Solved A "unique" (?) problem with non-functioning right-click
Notbillgates
7:07 AM
Chicago, IL
I have what seems to be a unique right-click problem. After searching a bit, I found nothing that seemed to relate exactly to my issue.
My system is as listed in "My System Specs" (OS, CPU, motherboard, etc.).
On my system, there are setup a limited user account set, my own account (administrator-level), and also the built-in administrator account (unhidden and renamed).
MY ISSUE:
Right-click is non-functional. No context menus appear anywhere at any time.
ADDITIONAL INFORMATION:
The application key on my Microsoft Natural Elite keyboard *does* bring up context menus (discovered this by chance).
Right-clicking with the mouse *does* bring up context menus in the limited user account, as well as in the built-in administrator account.
When running in Windows XP mode from my own account (I need this mode to run an application I use), the non-functioning right-click issue persists.
This problem arose seemingly “out of nowhere”. The only thing I had done recently was to run the “All tasks” (“mygodmode”) application–just as a matter of curiosity.
WHAT I HAVE TRIED:
1. I have run SFC. No change.
2. I have run checks for malware, viruses. No issues.
3. I have run ShellExView and ShellMnView. No change.
4. I have changed the USB ports into which the mouse and keyboard are connected. No change
5. I have updated the drivers for the mouse and keyboard. No change.
6. I have uninstalled, then reinstalled the drivers for the mouse and keyboard. No change.
7. I have tried a different mouse. No change (behavior is the same as with the Wireless Laser Mouse 5000 I use).
8. I have switched the left-right buttons on the mouse from the driver software/control panel. No change. It’s just the left-click that doesn’t work. Switching back to default takes me back to my problem. At least I know the issue is not in the mouse itself.
9. I turned off system restore and then back on again. No change. (I saw that this worked for someone else.)
10. Uninstalled “Mygodmode”. Reinstalled it. Uninstalled it again. No change at any time.
11. Disconnected the keyboard (in case of a conflict of some sort?). No change.
WHAT I WILL TRY NEXT:
I will connect a different keyboard (late tomorrow) to see if doing so has any effect.
WHAT I WOULD LIKE TO AVOID:
I’d prefer not to do a repair-reinstall, as I might not be able to reinstall Windows XP mode, which I use for a particular application.
I would appreciate any thoughts about how to resolve the issue I’m having.
Windows 7 Professional, 64-bit, Service Pack 1i7-3820Crucial 32 GB DDR3ASUS GeForce GTX 760 DirectCU II
Custom build
i7-3820
ASUS P9X79 Pro
Crucial 32 GB DDR3
NEC PA302W-BK
2560 x 1600
Samsung 840 Pro SSD, 265 GB (three of these)
Antec HCP-850
Lian Li PC-A71F Black
Microsoft Wireless Laser Mouse 5000
Norton AntiVirus (most recent version: 21.2.0.38)
Please take a look here and see if it applies.
Windows 7 32 bitAMD 5200+ dual core2 GBNVidia GeForce 6150SE 128 MB
HP Media Center
Windows 7 32 bit
AMD 5200+ dual core
2 GB
CRT
1280x1024
500 GB Sata internal :
PS/2
PS/2 Wheel Mouse
SIIG USB 3.0 PCIexpress card.
I appreciate your pointing me to that link, Miles. I made the change in both places in the registry, but I am still without any context menus. Thanks for the help.
On a whim, I decided to disconnect the keyboard (have added an item 11 to my initial post). Still nothing.
Custom build
i7-3820
ASUS P9X79 Pro
Crucial 32 GB DDR3
NEC PA302W-BK
2560 x 1600
Antec HCP-850
Too bad. Thought I might have gotten lucky with that hit. There is something that disables right click because public library computers I've used have it disabled totally. Are you running any AutoHotkey programs in the task tray? If one has a bug it could "eat" the right click. I suspect it may be something like that because the keyboard menu key works.
HP Media Center
Windows 7 32 bit
AMD 5200+ dual core
2 GB
CRT
1280x1024
PS/2
PS/2 Wheel Mouse
MilesAhead,
THANK YOU!!!!!
Your suggestion of looking into an AutoHotKey program was on the mark.
Last night--after way too many hours on the system--I was adding two hot keys and remember seeing the right-click defined as part of the new sequence. I corrected it so that the Windows key would be used, but only the left one. For the Windows key on the right of the keyboard, the "right-click" from the mouse remained in the definition, but I did not realize that until reading your message.
I went into my hot key application a few moments ago, and there it was: a right-click being used instead of the Windows key to the right of the spacebar. As you suspected, my right mouse button was getting "eaten".
The hot key definition has been corrected, and all is well.
It really does help to have others look at a problem one is having.
Thank you very, very much! :):):)
Custom build
i7-3820
ASUS P9X79 Pro
Crucial 32 GB DDR3
NEC PA302W-BK
2560 x 1600
Antec HCP-850
You are quite welcome. Glad it's resolved.
HP Media Center
Windows 7 32 bit
AMD 5200+ dual core
2 GB
CRT
1280x1024
PS/2
PS/2 Wheel Mouse
