Boot Issue BIOS-WindowsBootManager-System Recovery problem
Every BIOS has a boot order listing which allows you to choose which order to boot devices. EFI BIOS have a listing for something like EFI Boot Disk which must be removed from priority to install to an MBR disk.
EFI bioses will change a boot order without input from the user. Depending on whether you have media in the DVD or not, different options will be offered. Same type of thing with a Flash drive. But as long as the media is present, it should maintain the order, and this would be for situations like installs.
My suggestion is to always use the Boot device menu to make sure what you are booting to.
Edit: If you want, there is a setting in the bios on the boot page that will set which type of system you want to boot. If you go with MBR, you can set it to boot Legacy only and you won't have to worry about any UEFI boots.
Windows 7 x64i7-2600K8 GGTX 480
Homebuilt
Windows 7 x64
i7-2600K
Asus P8Z77-v Pro
8 G
GTX 480
Onboard
LG W2753V
Crucial M4 128 G SSD
Thanks, Saltgrass. So glad for your return just as EFI BIOS are coming online challenging most of what we have learned about install and repair. Please stick around and help us with these.
Yes, I went through my bios manual line by line and saw nothing regarding MBR or GPT format types.
Sorry for not posting that when I encountered it, but I had nothing set up yet and did not have alternative way to get online. I had printed up the guides you linked, so I thought I knew enough about it to try some different options.
Windows 7 Home Premium 32bit
In every case so far when there was not EFI Boot disk in BIOS Boot order selection, there was a setting nearby for Legacy Boot that also removes EFI boot to install.
In your case until it is learned how to remove EFI install you'll need to install and repair using EFI on a GPT formatted HD.
