Format a HDD or USB
    Quick Format a HDD or USB
    How to Quick Format a HDD or USB Drive
    This tutorial will show you how to format both external and 'internal' hard disk drives. We will be using both quick formats and also two useful pieces of software that can make fully formatting a HDD or USB much easier. In simple terms, this will remove all your files and folders from your disk storage device.
    You cannot quick format your C: drive as it has your OS installed on it.
       Warning
    Formatting your C: drive WILL kill your system. As I said above, whatever you format, back up a copy of all files and folders first on an external hard drive or CD. You follow this tutorial at your own risk. Please, please, please back up your hard drive.
    BEFORE YOU START:
    1. Back up a copy of all your files and folders to an external hard drive or CD.
    2. Also, either burn or copy all software to a disc (if needed and possible).
    Here's How:
    Quick Format
    1. Open the Start Menu by clicking the orb , and navigate to My Computer.
    2. Right click the hard drive or USB you would like to format.
    3. Select Format... from the options that drop down.
    4. A new window should pop up. Change the options in the drop down boxes to suit the requirements of your hard drive. Make sure the option Quick Format is ticked and press Start.
    5. A warning message should now pop up. Click OK to continue.
    6. A message should pop up saying Format Complete. Click OK.
    7. The pop up will close and return to the original 'Format Window'. Click Close.
    To check whether your hard drive is actually cleared, follow the following steps.
    8. Right click the newly formatted hard drive.
    9. Click the Properties option.
    10. The properties of your hard drive should look similar to the following image (close to zero used space and a large, almost entirely pink pie graph).
    Congratulations! You have successfully quick formatted your hard drive.
    Jaidyn
  1. Posts : 8,398
    Please ignore my image editing. I tried my best.
  2. Posts : 2,298
    Good simple Tutorial +1 :) - The last picture has your Taskbar in it so you may want to change that
  3. Posts : 8,398
    Thanks. I edited that last bit out as well. :)
  4. Posts : 21,004
    Dumb query
    Probably dumb query but I am going to wipe / format a HDD in an old XP machine to reinstall just the XP OS shortly - so same procedure - more or less?
  5. Posts : 8,398
    I've never had to quick format a HDD to put a new OS on it but I'm assuming that it should do the trick. And you shouldn't have to wipe it first; the re-install (if you clean install) should wipe it for you. :)
  6. Posts : 7,730
    Windows 7 Ultimate SP1 64-Bit
    There is no need to format a HDD or partition you are installing to as the operating system will do it automatically.
    That said, a quick format beforehand won't do any harm.
  7. Posts : 11,408
    ME/XP/Vista/Win7
    SSD / HDD : Optimize for Windows Reinstallation
  8. Posts : 8,398
    Well, there you go. As I said above, the re-installation should wipe it for you. :)
  9. Posts : 21,004
    Thanks to you all at least I know now - still finding out stuff even this simple.:)
