Water Cooling guide
Alsisgevat
2:02 AM
South Africa
Hi everyone. This Is my attempt at making a water cooling guide for beginners. THIS WILL BE BASIC.
Firstly, why water cool?
Well, you get cooling performance that no air cooler can give you, secondly using water cooling opens a new world to over clocking, and it is safe if you follow some basic rules.
What you need:
Pump
- The is the heart of your water cooling setup, obviously it pushes the liquid via the tubes to the necessary components. But what is important,is that you get different strengths, the 2 most common are Swiftech mcp355 MCP355 - Rouchon Industries Inc., dba Swiftech - PC Liquid Cooling Systems CPU Cooler VGA Water Block Heatsink Pump Radiator Heat Exchanger Kit This pump is considered to be the most versatile,mainly because it is small enough to fit in any chassis, and it can move liquid easily. The other one,and my personal favorite is the Swiftech mcp655: MCP655 - Rouchon Industries Inc., dba Swiftech - PC Liquid Cooling Systems CPU Cooler VGA Water Block Heatsink Pump Radiator Heat Exchanger Kit This one is awesome, its very popular and can move liquid like there's no tomorrow! There are various other types and brands, but the 655 or 355 series are the best and mostly used.Please take note,that if you run your pump dry for even a second it will burn out. Another important hint here is when you finshed the loop,and you added the liquid, remember that the asoon as you start the pump it will drain the liquid very fast,and if you are not quick enough to add more while the pump is running,or you miss calculated how much liquid is needed,your pump will drain all the liquid before the liquid reaches the pump again,so it will run dry,and be useless after that. Make sure you take the length of tubing,size of reservoir in account.
Reservoir- This is where all the liquid is stored,and also the only place you fill the loop from. Again you get different types, most people tend to go with the cylinders from EKWB, I personally use them,because of the look,and they offer various sizes,and most importantly,they are super easy to install and connect.: EK-Multioption reservoir 250 - Reservoirs - Reservoirs & Accessories THEN you can always go for a bay drive reservoir, these fit into any 5.25 drive bay, and is nice and neatly out of the way:http://www.ekwb.com/shop/reservoirs-and-acc/bay-res/ek-bay-spin-reservoir-acetal.html Take note,they are harder to fill then normal cylinder reservoirs,and don't offer as many liquid holding per icc as a cylinder(size of the amount of liquid in it). And then,this part is a must if you plan to make life easier,get a pump top! This is a little add on to your pump that allows you to use whatever fittings you want! This means if you plan on getting a MCP355,and it only supports 3/8" barb fittings,you can now with a pump top use 1/2" or any size you prefer. It also allows you to use your custom compression fittings for a tighter seel, so its a win win. : MCP35X Housing - Rouchon Industries Inc., dba Swiftech - PC Liquid Cooling Systems CPU Cooler VGA Water Block Heatsink Pump Radiator Heat Exchanger Kit they come in different colors,shapes and uses, so pick the one for your pump, and enjoy! Take note, that reservoirs connected to pump tops,require only one exit,so by doing this you save allot on barbs,cause you need only 2 for in and out, and you can make it compression fittings for safety and looks.
Tubing- Pretty much self explained, it caries the liquid. Most used sizes are 1/2" ID x 3/4'' OD, ID=Inner diameter and OD=outer diameter. Make sure this matches the OD of your fittings. You can however get a smaller 7/16 ID tubing,and fit it on a 1/2'' barb,this will create a tighter seal, but you cant use compression fittings then. Also you can get anti-kink coils, these are spring like raps around your tubing,that prevent kinking. IMO I don't use them,they are not nice to look ate,and if I have a tight bend that may kink my tubing, I will use 45 degree barbs or maybe even 90degree barbs. Or as I have used in my rig,two 45 degree fittings as one,so it makes a 90 degree bend,but is ALLOT less restrictive then the normal 90 degree fittings, to be honest,using two 45 degree fittings is maybe more expensive,but works allot better.
Fittings-
You get barbs and compressions, a barb is just a smooth little "holder" for the tubing,the tubing slides over it,you don't have to,but it is seriously recommended to use hose clamps with these barbs, it just gives you peace of mind that it wont leak. A much better option is compression fitting, they pre-seel the tubing in the manner that it has a built in hose clamp, so you are protected. And they tend to "finish" a liquid loop/ These are a personal recommendation,I use them in my loop,and they come in ALLOT of colors..: Monsoon Free Center Compression Fitting - 1/2"ID x 3/4"OD - Single Black Chrome (FCC-1234-1P-BC) - FrozenCPU.com .You can get bitpower fittings that costs more then the rest,but is well worth it, or go for some cheaper ones like coolance or EKWB, they all work fine, and if you plan on using some color scheme,then plan the fittings accordingly, ie: Chrome fittings go very well with white or black tubing, black fittings gives you a great contrast on white tubing, but using black fittings on black tubing wont show,so if you don't want people to see your nice tubing and fittings do this, otherwise make some color contrasts and make your rig stand out and enjoy it while doing it.
Blocks- This is the core of water cooling, you can get blocks for cpu,memory,graphics cards,motherboard blocks and so on. But the most used blocks are for the cpu, the base is used the same way as with a air cooled cooler, and consists of a (mostly copper) flat surface that connects with the cpu,the top of the block will have to 3/4" barb holes, and will be IN and OUT ports, so just apply some thermal paste on the copper base,screw in the cpu block and connect your tubing and barbs in the appropriate holes, each block is different,so consult the manual for IN and OUT ports. You also get gpu blocks,these are a litle tricky to install,cause you need to strip your gpu down to the base,and remove the old cooler. Please note this VOIDS the warranty! An alternative would be to get a pre-aplied block, EVGA has some hydro copper blocks,that are gpu's with the appropriate water blocks pre applied, this is allot easier,and from personal experience safer. You still have a 5 year warranty on them. Just dont try tu test them without liquid in the loops, they have not air cooling,so they rely on the liquid! You can if you want,get water blocks for the ram too,but cooling this will only be for looks,as it is a waste imo. Then also remember,always apply fresh thermal paste first,and just a thin layer,don't smudge it. Also the material used is important, some gpu blocks are copper only, and in some cases when using certain types of coolant with added chemicalsmthe copper will start to disilate and loose allot of cooling potential,and in worse cases even damidge your motherboard or other hard ware. Nickel plated blocks were designed to stop "corrosion" from happening, but in some cases the nickel plating can flake off, this has only happened with Koolance's gpu blocks recently,but news is they refunded them all,called the blocks back,and the new ones are said to be ok. Some blocks have arcylite tops,which look awesome as you can see liquid in them,so adding some red/blue dye,will make for a great looking rig,but these arcylite blocks are easy to crack,so don't apply too much pressure when installing fittings.
Radiator- This explains it self, and can be small i.e 1x120,or even big as the 5x140. This means it's a radiator that supports five 140mm fans! The only thing to note hear is the fin count, the more fins,the faster fans are needed,the less fins,the slower and more silent fans. To get the fin count,check the details of the rad, it would say 30fpi,or 12fpi and so on. Also, some rads have fittings only on the one side,more expensive ones give you the option of fittings on both sides,so it makes for easier placement. Just have a look at the rad you want's website,and make sure the barb locations on it is correct for your needs,and remember the fpi. Secondly, if possible to position the rad as close to the reservoir as possible,the only reason for this is that the tube length can be nice and short,and the liquid doesn't have to travel to far to get cold.
Fans- Also self explained,get fans of your choice, just get the appropriate speeds, i.e 1800rpms will be better for a 30fpi rad. And a 800rpm fan will be better for a 15fpi rad. I use gentle typhoons, they are noted to be best for rads, and remember that some fans may be super effective in an air cooled case,but wont work on rads, air flow isnt important,but pressure is,cause it needs to push/pull air via the rad fins, so make sure you choose the fans correctly,and don't use fans with slimline design, chances are very good that you will mess up with the screw and puncture a hole inside the rad. Just get your standard thick fans.What is very useful is a fan controller,this allows you to neatly control all the fans from on spot, and you can do this from out side the chassis. A fan controller is recommended.
Liquid- The cheapest is distilled water, all you need is a bottle of it and a silver kill coil to eliminate algae. But you can add die's for color, but this has a high chance of clogging up the blocks. But some liquid offers great features,like non conductive and non algae,these are more expensive,but can be used if you choose it. Bust seriously,just get some distilled water,and a kill coil,this is very cheap, and you can add your own dye to give it color. I have test some dyes from Mayem, and they are brilliant, if you spend a little cash and allot of time,you can create some very unique colors for the build, also if you plan on getting dyes,get clear tubing for obvious reasons. But if you plan on keeping one color scheme for life,rather use clear distilled water and pic the colored tubing you want, so it will last longer.
Some things to note:
Water cooling requires allot of time and planning, draw a loop out on paper first,and see where you will need fittings,maybe a 45degree turn fittings, and so on.
*I planned on making a dual loop and bought all I needed to do it, but after assembly I changed into a single loop,with a strong pump,it looks allot cleaner and neater now, so expect to change your design allot.
*Plan accordingly, don't buy separate stop fittings if you can get a reservoir with them included, you will only waste money
*The best order for a single loop is: Reservoir,Pump,Radiator, CPU Water block,Reservoir. Or even Reservoir,Pump,radiator,CPU Water block and the a separate *Radiatror2 for extra cooling,Reservoir. You will see that the Reservoir is always before the pump,and Always above it!!
*The general rule is. 1 rad for 1 block. With the new GPU's and CPU's you can make it 2 rad on block, this means a rad that supports 2x120mm fans next to each other,and some support an additional 2 at the back. But basic terms are a dual rad. If your chassis can fit bigger,then go bigger!
*And always leak test your loop before using it, you can do this by plugging only the pump in a separate psu,and jump starting the psu,by connecting a paperclip to green and second black wires. Search Google for more info on this. And rap all the connections of your loop in paper towels,this way you can see a leak easier. And let it leak test for at least 24hours. After a safe test,plug in all the components and let her run.
*Remember that its better to have left over,then having to need more, ie: when cutting your tubing, rather make it a bit longer,then having it be to short. Or when buying fittings, if you planned it out and need 10 fittings, buy 12, you will be glad later on, sometimes you buy stuff and end up not needing them, I personally have 10 feet of tubing left,6 fittings,3 reservoirs and a 240 rad,all these were in a plan to wc,but as you build your rig,you see new ways of doing it, so you make changes, so don't worry about buying more then you need, it happens:D
Hope you all enjoyed this short and BASIC guide, if you have questions leave a comment, and I will try to answer as best I can. Thanx for reading.
Ps: here is a link to my build,please feal free to ask any questions. Thank you
http://www.sevenforums.com/overclocking-case-mods/244466-tj-11-build.html#post2036371
64bit Windows 10Intel i964g-8x8gig DDR4 3600Asus ROg Strix 1080ti
Custom built
64bit Windows 10
Intel i9
MSI X299 Carbon pro
Samsung 49" Odyssey g9
5210x1440
1 x 512GB m.2 OS Drive
2 x 512gb ssd
1 x 2tb
4x 1TB's
Corsair AX1200w
Silverstone TJ11 B-W
AIC
Asus Rog Claymore 2
Asus Rog Apatha
1gb Fibre
Nice tut, Alsisgevat. I never thought I would go water cooling until I got an Ivy bridge. The H 100 won't do much more than slow it down. Does anyone know if the XSPC kits are any good? They seem to be pretty popular.
    ALWAYS UNDER CONSTRUCTION
    Windows 11 Pro
    Ryzen 9 5900X
    Asus X570 Crosshair Viii Hero
    32GB G Skill DDR4-3600
    EVGA RTX 3080 FTW 3 Ultra
    3 X Asus 27"
    2 X 1 TB NVME drives
    EVGA 850
    Phanteks Eclipse P400A
    EVGA 280 AIO
    Logitech G510s/ Logitech G13
    Logitech G502
    ESET/MBAM Pro/SAS Pro
    Chrome/ Firefox/ Edge
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
Thank You!! And they are amazing, I ordered one with rad and all, but cancelled it after I did the gpu's, it's too much work and not enough space, but I will in the near future add the XSPC raystorm cpu block to my all ready existing loop,instead of making a new separate loop.
Custom built
64bit Windows 10
Intel i9
MSI X299 Carbon pro
5210x1440
2 x 512gb ssd
1 x 2tb
4x 1TB's
Corsair AX1200w
AIC
Asus Rog Claymore 2
Asus Rog Apatha
1gb Fibre
The XSPC kits are awesome. They're completely dissimilar to the typical AIO kit, as in other than the combination reservoir/pump you can expand the kit in any way you see fit.
And as pointed out, very well put together tutorial there Alsis. :D
Windows 10 Technical Preview - x64Core i5-3570K - 4.5GHzG.Skill Sniper 12GB DDR3-1600ASUS GeForce GTX 970 STRIX
ASUS Sabertooth Z77 [B. 2003]
Acer K272HUL
Samsung 840 Evo 250GB (OS), Samsung Spinpoint F3 HD103SJ 1TB (Games), Seagate Expansion 1TB (Additional storage, Backup)
Cooler Master Real Power Pro 750W, Corsair HX1000W
HAF-X
XSPC Rasa RS360
Gigabyte Osmium, Noppoo Choc Mid 87, Corsair K70 RGB
Roccat Kova
50 Mbps up, 50 Mbps down
BitDefender TS 2013, Malwarebytes AM, SUPERAntiSpyware
Razer Vespula Gaming Pad, Razer eXactMat, Blackmagic Intensity Pro, Corsair Vengeance 1500 USB Headset, Google/ASUS Nexus 7
Thanks Terronium 12, I knew you had one and was going to ask you about them. I have to do something, Ivy Bridge is going to kill me. We have the same CPU and case, you can probably give me some advice based on your experience with them. I'm just looking now. I have an H100 but am ready to put my NH-D14 back in.
    Windows 11 Pro
    Ryzen 9 5900X
    3 X Asus 27"
    EVGA 850
    EVGA 280 AIO
    Logitech G502
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
Terronium- thanx mate! And yeah those xspc reservoir/pump combo's make your loop allot easier,but I still think they are harder to fill. But I like XSPC's cpu blocks allot!
Essenbe- You wont be sorry if you use watercooling, I am loving it! But the h100 is a pre-built liquid loop,so why would you want to remove it? This is one of the many reasons I am not watercooling my cpu,the h80 does enough cooling.
Custom built
64bit Windows 10
Intel i9
MSI X299 Carbon pro
5210x1440
2 x 512gb ssd
1 x 2tb
4x 1TB's
Corsair AX1200w
AIC
Asus Rog Claymore 2
Asus Rog Apatha
1gb Fibre
I have a Noctua NH-D14 that does better. And Ivy Bridge gets awful hot when you OC it. The H 100 can't handle it. I've repasted a dozen times with 3 different pastes, tried numerous fans in every configuration imaginable. Nothing changes. At 1.224V I hit 85 in Prime. I'm looking for something much better.
    Windows 11 Pro
    Ryzen 9 5900X
    3 X Asus 27"
    EVGA 850
    EVGA 280 AIO
    Logitech G502
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
Make sure you have it all planned out first because it's just as Alsis says: the combo res/pump is a pain in the ass when it comes time to drain and refill. As you already know I'm running the i5 at 4.6 and it peaked at about 89C, but is much, much cooler when my room isn't as hot or when the AC is on. However, because I want to push it even further (4.9-5.0+ if possible) I'm going to pick up either a 120 or 140mm rad and use that in addition to the 360.
I'm also considering picking up the Apogee HD block.
No problem, and I agree entirely with the XSPC bit.
But Ivy runs hot even on water and a 240 isn't really going to cut it. At least not with the VID my 3570 has.
Acer K272HUL
HAF-X
XSPC Rasa RS360
Roccat Kova
Yeah, they do get hot, but so far my H80 is holding up good enough. If I do watercooling on the cpu, I will add a 360 rad at the bottom, and a 120 on top, just for extra cooling. But chances are I won't, I only wanted the gpu's to be watercooled. And I played Batman Archam City and Witcher 2 last night,and the hottest the cards went were 37degrees!!!:D
Custom built
64bit Windows 10
Intel i9
MSI X299 Carbon pro
5210x1440
2 x 512gb ssd
1 x 2tb
4x 1TB's
Corsair AX1200w
AIC
Asus Rog Claymore 2
Asus Rog Apatha
1gb Fibre
Good tut Alsisgevat :thumbsup:
You should add a couple of example pics of the parts to each section and ask for this thread to be cleaned and stickied.
For more in depth explanations, just chuck in a couple of links :)
Nice :)
Once you get past the stress test phase, daily use temps are fine. While load temps are a bit higher than our 2500K's - they're still well within acceptable limits. At least they idle cooler :p
If you find yourself around 90c all day, every day - that's a different matter entirely ;)
Systems by SmartEyeball
8 Pro x64
i7 3770K 4.6GHz
ASUS P8Z77 WS
x3 Dell U2410 / 58" Samsung
5760*1200/ 1920*1200
Noctua NH-D14
IE, FF, WaterFox
Bloody Big Grin
Thanx,but I did add links, to only the stuff I see as important, the thread is allready a sticky. And This is just A basic guide, the idea was for everyoe that reads it to just get the general idea,if they want to know more I added at the bottom that anyone can reply and ask any quistions,and I will answer as best I can. I don't wan't to add pictures,then the guide will be over posted,and it will loose it's short andd sweetness:D
Custom built
64bit Windows 10
Intel i9
MSI X299 Carbon pro
5210x1440
2 x 512gb ssd
1 x 2tb
4x 1TB's
Corsair AX1200w
AIC
Asus Rog Claymore 2
Asus Rog Apatha
1gb Fibre
Yes, Patrick, everyday usage is no problem, it's only the stress testing. But, if you are going to OC, you have to do the stress testing. I'm only at 4.5 and hitting 85. I played BF3 last night and only got to 53, which is no higher than the 2500K or 2600K. But, I wanted to be up in your neck of the woods. The CPU has more in it, but the cooler does not. The difference in 4.2 prime and 4.5 is 20C. So, 4.8 is out of the question. And I know part of the problem is living in Florida, but that's just life. And Summer isn't even here yet. Besides, I've already spent more on coolers than the XSPC will cost.
    Windows 11 Pro
    Ryzen 9 5900X
    3 X Asus 27"
    EVGA 850
    EVGA 280 AIO
    Logitech G502
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
True, And you can't go wrong when watercooling, it is an amazing difference!!
Custom built
64bit Windows 10
Intel i9
MSI X299 Carbon pro
5210x1440
2 x 512gb ssd
1 x 2tb
4x 1TB's
Corsair AX1200w
AIC
Asus Rog Claymore 2
Asus Rog Apatha
1gb Fibre
So you did and so it is :o I just clicked on it when I saw it, lol :p
True. But 85 is nice and cool compared to the 95c+ I hit, lol. Thermal protection FTW :p
Yeah, it's heat and not volts that are these chips limits. 4.7ghz will add some more heat, but as long you don't 'overstress it' - the chip will handle the high stress temps while you dial it in.
I'm in the middle of winter, so come my summer - watercooling may definitely be back on the cards. And I'll need a new case. This Lian Li is not really big Rad friendly.
If worse comes to worse - I've always got a great 2500K sitting here as a replacement :D
That it is :)
If I end WCing (which has been on the cards since my 775 rig ;) ), I'll be looking at separate CPU/GPU water loops.
8 Pro x64
i7 3770K 4.6GHz
ASUS P8Z77 WS
Noctua NH-D14
IE, FF, WaterFox
Bloody Big Grin
That it is :)
Haha,no worries.
And my plan was to do separate WC and decided to start with the gpu's first,the WC on them are more expencive,after this I would have done the CPU, and may still do it, but Will need to think of a new way of wc ing it,not enough space. This is what I planned: It starts with the same reservoir and pump+pumptop I have allready installed,then down into the lower part of my chassis into a 240 rad,thenback up to the cpu,from the cpu to the second rad,but this is just a small 120 rad,then back into reservoir. I believe it will work well,and to me I think it will look pretty awesome, but still just thinking about it. Here is a pic of my rig with it in,done in paint. DO NOT make fun of my drawing:sarc::D
Custom built
64bit Windows 10
Intel i9
MSI X299 Carbon pro
5210x1440
2 x 512gb ssd
1 x 2tb
4x 1TB's
Corsair AX1200w
AIC
Asus Rog Claymore 2
Asus Rog Apatha
1gb Fibre
8 Pro x64
i7 3770K 4.6GHz
ASUS P8Z77 WS
Noctua NH-D14
IE, FF, WaterFox
Bloody Big Grin
    Windows 11 Pro
    Ryzen 9 5900X
    3 X Asus 27"
    EVGA 850
    EVGA 280 AIO
    Logitech G502
    Dell 16 Plus
    Windows 11 Pro
    Intel Ultra 9 288V
    32 GB LPDDR5X 8533
    2560X1600
    1 TB NVME
Hehehe, I like it so much that I might just do it haha
Custom built
64bit Windows 10
Intel i9
MSI X299 Carbon pro
5210x1440
2 x 512gb ssd
1 x 2tb
4x 1TB's
Corsair AX1200w
AIC
Asus Rog Claymore 2
Asus Rog Apatha
1gb Fibre
Hey guys since we are talking Watercooling I feel My numbers aren't what they should be for my current set up
At the time i was running same set up as this same cooler but now ......this is not the original board it all was installed on it is the same but not the original RMA
The Cpu same thing I had a issue with a bent pin bought a new one and returned the other now the problem is the temps Using Antec Khuler 620 push pull
Originaly my temps would be 16c to 38c max load @ 4.5ghz
now my temps are hitting 50c even in the Bios hitting 61c max temp for cpu but the temp throttles up and down I went and used Antec 7 nano diamond compound spread even no need to cure anyway now 3 hours later after i shut down my temps are right here in the first snip second was temps from earlier
Now I want to know if i switched from the fans i have now coolermaster /antec push pull on radiator Micro Center - Scythe Ultra Kaze 120mm 3,000RPM Case Fan DFS123812H-3000 think a pair of these would give it a much needed kick?
Enthod Pro Full Tower
Logitech wireless keyboard
Logitech wireless mouse
Cox Cable 100+ mb
IE-10, Chrome, Opera
GPU GTX Gigabyte 970G1
Heads up I installed Kaze Jyuni scythe Fans and big time change which i am happy to report
The stock fan from the waterblock and coolermaster fan did no justice but these puppies got me with no worries now
stable temps now :D max temps after burning a movie were 37c then droped back down to 16c
Cox Cable 100+ mb
