Solved Long standing USB port problem
ICIT2LOL
Confusion Therapist
10:29 AM
Central West NSW
For a long time now I have not been able to load a stick to ANY USB ports on my Asus P8Z77-V board. Have tried plugging sticks into ports that I know are working ie the mouse and KB ones but even with a brand new stick I get no joy.
I have tried sfc chkdsk, malware scans, loading the drivers again from saved files, including the Windows feature and Slim Drivers (something I don't like to use but any port in a storm) , Mr Fixit etc etc ad nauseum and am getting nowhere.
In Devices and Printers I get what is in the pics any ideas as I think I shall have dump the board soon as I can get nowhere with Asus support - their site is now almost impossible to access and full of rubbish re 10 and how good it is. :sarc:
1920x1080 D1 & D2 & Laptop 1
Desk1 Samsung 120GB 830 SSD
Asus ROG 256GB 850 Pro SSD
Desk2 Samsung 840 256 SSD
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
I have had this problem myself and I can tell you what has worked for me.
First let me say that A.) I am no expert and 2.) I don't fully understand the problem or the solution.
That said consider this a "use at your own risk" idea and please by all means use full precautions in the way of backups, restore points etc.
In my research of the problem I came to understand that Windows builds a list of devices plugged into USB ports. Once a list of "ghosted" devices accumulates it can and apparently does interfere with other devices being recognized.
For instance after a few months I'll find my phone is no longer recognized. This is especially true if I have used my computer to work on a number of other phones in the interim. Similar experiences occur with various other USB devices after a time.
My research led me to a program (free and open source) called "Ghostbuster" @ GhostBuster - Home
Using this to remove the "ghosted" USB entries has worked for me repeatedly over a period of years and has done no harm to my system. After running the program problem devices are once again recognized in the usual fashion.
It's a trifle tedious as you have to go through a list of devices and select only those that you recognize as truly removed USB devices.
Again This is what has worked for me! Even the programs coder advises " use it with care and only if you know what you are doing."
I offer this only because, as I had, you seem to have "tried everything" and nothing worked.
Do your own research. Make your own decision.
HTH
D
Dell XPS 8700 SE
Windows 10 Professional 64bit.
Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
Dell Inc. Model 0KWVT8
16 GB Micron DDR3 [PC3-12800]
NVIDIA GeForce GTX 650 Ti
SB Recon3D PCIe
Dell 2707WFP
1920 x 1200
Manufacturer Seagate
Model ST2000DM001-1CH SCSI Disk Device
Size 2000 GB with SAMSUNG SSD PM830 mSATA 32GB Cache drive.
Seagate
Model ST1000DM003-1CH162
Size 1000 GB
Western Digital
Model WDC WD2500JS-22MHB0
Size 250 GB
@datapod
Not sure how it compares to Ghostbusters but you also might have a look at the USB Mass Storage cleanup tool.. How to Cleanup and Remove old USB Mass Storage Drivers. It removes all old USB Mass Storage devices and drivers for devices not connected to your computer (which is what make them "ghosts")
@ici2tlol
Download and run the Filter Driver Load Order tool. Hit the Clipboard button and paste the result into next post
Dell Optiplex 360 and Optiplex 755
Desk 1: Win 7 Pro x32; Desk 2: Windows 10 x64
500GB Crucial SSD in both Desktops
Buffalo 6TB NAS, Raid 1
Ok you folks I am running a Kaspersky rescue disk out of desperation right now but will give those a try cos I don't really want to have to replace the board and the ways things are it would have to be the CPU and RAM as well with that Skylake stuff :(
But if I have to then I shall go for something less upbeat as I bough tis one to try OC but really it isn't worth it eh?
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
All USB flash drives (and USB external disks) failing with the same device driver error code= 10 is often caused by driver filters. Post the result of Filter Load Order tool. Hopefully your problem can be fixed too <fingers crossed>
Ok well the Kaspersky RD did not come up with anything but I am darned if I can find the clipboard to post those results.:confused:
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Just use Ctrl+V to paste into your post John.
Win 10 Pro x64
Intel I5-2500K @3.3GHz
Asrock P67 Extreme4
EVGA GeForce 750 Ti SC 2GB
auria eq2367
250GB Samsung 850 EVO SSD
1TB WD Blue
1TB Hitachi
SeaSonic X 650W 80 Plus Gold
Corsair Obsidian 750D
Logitech Wireless Mouse M310
Wave Broadband ~ 100 dn 5 up
Edge, IE11, Chrome
Laptop specs: HP g7-1365dx /
RAM: Crucial 8Gb (2x4Gb) /
GFX: AMD Radeon HD 6520G /
OS: Windows 10 Pro x64
Many times when you do a clipboard you will find that it is using Notepad.a
When you send something to Clipboard just look in Notepad.
Can't say I've ever had that happen. I just tried it with the above program and there was nothing there.
Win 10 Pro x64
Asrock P67 Extreme4
auria eq2367
1TB WD Blue
1TB Hitachi
Edge, IE11, Chrome
Shouldn't really need to find or look for the clipboard, it only stores one thing at a time anyway, just right click> paste or Ctrl+V.
That is an interesting tidbit though.
Win 10 Pro x64
Asrock P67 Extreme4
auria eq2367
1TB WD Blue
1TB Hitachi
Edge, IE11, Chrome
Yep that is what I did but nothing showed maybe it is the board dying?? Anyway I ma away form my place for a bit so will have to try next time I am there.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Can you be more specific? What didn't show????
> The the tool not run?
> Tool ran but nothing listed under Disk Drives you could select?
> You selected a Disk but then didn't see a Cliboard button??
> p.s. point of note: You must select any one Disk devices, and not the Disk category if that's what you did
> You won't see anything happen when you click Clipboard button. You only see resulting information when you paste into something (like pasting back into your post)
Can you post the screen shot9s0 and explain what didn't work?
1) I'm curious as no one has ever reported that user problem before so would like more specifics
2) If necessary, we can also collect the information I want manually)
If you could try that tool again per above as i've never had a problem with it before (so am curious as to where you find a problem)
But to save time (and your nerves in trying to fix this problem!) here's alternate instruction to manually provide the starting data i want
  1. Right click on any disk drive you see in Device Manager, select Properties then the Details tab
  2. Use the pull down menu to carefully look if any entry exists for Class upper filters and/or Class lower filter (see snapshot below) For each if found, you can Ctl-A to select all the display info then paste that info for each into next post. Or simply take snapshot(s) if easier
  3. Now go to the Driver tab. Click the Driver Details button. Provide a snapshot of the Driver File Details window that appears
Ok I will try that when I next have access to the machine. IT is very frustrating though because I have several USB outlets on the thing and not one of them work with a stick/s yet the KB and mouse no problems:confused:
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Sorry for very late replymate but don't get back to my place very often. Attached are pics of the drives and results they may not be in order .
Also at desktop screen on the Password appears and is entered it pops up this ini message??
Now I notice the second drive the spinner has that PartMnr listed in the filters.
Have had problems with this Ivy machine for a long time now:(
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
CG Some pics I could not fit in last post don't know if there is any relevance??
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
Bingo! I've fixed this problem before. It's the Samsung Rapid Mode filter. Try turning off Rapid Mode. Verify the Samsung lower filter is no longer listed. Try your usb drives again. Hope that works for you too!
http://www.sevenforums.com/drivers/372111-device-cannot-start-code-10-a.html
/* EDIT */
Some have also uninstalled then reinstalled Samsung magician to fix the problem. Either approach seems to have worked in the past
/* EDIT */
Thanks CG mate I shall give it a whirl when I am next at my place (I live with my partner now).
Perhaps it has been causing the other problems too and I shall reinstall the Magician too - I have used it to do things with the drive nothing over the top but again perhaps it has got corrupted.
Who would even think that would cause my board USB's to fail?? it simply makes no sense - to me;)
I am back there this weekend I will update you.
Toshiba 120GB EVO
ADSL2+
Canon MG5250MFC
