Open Command Window Here - Add or Remove Shift + Right Click
Page 1 of 3 123 LastLast
    How to Use "Open Command Window Here" Context Menu Item without Shift+ Right Click
    This will show you how to add or remove having to press Shift and right clicking on a folder or drive to use the Open Command Window Here from the context menu item for all users in Vista, Windows 7, and Windows 8.
    You must me logged in as an administrator to be able to do the steps in this tutorial.
    EXAMPLE: Open Command Window Here
    NOTE: By default you have to press and hold the Shift key and right click on a folder or drive to click on Open Command Window Here to open a command prompt with the focus at the folder or drive.
    Open Command Window Here - Add or Remove Shift + Right Click-default.jpgOpen Command Window Here - Add or Remove Shift + Right Click-right_click.jpg
    Here's How:
    1. Shift + Right Click to use "Open Command Window Here"
    A) Click/tap on the download button below to download the file below, and go to step 3 below.
    Shift+Right_Click_with_Open_Command_Window_Here.reg
    2. Right Click Only to use "Open Command Window Here"
    Right_Click_Only_with_Open_Command_Window_Here.reg
    4. Double click/tap on the downloaded .reg file to merge it.
    5. When prompted, click/tap on Run, Yes (UAC-Windows 7/8) or Continue (UAC-Vista), Yes, and OK to approve merging the .reg file.
    6. You can now delete the downloaded .reg file if you like.
    That's it
  1. Posts : 20
    Dude that is just awesome Thnx again. :)
  2. RpD
    Right-clicking on a folder, not within it
    One should be aware that 'Open command window here' is available when you right-click -ON- a folder name... and not by right-clicking within it. In other words, you cannot be inside a folder and right-click on the window background to get the 'Open command window here' menu item.
    However, you -can- do so with the Open Command Windows Here as Administrator registry edit. When you have a folder open, you can right-click on the window background (not on a file), and the pop-up menu will have the 'Open Command Window Here as Administrator' option.
  3. Posts : 72,052
    Hello RpD,
    When I right click on a empty area within the main folder window, I have a Open command window here option in the context menu.
    Open Command Window Here - Add or Remove Shift + Right Click-folder-window.jpg
  4. Posts : 10,200
    Shawn,
    Thanks.
    Karl
  5. Posts : 72,052
    You're welcome Karl. :)
  6. RpD
    Odd
    Odd, because I'm not getting that.
    I have a new laptop and it seems like that worked on my old one, but the new one won't give me an 'Open command window here' if I right-click a folder background. Old was 32bit, new is 64bit.
  7. Posts : 72,052
    Try with shift (hold) + right click to see if it does then.
    It will not do this in the "Computer" window, or in a library window. Only in a opened folder's window.
  8. RpD
    Yes, it will show up with a Shift-hold right-click... on folder window backgrounds, but Shift is not necessary if right-clicking on a folder name. Seems like there must be two different places to set the Shift mode. I don't have to Shift-hold for right-clicking on a folder name... (unless I return the functionality to default behavior).
  9. Posts : 72,052
    I updated the REG files in the tutorial. They include those locations as well now. Please give the updated REG files a try to see how they work for you for this now. :)
