Using DFX Audio Enhancer with AIMP 2 audio player
harpua
7:03 PM
Honolulu, HI, USA
Yes, it's possible. :D AIMP can emulate Winamp plugins. For those who use the Aimp 2 audio player and would also like to use DFX Audio Enhancer (note pro version of DFX is not free), here's how to configure it.
First you have to have any version of Winamp installed.
Next install DFX, directing it to install in the main AIMP folder instead of the default Winamp folder (Note: Do not install in the "plugins" folder). DFX will then install itself in a folder called "Winamp" in the main AIMP folder.
Finally, simply copy "dsp_dfx.dll" from the Winamp plugins folder to the AIMP plugins folder. (This is why Winamp has to be installed . . . so that DFX will have the place it expects and needs to install its Winamp .dll.)
To turn DFX on in AIMP, run AIMP and open the menu and the "DSP Manager" and choose DFX from the Winamp plugin list.
That's it. You can now uninstall Winamp if you want, but better to leave it installed so you won't have to reinstall it whenever you want to install updates to DFX.
HP DV8t quad
Windows 7 Ultimate x64 (Retail)
i7-Q 720
Motherboard Chipset Intel Ibex Peak-M PM55, Intel Lynnfield
nVidia GeForce GT 230M (1GB)
18.4 inch HP Infinity FHD (Samsung 184HT03-001)
Hitachi 500GB 7200 rpm (x2)
Seagate FreeAgent 1.5 TB External USB (x2)
Thermaltake BlacX eSATA/USB 2.0 3.5/2.5 HD dock
Zalman NC-2000 notebook cooling pad
laptop
Logitech VX Revolution
Backup Unit: Lenovo T61p
DFX FTW...:D The sound effects are amazing. Been using for the last 3 years with both WinAmp & WMP.
D3f's Customs
Win 7 Ultimate SP1 x64
Intel Pentium Dual Core E5300 OC'd @ 3GHz
Asus P5G41-M LE
Kingston 2x2GB DDR2-800 Dual Channel SDRAM
Integrated Intel GMA X4500
Realtek 5.1 HD Audio (ALC887)
LG Flatron W1943S @ 60Hz
1360 x 768
Internal - WD Caviar Blue 500GB, External - WD My Passport Essential 500GB
Headway 450w PSU
Pixxo Slim Black mATX Case
Stock Cpu Fan, 1 x Top Case Fan
Logitech K120
Logitech LS1 Laser Mouse
17.66Mb/s Down, 0.82Mb/s Up
Creative SBS A300 2.1 Speaker System, LG GH22NS50 22x Internal Super-Multi DVD-RW, 2Wire 5012NV Wireless Modem Router
Thanks to D3ftOn3z im also using DFX in my computer, with no problems =)
The sound is truly amazing
- BTW, EMINEM FTW, nice screenshot !
Windows 7 Ultimate 64 BITS
Quad core Q6600 2,4GHZ
Asus P5N-D
8 GB DDR2
Geforce GT 8600 ddr3
1 -22 LCD Samsung, 1-19 LCD Samsung
1920x1080, 1440x900
1 - Barracuda 750 GB
4mb/s
1 home theater 7.1 - 180 RMS
