Page 9 of 33 FirstFirst ... 789101119 ... LastLast
  1. Posts : 435
    X:\windows\system32>Format fs=NTFS label="Local Disk", didn't work, my disk is C://
    Error: Invalid parameter - label ="Local
  2. Posts : 72,128
       #81
    LOL, sorry.
    You would still need to use the diskpart command first like in your post above, then use this command. This command was just a replacement for the one you used instead at step 4 in your post above. See Option Two in the tutorial below as an example.
    Partition or Volume - Create New
  3. Posts : 435
    Ok, Disk 0 is now the selected disk.
    I then typed clean all, it appears stuck, nothing is happening, except the white underscore blinking.
  4. Posts : 21
    Windows 7 Professional 32bit
       #83
    Sorry Brink
    I don't know how to quote your statement, but just copy & paste:
    The Format fs=NTFS label="Local Disk"you did was for a "full format". It will take a bit to finish.
    Next time, you could use the command below instead to perform a "quick format" that will finish fast.
    Format fs=NTFS label="Local Disk" Quick
    , Is there any short cut to jump out from the Full Format to Quick Format?? Is it worth to do so?
  5. Posts : 21
       #84
    Hi Joe, I think it is doing cleaning now. As I experience before, it took ages to complete. I have abandon it in the half way.
  6. Posts : 72,128
       #85
    cmlow said:
    Sorry Brink
    Yes, it would be the same procedure as you did to interrupt the "Clean All" command.
    Afterwards, run "Clean" again, then do the quick format. :)
  7. Posts : 72,128
       #86
    Joe,
    Yep, it's doing the "clean all" now. It will take a long time to finish.
  8. Posts : 435
    cmlow said:
    Thanks heaps
    Joe,
    So can I go to bed safely?
  9. Posts : 72,128
       #88
    Joe,
    Yep, it could take that long or longer to finish. Sleep well. :)
  10. Posts : 21
       #89
    It is a great relief to hear this solution. I will try it out when getting home. Keep my finger cross.
    Thank you very much Brink.
