Control Panel - Add Local Group Policy Editor
    How to Add "Local Group Policy Editor" to the Control Panel in Windows
    How to Add "Local Group Policy Editor" to Control Panel in Windows
    This will show you how to add Local Group Policy Editor, also known as gpedit.msc, to the Control Panel in Vista, Windows 7, and Windows 8.
    In Windows 7, the Local Group Policy Editor will only be available in the Professional, Ultimate, and Enterprise editions.
    In Windows RT, 8, and 8.1, the Local Group Policy Editor will only be available in the Pro and Enterprise editions.
    EXAMPLE: Before and After "Local Group Policy Editor" added to Control Panel
    NOTE: This is the Control Panel icons and category view.
    Here's How:
    1. To Remove "Local Group Policy Editor" from Control Panel
    A) Click/tap on the Download button below to download the file below.
    Remove_GroupPolicy_ControlPanel.reg
    Download
    B) Go to step 3.
    2. To Add "Local Group Policy Editor" to Control Panel
    Add_GroupPolicy_ControlPanel.reg
    3. Save the .reg file to your Desktop.
    4. Double click/tap on the downloaded .reg file to Merge it.
    5. If prompted, click/tap on Run, Yes, Yes (UAC-Windowws 7/8) or Continue (UAC-Vista), and OK to approve the merge.
    6. When finished, you can delete the .reg file if you like.
  1. Posts : 2
    Regedit Explaination
    I completely understand that some people would like to just download a program (or zip file) and have it do all the work for them when trying to "fix" an issue.
    I, however, am not one of those people. Especially since it's not a good idea to allow strangers make changes to your registry w/o knowing what they are doing.
    Is there anyway you could give details as to what registry changes your zip file makes? I was hoping that by running the file the registry would open to the new entry. Alas, it did not. It worked perfectly. I'd just like to know how it worked.
    Thanks,
    Kinsey
  2. Posts : 72,052
    Hello Kinsey,
    Sure thing. I do not blame you.
    You can just right click on the extracted REG file from the ZIP and click on EDIT to see what changes are made to registry and where without having to merge or run them. From there, you can manually make the changes in the registry instead. :)
  3. Posts : 2
    Awesomeness
    That's great. I tried that but forgot that you need to extract the file before I can view it's contents. Silly me.
    Thanks for the help.
    Kinsey
  4. Posts : 72,052
    LOL, I'm glad to hear that you got it sorted Kinsey It's always the little things that catch us. :)
  5. Posts : 1
    windows 8.1 x64
    So i downloaded the .reg file, executed it, and i do now see the local group policy editor in my control panel, but when i try to open it to disable the lock screen i get this error message:
    "MMC cannot open the file C:\WINDOWS\system32\gpedit.msc This may be because the file does not exist, is not an MMC console, or was created by a later verison of MMC. This may also be because you do not have sufficient access rights to the file."
    Please help! The lockscreen is by far the most annoying feature of windows8, and the fact that theres no way to disable it on my verison of windows 8 is very frustrating. I work with digital audio workstations, and its a pain in the ass to have the lockscreen pop up while im busy playing/recording an instrument yet rely on the screen to watch my recording in progress.
    Im currently using windows v. 8.1
    Ryan
  6. Posts : 72,052
    Hello Ryan, and welcome to Seven Forums.
    What edition of Windows 8.1 do you have?
    Unless it's the Windows 8.1 Pro or Enterprise edition, you do not have Group Policy included in your Windows.
  7. Posts : 20
    windows 7 home premium 64 bit
    I downloaded and installed the registry hack for adding Local Group Policy Editor to the Control Panel: System and Security, and it worked like a charm, however I get the same pop-up Ryan got:
    My OS is Windows 7 Home Premium. Does this mean I cannot take advantage of the Editor?
    Thanks.
  8. Posts : 72,052
    Hello xp4ever,
    Unfortunately, the Windows 7 Home Premium edition does not include the Local Group Policy Editor MMC in it. This would be why you got the error since it's not there to find.
  9. Posts : 20
    Ok, thanks.
