Window Color and Appearance - Enable or Disable Change
    How to Allow or Prevent Changing Window Color and Appearance in Vista and Windows 7
    This will show you how to allow or prevent all users from changing the current Window Color and Appearance personalization settings in Vista and Windows 7. Changing the Window Color and Appearance settings is allowed for users by default in Windows.
    EXAMPLE: Window Color and Appearance Enabled and Disabled
    NOTE: When disabled (right screenshot), Window Color is grayed out and will not open when clicked on.
    EXAMPLE: Window Color and Appearance settings
    NOTE: When enabled, these are the settings available that you can change when the ungrayed out (blue) Window Color is clicked on above.
    OPTION ONE
    Using a REG File Download
    1. To Allow Changing Window Color and Appearance
    Enable_Window_Color_and_Appearance.zip
    B) Go to step 3.
    2. To Prevent Changing Window Color and Appearance
    Disable_Window_Color_and_Appearance.zip
    3. Click on Save, and save the .zip file to the desktop.
    4. Open the downloaded .zip file and extract the .reg file to the desktop.
    5. Right click on the extracted .reg file and click on Merge.
    6. Click on Run, Yes, Yes, and OK when prompted.
    7. Restart the computer to fully apply.
    8. When done, you can delete the downloaded .reg and .zip files if you like.
    OPTION TWO
    Through the Local Group Policy Editor
    2. In the left pane, click on to expand User Configuration, Administrative Templates, Control Panel, and Personalization. (See screenshot below)
    3. In the right pane, right click on Prevent changing window color and appearance and click on Edit. (See screenshot above)
    4. To Allow Changing Window Color and Appearance
    A) Select (dot) either Not Configured or Disabled. (See screenshot below step 6)
    B) Go to step 6.
    5. To Prevent Changing Window Color and Appearance
    A) Select (dot) Enabled. (See screenshot below step 6)
    6. Click on OK. (See screenshot below)
    8. Restart the computer to fully apply.
  1. Posts : 1
    windows 7 32 bit
    windows 7 background turn red
    hi,
    I am having a problem with windows 7 background color.
    When I changed from slide show to the default windows 7 everything turn red.
    I tried to change to different colors, but it windows doesn't response to my changes.
    What did i do wrong and how can fix background problem
    I have windows 7 professional N.
    Please help.
  2. Posts : 72,073
    Hello Shura, and welcome to Seven Forums.
    Are you referring to the desktop wallpaper background?
    If so, then double check using the tutorial below to see if you may have the Remove background images (where available) box checked by mistake.
    Remove Background Images (where available)
  3. Posts : 1
    windows 7 enterprise 64 bit
    i download and install Enable_Window_Color_and_Appearance.reg but i changed my entire windows apperance..how can i revert back now ?? i dont have system restore option so please give me a way to go back as it was before.
  4. Posts : 72,073
    Hello Parthysing, and welcome to Seven Forums.
    Could you post a screenshot showing what you mean with more details? :)
  5. Posts : 1
    Windows 7 Profesional
    I just registered to say thank you for this post. I did seek for days to find out how to get windows background back.
    People did think that I mourning because someone because my whole desktop was black. When i did turn it to pink they guessed i am queer. Finally today my Alpha Romeo 8C appear again on my desktop.
    Thank you dude.
  6. Posts : 72,073
    I'm glad it could help Boboo, and welcome to Seven Forums. :)
