Crash
shadowminx69
4:35 PM
Ok don't know what happend but Ie8 dosn't work anymore or windows update they both stall and then shutdown and send info to microsoft. No clue what happend unfortunaly I didn't have system restore set up thought it did that Normally so I might have to reinstall :( any Ideas?
Windows 7 Build 7000
HP Compaq Presario/SR5113WM
Windows 7 Ultimate x64/ Windows Vista Ultimate x64
AMD Athlon 64 X2 3600+ 1.9Ghz
Asus M2N68-LA
PNY Optima Memory DDR2 2GB 2x1 kit
PNY Nvidia 8400 GS 256MB
On board RealTek
Acer X163W LCD
1366x768
Western Digital 160 GB SATA 3G (3.0Gb/sec)
7200 rpm
Western Digital 160 GB IDE
Dynex 400w
Nothin Special
Standard 102 key with volume and sleep buttons
Wireless Logitech LX7
Comcrap 10mb cable
Insignia 2.1 speakers, wireless Xbox 360 controller w/plug n play charger, Belkin wireless G + mimo usb network adapter.
yes IE8 is working ok now however when ever I click on Windows update I get windows Explorer has stopped working. and shuts down.
Asus M2N68-LA
On board RealTek
Acer X163W LCD
1366x768
7200 rpm
Dynex 400w
Nothin Special
Comcrap 10mb cable
no Luck
scan came out clean. wonder what happened.
Crash Too
The same thing just started happening to me. I have no trouble going to other Websites but trying to start Windows Update causes the same error as you're getting. I also tried resetting IE8 and SFC /SCANNOW and neither helped.
Homebrew
Windows 7 Ultimate (64-bit)
Intel Core 2 Duo E6700 (2.66 GHz)
Intel DG965WH
8 GB
ATI 2600 XT
SigmaTel 9271
Dell SE198WFP 19" Widescreen LCD
1440 x 900
3 Maxtor 500 GB SATA II
Thermaltake 750 W
2-80 mm, 1-120 mm
Microsoft Digital Media Pro
Microsoft Wheel Mouse Optical
Cable 1.5 Mbps
Have you recently installed Java ?
The same problem happened to me this morning so I restored the system before the installation of Java and my computer works fine now. (I couldn't uninstall because explorer was crashing just like windows update)
Laptop HP Pavillion 9205eu
Windows 7 Build 7000 32Bits
Turion 64x2
2Go
GeForce Go 7600
I noticed last night that Windows 7 Beta was crashing for me when I tried to open Windows Update.
I've just uninstalled Java, and Windows Update opened fine.
EDIT: Windows Installer was then playing up, so I went back with System Restore, and reinstalled Java because I need it. Windows Update seems to be working.
Windows 7 Beta
Thanks to those who suggested System Restore. I didn't have Java loaded but a Restore fixed my problem. I then cautiously reinstalled the programs I had installed after the Restore point one at a time and tested Windows Update after each install. Nothing affected Windows Update! I'm pretty sure I reinstalled all the software I had loaded. Oh well, this *is* just a beta so I'm not upset. It's still more stable than either the XP or Vista betas were!
Homebrew
Intel DG965WH
8 GB
ATI 2600 XT
SigmaTel 9271
1440 x 900
Thermaltake 750 W
2-80 mm, 1-120 mm
Cable 1.5 Mbps
Same started happening here today, odd as i haven't installed anything new, just opened ie8 and after a while windows updated just crashes and so does windows explorer, i did a system restore and it worked once then it started giving the same error again.
windows 7 64
Windows Update is crashing Windows Explorer for me as well :(
Seems as if this is a widespread problem, as every Windows 7 forum I am subscribed to has people mentioning this problem
Toshiba Equium L40
Vista 32-bit / Windows 7 32-bit (Dual-Boot)
Intel T2080 Dual Core
2Gb
1280x800
PlusNet Unlimited Broadband
hym wonder what it could be. I did a total reinstall. installed all my stuff the way I liked it and made a hidden back up partition with the Windows 7 Partition on it. So if anything like that happens again I can just delete my windows 7 and copy the backup onto it. and doing system restore and backing up files.
something weird seems to be going on it seems like these problems just all started poping up recently or today, i havnt had any untill today and havnt read about any untill today... but then again i dont check things like this often...
TripOG - Kwamathon
windows 7 X64
amd phenom II x4 940
GIGABYTE GA-MA790GP-UD4H
8GB
integrated radeon hd3300
Realtek ALC889A
ASUS VH222H
PQI DK9320GD3R000A03
30Mbps down / 2Mbps up
Well it kinda figures that if it is a problem with a specific update, then the problem would start popping up from the point that update is started to be downloaded by users
Toshiba Equium L40
2Gb
1280x800
i dont think any updates have been released recently well recent enough that the problem would start today... but then again i dunno i havnt paid much attention to my windows update logs
TripOG - Kwamathon
windows 7 X64
8GB
Realtek ALC889A
ASUS VH222H
The windows update crash strikes back... (and nothing installed since the system restore...)
Turion 64x2
2Go
GeForce Go 7600
Seems we have a solution here: SQM Client Causing Crashing in Windows 7 at Chris123NT’s Blog
1. Delete the string values (Except for (Default)) in HKLM\Software\Microsoft\SQMClient\Windows\DisabledSessions
2. Start gpedit.msc
3. Expand Computer Configuration, expand Administrative Templates, expand System, expand Internet Communication Management, and then click Internet Communication settings.
4. In the details pane, double-click Turn off Windows Customer Experience Improvement Program, and then click Enabled.
The problem comes from the HKLM\Software\Microsoft\SQMClient\Windows\DisabledSessions\MachineThrottling
Deleting or renaming it solves the problem. Turning off WCEIP apparently prevents the problem to happen again.
Turion 64x2
2Go
GeForce Go 7600
Fix confirmed working :)
Toshiba Equium L40
2Gb
1280x800
Also confirm the fix is working!!!!!!!!!!!!! :)
Advent Roma Laptop
Windows 7 Enterprise SP1 x64 Windows 8 Enterprise RTM x64
Mobile DualCore Intel Pentium T4400, 2200 MHz (11 x 200)
Advent Roma (Intel Cantiga GL40)
4028 MB (DDR2-667 DDR2 SDRAM)
Mobile Intel(R) GMA 4500M
Realtek ALC662 @ Intel 82801IB ICH9 - High Definition Audio
Generic PnP Monitor [NoDB]
1366x768
TOSHIBA MK5065GSX ATA Device (500 GB, 5400 RPM, SATA-II)
Mikomi 7 Button Laser Mouse w/DPi Switch
Slow!!
I am running the Official Release of Windows 7 Beta build 7000 X64. I have done no "hacking" or "Tweaking" to date on this. Wanted to run it as intended and see how stable it was. I have been checking for updates daily and performing them as needed.
I experienced the same thing as described here today. Could not do any updates. Wouldn't even open that page.... So it wasn't any hacks or tweaks on my end, and it was with X64 for me, no x86. I did do the Send Feedback and also the Report an issue and described my problem. If anyone pays attention to those on MSofts end, then they got my info.
Hope this helps. I will try the fix described here when I have a moment and report back.
Windows 7 Beta Build 7000
