Recycle Bin - Pin to Taskbar
How to Pin the Recycle Bin to the Windows 7 Taskbar
The Recycle Bin provides a safety net when deleting files or folders. When you delete any of these items from your hard disk, Windows places it in the Recycle Bin and the Recycle Bin icon changes from empty to full.
This will show you how to create a Recycle Bin shortcut with Empty Recycle Bin in the context menu, and how to pin this shortcut to the taskbar as a toolbar.
Removable drives do not use or have a Recycyle Bin. Files deleted from removable drives are permanently deleted instead.
EXAMPLE: Recycle Bin Unpinned and Pinned from the Taskbar
Here's How:
1. Make sure the Recycle Bin is on the desktop.
2. Right click on the desktop and select New and Folder , then rename it anything you like. (i.e. Trash Bin)
3. Drag & drop the Recycle Bin on the new Folder to create a shortcut.
NOTE: You could also Pin to Start Menu this new Recycle Bin shortcut by pressing and holding Shift, then right click on the shortcut, and click on Pin to Start Menu.
4. Save the new Folder (containing Recycle Bin shortcut) to the directory of your choice (i.e. C:\Trash Bin) by dragging and dropping.
5. UnLock the taskbar.
6. Right-click on the taskbar and select Toolbar and New toolbar...
7. Navigate to the location you saved the New Folder (Ex: Trash Bin), select it and click on the Select Folder button.
8. This places the new Toolbar and a Separator (dotted lines) on the taskbar.
9. Right click on the Separator and uncheck Show Text and Show Title.
10. Right click on the Separator and select View and Large Icons.
11. You now have the Recycle Bin pinned to the taskbar.
12. To Keep the Recycle Bin on Right Side of Taskbar
A) Left click on the Separator to the left of the folder and hold, then drag it to the left and right to make any adjustments to how you want the Recycle Bin positioned on the right side of the taskbar. (See screenshot above)
B) Release the left click when done.
C) Go to step 14.
13. To Have the Recycle Bin on Left Side of Taskbar
A) Left click on the Separator of the pinned taskbar programs on the far left side and hold, then drag it to the right past the Recycle Bin and release. (See screenshot below)
B) Left click on the Separator of the pinned taskbar programs on the now right side and hold, then drag it to the left next to the Recycle Bin and release. (See screenshot below)
14. Lock the taskbar.
15. Remove the Recycle Bin from the desktop.
You do know that when you drag & drop copied shortcuts from the Start Menu in with the Recycle Bin shortcut, that those automatically become Quick Launch items beside the Recycle Bin. By doing it that way you can "kill two birds with one stone".(See screenshot below)
Enjoy,
this is excellent!!
now i can get rid of the only icon i ever have on my desktop. i love the new taskbar, it's so very useful :)
great tutorial, i appreciate your time and effort.
7600 x86Core 2 Duo e7200, 2.53 ghz2x DDR2 PC5300 1gb, 667 mhzGeForce 9500gt, 512mb
7600 x86
Micro-Star MS-7529
22" LG Flatron w2234s
Excelstor SATA-II 250gb 7200rpm, 8mb cache
CoolerMaster M520
30/20 mbits
You can also move that toolbar to the left side and remove the text and change the icon size to large, which looks like this.
Windows 7 Ultimate Vista Ultimate x64Core 2 Duo E8500 3.16Ghz @ 3.8Ghz2x2Gigs Patriot PC2-6400 LLInno3D GeForce GTX260 216 SP
Home Brew
eVGA 750i FTW
SATA 150GB
SATA II 250GB
USB IDE 750GB Ext.
Liquid Cooling System
Logitech G15 Gaming Keyboard
Logitech G9 Gaming Mouse
This tutorial has been updated to have the choice of having the pinned Recycle Bin (fully functional) on the left or right side of the taskbar. :)
Hello Charbroil57.
Good tutorial, I like the recycle bin on the taskbar better; in Vista you could just drag it there.
Thank you!
Later ;) Ted
* BFK Customs *
W 7 64-bit Ultimate
Intel Q9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
ATI : XFX 5870
Realtek HD Audio 7-1
1920x1080P & 1920x1200
Corsair 620HX
Cooler Master RC-690
Microsoft 500
Razer Diamondback 3G
14 Mb/s
Hello Charbroil57.
Thank you!
Later ;) Ted
Hello Bare Foot Kid,
Your are quite welcome, it is a lot nicer if your into a clean desktop. Retaining the characteristic features we have come to like is a plus also.
Windows 7 Home Premium x64 (clean install 8/0...AMD Phenom II X2 550 Black Edition 3.1GHz8 GB (4 x 2 GB) Corsair 6400C5 800 MHzBFG 512MB GDDR3 9600GT OC
Custom by Charbroil57
Windows 7 Home Premium x64 (clean install 8/05/2015)
Gigabyte GA-MA790X-UD4P AM3/AM2+/AM2 AMD 790X ATX AMD
Realtec HD Audio 5.1
DVI Viewsonic VA2231
1920 x 1080 (1080p)
1 TB SATA 6G Seagate Barracuda (Boot drive, limited to 3G due to Mobo)
500 GB SATA 3G Seagate Barracuda
500 GB USB Seagate Desktop Drive
Ultra X4 750w Modular(upgraded)
Antec Sonata
Stock (80w CPU)
Microsoft Wireless Desktop Elite
Wirless Intellimouse Explorer 2.0
Xfinity Broadband (Home 75 MB Download)
Norton Internet Security
Firefox 39 (default) and IE 11
SATA HP Lightscribe DVD RW
SATA Samsung Lightscribe DVD RW
Thanks CB57, like it so much! Great work, I think it fits nice on the left side with ql on the right.
Keep up the good input flow. lm
Windows 7 Ulti. x64AMD Phenom 8450 triple-core 2.10 ghz4GBATI Radion HD 3200
Gateway GT5692
Windows 7 Ulti. x64
4GB
ATI Radion HD 3200
Gateway FPD1775W
1280x720
465.6613 Gibibytes
You do know that when your on step 3 of the Recycle Bin - Pin to Taskbar Tutorial and you drag & drop copied shortcuts from the Start Menu in with the Recycle Bin shortcut, that those automatically become Quick Launch items beside the Recycle Bin. By doing it that way you can "kill two birds with one stone". That is what I finally did as you can see in the attached screenshot.
1920 x 1080 (1080p)
Antec Sonata
Stock (80w CPU)
Hello again.
This is very useful, I just used it to add a shortcut to my storage drive and a shortcut to Brinks Instant Restore Point that I couldn't get to pin to the taskbar previously.
Have some rep love on me.
Later ;) Ted
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
CB thanks again! I'm liking this more and more, however ql must remain because my better half does not like change.
Gateway GT5692
Windows 7 Ulti. x64
4GB
ATI Radion HD 3200
Gateway FPD1775W
1280x720
465.6613 Gibibytes
this is fantastic! thanks for your ingenuity!
7600 x86
Micro-Star MS-7529
CoolerMaster M520
30/20 mbits
yeah...thanks its a nice trick
Windows 7 RC ,Windows Vista Ultimate ,Windows...Core 2 Duo 2.4 Ghz4 GB Ram
Windows 7 RC ,Windows Vista Ultimate ,Windows XP SP3,Ubuntu 8.01
Core 2 Duo 2.4 Ghz
Intel 945 G
4 GB Ram
WD SATA 250 GB
Hitachi SATA 80 GB
Not sure if anyone is as OCD about this as me, but anyway, here goes just in case...
I hated how the small icons aligned to the top, and the large icons pushed the taskbar icons to the top and therefore the rectangles around them didn't fit the bar properly...
So, I switched to large icons, and then moved my taskbar to the left side of the screen, and then back down again, and (magically it seems) the large icons simply fit within the usual 40px taskbar (instead of increasing it to 43px or w/e).
If anyone else had that problem, I hope I helped!
(new here just btw)
EDIT: I just moved it to try and replicate what I did to get it to work, and it reset to the horrid 43px height... If anyone has a better solution to this one, please let me know!
- AeonSlayer / Simon
Windows 7 RC
Windows 7 RC
Windows 7 Build 7137 x64AMD Athlon 64 X2 +40002gbNvidia Geforce 6150SE
Compaq Presario
Yes
2gb
Realtek
Toshiba 26" LCD TV
1360x768
Samsung something-or-other 250gb
ADSL
1 tb of external storage
Oh, figured it out for real this time! (Has worked 4 times so far :P)
Just unlock your taskbar (while at the bottom of the screen) and grab the top, and expand it to like 3 times the normal height. From there, just shrink it back to the standard height and it SHOULD be 40px high and all will be right in the world!
Cheers!
Windows 7 RC
Windows 7 RC
Cheers!
That has bugged me now that you mentioned it lol. However neither of the steps you provided worked for me :(
Windows 7 Ultimate retail // Windows 7 build ...Intel Core i7 920 // Intel Core2Duo T-5550 1....12 GB Corsair XMS3 Tri-channel 1333 // 4 GB DDR2EVGA GTX 295 // Nvidia GeForce 8800 GTS
Self-built // Gateway FX P-6860
Windows 7 Ultimate retail // Windows 7 build 7264 x64, Vista Home Premium SP2 x64
Intel Core i7 920 // Intel Core2Duo T-5550 1.86x1.86
EVGA x58 SLI LE //
Integrated Realtek // RealTek HD integrated sound
19" Acer flatpanel // Laptop Display, Secondary CRT
1440 x 900 1152x864 // 1440x900, 1152x864
750 GB WD Caviar Black 7200 RPM - in desktop
320 GB -laptop
80 GB - laptop secondary drive
Corsair HX1000w // Laptop PSU?
Thermaltake Armor+
Assload of fans, intel stock cpu cooler // GearHead Fan dock
Razer Lycosa // laptop keyboard
Razer DeathAdder // Logitech Laser
3.0 MB down/ 768 Kb up
Just built my computer in 12/09
Yeah, I myself found the second method should work if you do it two or three times... but maybe I just got lucky.
I found out, sadly, that whenever explorer.exe resets, so too will the 43px height. So I just got fed up with the whole thing and made them small icons, which doesn't look quite as good, but is much easier on the whole.
Sorry I couldn't be of any more help, just move the taskbar round and resize it a lot, and it should work eventually I found.
Anyway, if anyone's got a way to change the size of "large icon" mode to 43 px (maybe through a regedit hack?) please let me know!
Windows 7 RC
Windows 7 RC
- Simon
I got it once, but I cant seem to do it again. The one time I got it was when i put the bar on the bottom, as I usually have it on top. But I cant even fix it when I put it on the bottom. Yeah, we need to discover a registry hack or something. Perhaps this will be fixed in the final version. we can only hope.
EVGA x58 SLI LE //
320 GB -laptop
Thermaltake Armor+
The only problem with this method is that it creates a clear space of about 5px below the actual pinned icons making the hover effect look off.
You can actually use, I've discovered, a third party program know as TrueLaunchBar to create "custom" toolbars. This allows you to make custom sized icons, and position them centered vertically if you wish (which is what I've done). I now have my Bin, then a CD Folder / Eject button, and a HDD / USB monitor on the right of the bar, next to the task tray, with white icons so it blends in. Other than this, I haven't found a good solution as of yet.
Windows 7 RC
Windows 7 RC
