Wireless connection issues - Stuck on Identifying
jigsaw82
6:00 AM
I have a Dell Latitude with Windows 7 enterprise 64 bit edition. From past 4 days, I am facing an issue wherein I am not able to connect to my wireless continuously. If I switch off the modem and router, it connects for some time but drops again and then gets stuck on identifying. There are other devices that can connect to the wireless fine - tablet/mobile/another laptop. Apparently, I can connect to my mobile hotspot without any issues.
I am a novice in these kind of networking issues so have not been able to try much. But I did try the following options:
1. System restore - Restored to around 10 days back
2. Deleted wireless connection - It connected but drops and gets stuck. It did give the message "problem with wireless adapter or access point" when I did a troubleshoot. If I troubleshoot again it does not do anything.
3. Driver update - Says the driver is up to date
4. Ran McAfee antivirus - A trojan was detected and deleted.
I would really appreciate any help regarding this.
Thanks.
Windows 7 Enterprise 64 bit
Thanks.
If you can post the output of the following two commands it would be most helpful. :)
ipconfig/all
netsh wlan show all
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
GSkill Phoenix Pro 120GB SSD
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Thanks for helping me out here. Attached are the outputs of those commands.
~Aps
I'm not really seeing anything that would explain the connection drop issue.
Have you tried resetting the router?
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Yes, I did reset the router a couple of days back to no effect.
Yes try resetting by first unplugging the router from the modem, reset the modem by unplugging it for a few minutes and plug it back in letting the lights settle. Then plug the router back in to the WAN or Internet port. Let the lights calm down then check for connectivity.
Post a screen shot of the ipconfig/all if you are still having problems after this.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Hi Chev65,
Thanks for your time.
I did try resetting again as you suggested but it did not work. Then I uninstalled the network card and installed it again. It worked for some time and now its back to where it was - stuck at Identifying.
Below is the ipconfig /all output:
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Centrino(R) Ultimate-N 6300 AGN
Physical Address. . . . . . . . . : 24-77-03-65-B5-F4
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::6d77:e7bb:cbe9:43e7%28(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.67.231(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Any other ideas?
Thanks,
Jigsaw
Hi Chev65,
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Any other ideas?
Thanks,
Jigsaw
Is this the entire ipconfig/all? Because many components of the network stack are missing from this for some reason?
This should look more like mine. Most likely your system files have been corrupted by a virus or malware.
You should try running the following command and let me know the results. It's unlikely you will pass this scan from what I've seen here.
sfc/scannow
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Attached is the complete output of ipconfig. I actually just pasted the top part earlier. Sorry about that.
Thanks.
Yes I think that virus messed something up. No real problems showing there, your machine can see the router but isn't connecting for some reason.
Can you run the sfc system file scan and let me know the results?
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Attached output of sfc scan.
If virus or malware did mess up any files, shouldnt that effect connectivity through mobile hotspot as well? Surprisingly that works fine without any issues.
Ok try going into the Network and Sharing Center, look to the left for "Manage Wireless Networks" delete the old profile for this connection then create a new wireless profile making sure the SSID, password and, security type and encryption are the same as the ones in the routers settings. Check if the connection holds up after that.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
How do I check the router settings?
You've never accessed the routers wireless settings before?
Ok just click on > http://192.168.1.1
This should be your routers firmware set up page.
Since you reset your router's it's likely that all the wireless connection settings are at default so you will need to set up the SSID, password, security and encryption again from scratch.
Home built
Evga 780i FTW
GTX480
Asus Xonar D2
HannsG
1680X1050
ThermalTake XaserV
Xigmatek S1283
Logitech G15
Logitech G9
T1
Hi Chev65,
Tried this as well but did not work. As a workaround, I am using my tablet for USB tethering.
Thanks for your help.
