually get reading and writing to an external USB 3.0 drive vary significantly, depending on the underlying drive (probably SATA-III, but could be SATA-II) in the enclosure and its specifications. You can use HDTune (free version is fine) to run performance tests on the external USB 3.0/2.0 drive and compare it to the performance of the same drive when plugged into a standard USB 2.0 port.
