trying to restore system winimage 64bit to 32 bit system
Windows 7 Ultimate 32-Bit & Windows 7 Ultimat...Intel Core i7 CPU 950 @ 3.07GHzOCZ 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 160...ATI Radeon HD 5700 Series
Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
ASUS P6T DELUXE V2
OCZ 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 OCZ3X1600R2
OnBoard
WD6400AACS-00M3B0 (640GB SATA )
CORSAIR 850w
NZXT LEXA
Intel Stock Heatsink Fan
Microsoft Wireless Laser Keyboard 7000
Microsoft Wireless Laser Mouse 7000
so this is what i'll attempt:
- after the windows 7 download finishes (anothrr 5 hrs to go), i'll
- make a winimage of the current system
- use the freshly downloaded win7 home premium x64 to do a clean install & use my original prod key
- IF it works, i'll make a winimage
- then make a repair disk
- then try to do the restore i made from the old HD
wish me luck. i feel like chucking this thing out the window
thanks for your help & feel free to make more comments, i'll keep tabs on this forum
windows 7 home premium 32 bit1 gig
dell mini 10 (1012)
1 gig
You could try to do is boot off the DVD you're downloading and try to do the restore of your image .
This link will help you
:ar: http://www.sevenforums.com/tutorials/219487-clean-reinstall-factory-oem-windows-7-a.html#post1839164
Read the warning from this link http://www.sevenforums.com/tutorials/663-backup-complete-computer-create-image-backup.html
Comment from the warning :
You cannot restore a 64-bit Windows 7 backup image on a 32-bit system.
You cannot restore a 64-bit Windows 7 backup image with a 32 bit Windows 7 installation DVD or recovery partition, or the other way around.
♦ You must use the same 32-bit or 64-bit Windows 7 installation DVD or recovery partition as the backup image is.
ASUS P6T DELUXE V2
OnBoard
CORSAIR 850w
NZXT LEXA
ah, so NOT do a clean install, but try to boot from the newly downloaded dvd & try to restore. i'll try that. thanks
from what i read i need to get that downloaded file to a dvd in a special way. not just drag & drop. any advice?
dell mini 10 (1012)
1 gig
ASUS P6T DELUXE V2
OnBoard
CORSAIR 850w
NZXT LEXA
ahh, success! after the 7 hr download, i burned the iso file to dvd & as you suggested i used it to boot from & then did the system winimage restore.
thanks for your help!!
z
dell mini 10 (1012)
1 gig
You're welcome .
Remember you can't restore a 64-bit OS from a 32-bit OS . You have to use the same same bit version no matter if its a repair disk or installation disc.
ASUS P6T DELUXE V2
OnBoard
CORSAIR 850w
NZXT LEXA
