Navigation Pane - Automatically expand to current folder
    How to Turn On or Off Expand to Current Folder in Navigation Pane in Windows 7
    This will show you how to have automatically expand to current folder turned on or off in the Windows 7 Navigation Pane folder tree while you are navigating in the main Windows Explorer pane.
    If you open a user folder directly to it's C:\Users\(user-name) location from say a shortcut or from the Start Menu, and did not manually navigate to it in Windows Explorer, then a separate (user-name) folder group will display in the navigation pane of Windows Explorer whenever you have the Expand to current folder option checked.
    Navigation Pane - Automatically expand to current folder-user-name_group.jpg
       Tip
    You can also quickly expand the navigation pane to the current location you are navigated to by pressing Ctrl+Shift+E keys.
    EXAMPLE: "Automatically expand to current folder" Turned Off
    NOTE: This is the default setting in Windows 7.
    EXAMPLE: "Automatically expand to current folder" Turned On
    OPTION ONE
    Through Navigation Pane
    1. Right click on an empty space in the Navigation Pane.
    2. To Turn On Automatically Expand to Current Folder
    A) Click on Expand to current folder to check it. (see screenshot below)
    Navigation Pane - Automatically expand to current folder-expand_current_folder.jpg
    3. To Turn Off Automatically Expand to Current Folder
    A) Click on Expand to current folder to uncheck it. (see screenshot above)
    OPTION TWO
    Through Folder Options
    1. Open Folder Options, and click on the General tab. (See screenshot below)
    A) Check the Automatically expand to current folder box. (see screenshot above)
    B) Go to step 4.
    A) Uncheck the Automatically expand to current folder box. (see screenshot below step 2)
    4. Click on OK. (see screenshot below step 2)
    OPTION THREE
    Through a REG file Download
    1. To Turn On Automatically Expand to Current Folder
    Expand_to_Current_Folder_Navigation_Pane.reg
    B) Go to step 3.
    2. To Turn Off Automatically Expand to Current Folder
    Not_Expand_to_Current_Folder_Navigation_Pane.reg
    3. Click on Save, and save the .reg file to the desktop.
    5. Click on Run, Yes, Yes, and OK when prompted.
    6. If open, close and reopen Windows Explorer to see the changes.
    NOTE: If you do not see a change, then log off and log on, or restart the computer to apply.
    7. When done, you can delete the downloaded .reg file if you like.
    OPTION FOUR
    Manually Through Registry Editor
    1. Open the Start Menu, then type regedit in the search box and press Enter.
    3. In regedit, navigate to the location below. (see screenshot below)
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
    4. In the right pane of Advanced, right click on NavPaneExpandToCurrentFolder and click on Modify. (see screenshot above)
    5. To Turn Off Automatically Expand to Current Folder
    A) Type 0 (number zero), and click on OK. (see screenshot below)
    B) Go to step 7.
    6. To Turn On Automatically Expand to Current Folder
    A) Type 1, and click on OK. (see screenshot above)
    7. Close regedit.
    8. If open, close and reopen Windows Explorer to see the changes.
  1. Posts : 10
    window 7
    It did not work for me. Please help me !
  2. Posts : 5,642
    Windows 10 Pro (x64)
    How did it not work?
  3. Posts : 10
    window 7
    I clicked on folder name and it didnot expand .
  4. Posts : 72,052
    Hello Lavecoi,
    In the Navigation Pane, try clicking on the arrow to the left of the folder, or double clicking on the folder instead to see how that allows it to expand for you.
    If you have Expand to current folder checked and click on a folder in the main Windows Explorer window and it does not expand to it in the Navigation Pane, then close and reopen Windows Explorer to see if does afterwards.
  5. Posts : 13
    Win7Pro & XPpro
    Orsumness!
    Been meanin' to sort this for ages and it only took a few click's, search "explorer expand navigate", hit the top result and a scroll down Brink's post.
    Thanks.
  6. Posts : 2
    Windows 7 Home Premium 64-bit
    I'm struggling to get this to work. Folder Options and the registry edit made no difference.
    I use the mouse as seldom as possible so I want to be able to use Windows Explorer as I used to in XP, i.e. with keyboard arrows and tab/shift-tab to navigate around. The requirement is:
    1. to be able to pass down to a folder in the Navigation Pane (using up/down arrows and right/left arrows to expand/contract to folder of interest) and to have the folder's contents displayed automatically in the right hand pane. As it stands this only works by hitting Enter when you get to the desired folder. This is annoying as (1) it is one more key stroke than XP and (2) I have to repeat the whole business if the selected folder doesn't have the file I want and I want to navigate to another folder.
    2. to be able to navigate the right hand pane and to hit Enter on a particular folder, it expands in the right hand pane and the folder appears in the left hand pane. This works fine.
    For the record, the regedits from separate posts for killing Libraries, Homegroup and Favorites worked straight away (thank you).
    Thanks.
  7. Posts : 72,052
    Hello Horse Sands, and welcome to Seven Forums.
    Yes, that can be annoying, but this tutorial is for only while you are navigating in the main Windows Explorer pane instead of navigating in the navigation pane.
  8. Posts : 2
    Ah-ha. Is there a fix to this elsewhere in the forum, per chance? No matter where I search I cannot see how to fix this.
    Thanks.
  9. Posts : 72,052
    Unfortunately, I'm not aware of any way around it so far.
