Homegroup - Add or Remove from Navigation Pane
Page 1 of 4 123 ... LastLast
    How to Add or Remove Homegroup from Navigation Pane in Windows 7
    This will show you how to add or remove Homegroup in the Windows Explorer Navigation Pane in Windows 7.
       Warning
    • You can only do this while logged into an administrator account.
    • This will affect all user account's on the computer.
    EXAMPLE: Homegroup in Navigation Pane
    NOTE: This is Homegroup added (default) (left screenshot below) and removed (right screenshot below) from the Navigation Pane.
    Here's How:
    1. Open the Start Menu and type regedit.exe in the search line, then press enter.
    3. In Regedit, go to the location below: (See screenshot below step 4)
    HKEY_CLASSES_ROOT\CLSID\{B4FB3F98-C1EA-428d-A78A-D1F5659CBA93}\ShellFolder
    4. In the left pane of regedit, right click on the ShellFolder key and click on Permissions. (See screenshot below)
    5. At the top, select the Administrators group. At the bottom, check the Allow box to the right of Full Control and click on OK. (See screenshot below)
    6. In the right pane of regedit, right click on Attributes and click on Modify. (See screenshot below)
    7. To Add Homegroup to the Navigation Pane
    A) Type in b084010c and click on OK. (see screenshot below)
    B) Go to step 9.
    8. To Remove Homegroup from the Navigation Pane
    A) Type in b094010c and click on OK. (see screenshot below)
    9. If you have 64-bit Windows 7 Installed
    CREDIT TO: Kookster for this addition.
    To also add or remove Homegroup from the "Open" and "Save as" type windows as well in 64-bit Windows 7, you will also need to do this step.
    If you have a 32-bit Windows 7 installed, then skip this step since doing steps 1 to 7/8 will add or remove Homegroup from the "Open" and "Save as" type windows as well.
    A) In Regedit, go to the location below:
    HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Classes\CLSID\{B4FB3F98-C1EA-428d-A78A-D1F5659CBA93}\ShellFolder
    B) Repeat steps 4 to 7/8 above.
    10. Close regedit.
    11. Restart the computer to fully apply.
  1. Posts : 4
    Re: How to Add or Remove Homegroup...
    Will this also remove the icon from my desktop? That's all I would care about. All other computers on my home net are XP, so Homegroup is superfluous to me.
    Nick
  2. Posts : 72,073
    Hello Nick,
    I don't believe it will, but if it does, then you should be able to use this.
    HomeGroup Desktop Icon - Add or Remove
  3. Posts : 4
    Do I have to do both, or will the downloaded reg file merge alone work?
  4. Posts : 72,073
    No, do the one here first to see if it is removed from the desktop first. We can go from there if needed.
  5. Posts : 5
    Windows 7,Vista,XP
    thanx m8, home group and other links were getting really annoying, especially when i opened a small open or save file dialogue, i couldn't see my favorites because the space was taken up by homegroup and libraries
  6. Posts : 72,073
    You're most welcome Iottt, and welcome to Seven Forums. :)
  7. Posts : 3
    on my laptop: Win7 home premium x64
    Thanks, Brink! My laptop is my only Win7 computer and the homegroup in the Navigation tab was driving me crazy. This tutorial worked perfectly!
  8. Posts : 72,073
    You're most welcome cmhp2111, and welcome to Seven Forums. :)
  9. Posts : 22,814
    W 7 64-bit Ultimate
    Hello Shawn.
    This is odd in Windows 8, Homegroup goes away but on a reboot it's back.
