Computer running slow repair does not help
lesgeektech
8:21 AM
new york
hello
after going thru some old post and trying to use various scans i am not having any luck in getting my computer to start running correctly. all of a sudden it just started dragging and as of now i am trying to go in to safe mode with networking from 4:08 pm est and it still has not loaded up.
I am wondering if i should just do a system repair.
I had notice the other day after trying to start aol it gave a message that it was not compatible with win 7 but then it would start
this is a home build pc wind 7 32 bit utl
now it just restarted so it did not go into safe mode..
msi p45 mobo
4 gb corair ram
nvida graphic card
seagate 1 tb hard drive
any ideas or suggestions
thanks
ok so this message just came up
c:\programfiles\common
files\aol\1364913661\ee\service\waolTrayMenueservice\ver_0_9_1\waol
TrayMenuService .dll is either not designed to run on windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator of the software vendor for support
home built
windows 7 ultimate 32 bit
e8400 dual core
msi p45 neo
4gb corsair
nvida geforce
system board
gateway 20 inch and acer 21 inch
seagate 1tb
xion
install several fans in case
gateway
microsoft wireless
broadband
microsoft essentials
hello
msi p45 mobo
4 gb corair ram
nvida graphic card
thanks
Can your PC boot?
Try this:
Shut down your PC. Then, power it on and start pressing the f8 key. You should be on the Advanced Boot Options Screen. Then, use the keyboard arrow keys to select Repair Your Computer. Then, press enter. Once you have gone through the on-screen boxes, click on Startup Repair. If it prompts you to System Restore, go ahead and restore it.
Note: This will restore your computer to an earlier day. Your personal files shouldn't be affected, but a program that you installed after the restore point was made will be deleted.
Also, do you use registry "cleaners" or other "optimizers?"
HP Pavilion P7-1010
AMD Athlon X4 645
Foxxcon N-Alvorix RS880
6GB DDR3 1066
Sapphire Radeon HD 5670 512MB GDDR5
Realtek Integrated Audio
HP 2011x
1600x900
1. Crucial M4 128GB SSD
2. 1TB Seagate Barracuda 7200.12 RPM
3. 1TB Western Digital Caviar Green 5400RPM
Seasonic S12 II Bronze 380 Watt
HP OEM
Coolermaster Heatsink, AVC Case Fan
HP OEM- Made by Chicony
HP OEM- Made by Logitech
20MBit Down/4 Up
Internet Explorer 10
it boots but i am unable to go into the safe mode screen
no i do not know how to use registry cleaners i just deleted aol off my computer since that was the only thing that was done differently
I was able to go into safe mode but it was unable to complete the task it said error copying :
System restore did not complete successfully your computer system files and setting were not changed
System restore failed while copying registry from the restore point an unspecified error occurred during system restore
(Ox80070570)
home built
e8400 dual core
msi p45 neo
4gb corsair
nvida geforce
system board
seagate 1tb
xion
gateway
microsoft wireless
broadband
(Ox80070570)
Try using another restore point.
HP Pavilion P7-1010
AMD Athlon X4 645
6GB DDR3 1066
HP 2011x
1600x900
HP OEM
20MBit Down/4 Up
